Just having a to and fro with ChatGPT and sending over tcpdumps etc, it seems to think the connection begins but then the client side never responds and something in the middle is causing connection to be killed.
Also I have some output from the local ziti router.
ssh output
be2b67ee4cdc:~# ssh root@10.12.10.9 -vvv
OpenSSH_9.7p1, OpenSSL 3.3.0 9 Apr 2024
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 22: include /etc/ssh/ssh_config.d/*.conf matched no files
debug2: resolve_canonicalize: hostname 10.12.10.9 is address
debug3: expanded UserKnownHostsFile '~/.ssh/known_hosts' -> '/root/.ssh/known_hosts'
debug3: expanded UserKnownHostsFile '~/.ssh/known_hosts2' -> '/root/.ssh/known_hosts2'
debug3: channel_clear_timeouts: clearing
debug3: ssh_connect_direct: entering
debug1: Connecting to 10.12.10.9 [10.12.10.9] port 22.
debug3: set_sock_tos: set socket 3 IP_TOS 0x48
debug1: Connection established.
debug1: identity file /root/.ssh/id_rsa type -1
debug1: identity file /root/.ssh/id_rsa-cert type -1
debug1: identity file /root/.ssh/id_ecdsa type -1
debug1: identity file /root/.ssh/id_ecdsa-cert type -1
debug1: identity file /root/.ssh/id_ecdsa_sk type -1
debug1: identity file /root/.ssh/id_ecdsa_sk-cert type -1
debug1: identity file /root/.ssh/id_ed25519 type -1
debug1: identity file /root/.ssh/id_ed25519-cert type -1
debug1: identity file /root/.ssh/id_ed25519_sk type -1
debug1: identity file /root/.ssh/id_ed25519_sk-cert type -1
debug1: identity file /root/.ssh/id_xmss type -1
debug1: identity file /root/.ssh/id_xmss-cert type -1
debug1: identity file /root/.ssh/id_dsa type -1
debug1: identity file /root/.ssh/id_dsa-cert type -1
debug1: Local version string SSH-2.0-OpenSSH_9.7
kex_exchange_identification: read: Connection reset by peer
Connection reset by 10.12.10.9 port 22
05-23T10:12:13.049Z"}
ziti-router-1 | {"file":"github.com/openziti/ziti/tunnel/intercept/tproxy/tproxy_linux.go:103","func":"github.com/openziti/ziti/tunnel/intercept/tproxy.New","level":"info","msg":"tproxy config: udpCheckInterval = [30s]","time":"2025-05-23T10:12:13.049Z"}
ziti-router-1 | {"file":"github.com/openziti/ziti/tunnel/intercept/tproxy/tproxy_linux.go:277","func":"github.com/openziti/ziti/tunnel/intercept/tproxy.(*interceptor).addIptablesChain","level":"info","msg":"added iptables 'mangle' link 'PREROUTING' --\u003e 'NF-INTERCEPT'","time":"2025-05-23T10:12:13.054Z"}
ziti-router-1 | {"file":"github.com/openziti/ziti/tunnel/intercept/tproxy/tproxy_linux.go:143","func":"github.com/openziti/ziti/tunnel/intercept/tproxy.New","level":"info","msg":"no lan interface specified with '-lanIf'. please ensure firewall accepts intercepted service addresses","time":"2025-05-23T10:12:13.054Z"}
ziti-router-1 | {"file":"github.com/openziti/ziti/router/xgress_edge_tunnel_v2/tunneler.go:150","func":"github.com/openziti/ziti/router/xgress_edge_tunnel_v2.(*tunneler).NotifyIdentityEvent","level":"info","msg":"identity updated xUEQ-4UCo, eventType: identity.full-state","time":"2025-05-23T10:12:13.054Z"}
ziti-router-1 | {"file":"github.com/openziti/ziti/router/xgress_edge_tunnel_v2/tunneler.go:160","func":"github.com/openziti/ziti/router/xgress_edge_tunnel_v2.(*tunneler).NotifyServiceChange","level":"info","msg":"service changed for local-router-lsk15. service snmp-service was access.gained","time":"2025-05-23T10:12:13.054Z"}
