One of our users shared their logs files for our app and I see this inside of their log files.
tor_server-1 | Dec 01 18:36:37.588 [warn] Unparseable address in hidden service port configuration.
tor_server-1 | Dec 01 18:36:37.588 [warn] Failed to parse/validate config: Failed to configure rendezvous options. See logs for details.
tor_server-1 | Dec 01 18:36:37.588 [err] Reading config failed--see warnings above.
tor_server-1 | Dec 01 18:37:37.762 [notice] Tor 0.4.7.8 running on Linux with Libevent 2.1.12-stable, OpenSSL 1.1.1n, Zlib 1.2.11, Liblzma N/A, Libzstd N/A and Glibc 2.31 as libc.
tor_server-1 | Dec 01 18:37:37.762 [notice] Tor can't help you if you use it wrong! Learn how to be safe at
tor_server-1 | Dec 01 18:37:37.762 [notice] Read configuration file "/tmp/torrc".
tor_server-1 | Dec 01 18:37:37.772 [warn] Unparseable address in hidden service port configuration.
tor_server-1 | Dec 01 18:37:37.772 [warn] Failed to parse/validate config: Failed to configure rendezvous options. See logs for details.
tor_server-1 | Dec 01 18:37:37.772 [err] Reading config failed--see warnings above.
mintsolo-platform-mintsolo_zrok-share_1 | [ 0.196] INFO main.(*shareReservedCommand).shareLocal: sharing target: 'http://server:3068'
mintsolo-platform-mintsolo_zrok-share_1 | [ 0.196] INFO main.(*shareReservedCommand).shareLocal: using existing backend target: http://server:3068
mintsolo-platform-mintsolo_zrok-share_1 | [ERROR]: unable to create 'proxy' backend (error listening: failed to listen: no apiSession, authentication attempt failed: Post "https://ziti.shared.mintsolo.app:80/edge/client/v1/authenticate?method=cert": context deadline exceeded (Client.Timeout exceeded while awaiting headers))
mintsolo-platform-mintsolo_zrok-share_1 | WARNING: STATE_DIRECTORY is undefined. Using HOME=/mnt
mintsolo-platform-mintsolo_zrok-share_1 | DEBUG: zrok state directory is /mnt/.zrok
mintsolo-platform-mintsolo_zrok-share_1 | DEBUG: ZROK_SHARE_RESERVED=true
mintsolo-platform-mintsolo_zrok-share_1 | INFO: zrok backend is already reserved: l3c6y9zlv87b
mintsolo-platform-mintsolo_zrok-share_1 | INFO: running: zrok share reserved l3c6y9zlv87b --override-endpoint http://server:3068 --headless
mintsolo-platform-mintsolo_zrok-share_1 | [ 0.193] INFO main.(*shareReservedCommand).shareLocal: sharing target: 'http://server:3068'
mintsolo-platform-mintsolo_zrok-share_1 | [ 0.193] INFO main.(*shareReservedCommand).shareLocal: using existing backend target: http://server:3068
From those logs, it appears that we may have erred in creating our server: container due to the following error on their system.