ziti-router-1 | {"file":"github.com/openziti/ziti/tunnel/intercept/svcpoll.go:155","func":"github.com/openziti/ziti/tunnel/intercept.(*ServiceListener).HandleServicesChange","level":"info","msg":"adding service","service":"snmp-service","time":"2025-05-23T10:12:13.054Z"}
ziti-router-1 | {"file":"github.com/openziti/ziti/tunnel/intercept/svcpoll.go:226","func":"github.com/openziti/ziti/tunnel/intercept.(*ServiceListener).addService","level":"info","msg":"starting tunnel for newly available service snmp-service","serviceId":"5vYnRfmnxE5a8N7cpwHxT","serviceName":"snmp-service","time":"2025-05-23T10:12:13.054Z"}
ziti-router-1 | {"file":"github.com/openziti/ziti/tunnel/intercept/tproxy/tproxy_linux.go:241","func":"github.com/openziti/ziti/tunnel/intercept/tproxy.(*interceptor).newTproxy","level":"info","msg":"tproxy listening on udp:127.0.0.1:57027, remoteAddr: \u003cnil\u003e","time":"2025-05-23T10:12:13.054Z"}
ziti-router-1 | {"file":"github.com/openziti/ziti/tunnel/intercept/tproxy/tproxy_linux.go:555","func":"github.com/openziti/ziti/tunnel/intercept/tproxy.(*tProxy).addInterceptAddr","level":"info","msg":"Adding rule iptables -t mangle -A NF-INTERCEPT [-m comment --comment snmp-service -d 10.12.10.9/32 -p udp --dport 161:161 -j TPROXY --tproxy-mark 0x1/0x1 --on-ip=127.0.0.1 --on-port=57027]","time":"2025-05-23T10:12:13.055Z"}
ziti-router-1 | {"file":"github.com/openziti/ziti/router/xgress_edge_tunnel_v2/tunneler.go:160","func":"github.com/openziti/ziti/router/xgress_edge_tunnel_v2.(*tunneler).NotifyServiceChange","level":"info","msg":"service changed for local-router-lsk15. service ssh-service was access.gained","time":"2025-05-23T10:12:13.056Z"}
ziti-router-1 | {"file":"github.com/openziti/ziti/tunnel/intercept/svcpoll.go:155","func":"github.com/openziti/ziti/tunnel/intercept.(*ServiceListener).HandleServicesChange","level":"info","msg":"adding service","service":"ssh-service","time":"2025-05-23T10:12:13.056Z"}
ziti-router-1 | {"file":"github.com/openziti/ziti/tunnel/intercept/svcpoll.go:226","func":"github.com/openziti/ziti/tunnel/intercept.(*ServiceListener).addService","level":"info","msg":"starting tunnel for newly available service ssh-service","serviceId":"4VNjVPeiJ6Ew6AN9IuJYVy","serviceName":"ssh-service","time":"2025-05-23T10:12:13.056Z"}
ziti-router-1 | {"file":"github.com/openziti/ziti/tunnel/intercept/tproxy/tproxy_linux.go:228","func":"github.com/openziti/ziti/tunnel/intercept/tproxy.(*interceptor).newTproxy","level":"info","msg":"tproxy listening on tcp:127.0.0.1:46177","time":"2025-05-23T10:12:13.056Z"}
ziti-router-1 | {"file":"github.com/openziti/ziti/tunnel/intercept/tproxy/tproxy_linux.go:555","func":"github.com/openziti/ziti/tunnel/intercept/tproxy.(*tProxy).addInterceptAddr","level":"info","msg":"Adding rule iptables -t mangle -A NF-INTERCEPT [-m comment --comment ssh-service -d 10.12.10.9/32 -p tcp --dport 22:22 -j TPROXY --tproxy-mark 0x1/0x1 --on-ip=127.0.0.1 --on-port=46177]","time":"2025-05-23T10:12:13.056Z"}
ziti-router-1 | {"file":"github.com/openziti/ziti/tunnel/intercept/tproxy/tproxy_linux.go:310","func":"github.com/openziti/ziti/tunnel/intercept/tproxy.(*tProxy).acceptTCP","level":"info","msg":"received connection: 10.12.10.9:22 --\u003e 10.12.10.9:47474","time":"2025-05-23T10:13:28.917Z"}
ziti-router-1 | {"_channels":["establishPath"],"attempt":1,"attemptNumber":"2","circuitId":"lis8vQUaz","context":"ch{ctrl}-\u003eu{reconnecting}-\u003ei{NetFoundry Inc. Client LIboJaJ32/98Ya}","error":"invalid link destination 2SYIhX0zqPktxzfpkuDpF6","file":"github.com/openziti/ziti/router/handler_ctrl/route.go:140","func":"github.com/openziti/ziti/router/handler_ctrl.(*routeHandler).fail","level":"error","msg":"failure while handling route update","serviceId":"4VNjVPeiJ6Ew6AN9IuJYVy","time":"2025-05-23T10:13:28.985Z"}
ziti-router-1 | {"_context":"ch{ctrl}-\u003eu{reconnecting}-\u003ei{NetFoundry Inc. Client LIboJaJ32/98Ya}","file":"github.com/openziti/ziti/router/handler_ctrl/fault.go:65","func":"github.com/openziti/ziti/router/handler_ctrl.(*faultHandler).handleFault","level":"info","linkId":"3MIE29zGJh6l3KHGAE5wOL","msg":"link fault reported, closing","time":"2025-05-23T10:13:28.985Z"}
ziti-router-1 | {"_context":"ch{l/3MIE29zGJh6l3KHGAE5wOL}-\u003eu{classic}-\u003ei{3MIE29zGJh6l3KHGAE5wOL/OoP7}","file":"github.com/openziti/ziti/router/handler_link/close.go:56","func":"github.com/openziti/ziti/router/handler_link.(*closeHandler).HandleClose.func1","iteration":1,"level":"info","linkId":"3MIE29zGJh6l3KHGAE5wOL","msg":"link closed","routerId":"xUEQ-4UCo","time":"2025-05-23T10:13:28.985Z"}
ziti-router-1 | {"_context":"ch{l/3MIE29zGJh6l3KHGAE5wOL}-\u003eu{classic}-\u003ei{xUEQ-4UCo/4dp4}","file":"github.com/openziti/ziti/router/handler_link/close.go:56","func":"github.com/openziti/ziti/router/handler_link.(*closeHandler).HandleClose.func1","iteration":1,"level":"info","linkId":"3MIE29zGJh6l3KHGAE5wOL","msg":"link closed","routerId":"xcPcN-mto","time":"2025-05-23T10:13:28.986Z"}
ziti-router-1 | {"file":"github.com/openziti/ziti/router/link/link_state.go:106","func":"github.com/openziti/ziti/router/link.(*linkState).updateStatus","iteration":1,"key":"default-\u003etls:xcPcN-mto-\u003edefault","level":"info","linkId":"3MIE29zGJh6l3KHGAE5wOL","msg":"status updated","newState":"linkFailed","oldState":"established","time":"2025-05-23T10:13:28.986Z"}
ziti-router-1 | {"file":"github.com/openziti/ziti/router/link/link_state.go:106","func":"github.com/openziti/ziti/router/link.(*linkState).updateStatus","iteration":1,"key":"default-\u003etls:xcPcN-mto-\u003edefault","level":"info","linkId":"3MIE29zGJh6l3KHGAE5wOL","msg":"status updated","newState":"dialing","oldState":"linkFailed","time":"2025-05-23T10:13:28.986Z"}
ziti-router-1 | {"file":"github.com/openziti/ziti/router/link/link_registry.go:543","func":"github.com/openziti/ziti/router/link.(*linkRegistryImpl).evaluateLinkState","iteration":2,"key":"default-\u003etls:xcPcN-mto-\u003edefault","level":"info","linkId":"3MIE29zGJh6l3KHGAE5wOL","msg":"queuing link to dial","time":"2025-05-23T10:13:28.986Z"}
ziti-router-1 | {"file":"github.com/openziti/ziti/router/link/link_registry.go:555","func":"github.com/openziti/ziti/router/link.(*linkRegistryImpl).evaluateLinkState.func1","iteration":2,"key":"default-\u003etls:xcPcN-mto-\u003edefault","level":"info","linkId":"3MIE29zGJh6l3KHGAE5wOL","msg":"dialing link","time":"2025-05-23T10:13:28.986Z"}
ziti-router-1 | {"connId":"7db657b5-2fec-4753-9892-96f4bc9aec41","file":"github.com/openziti/ziti/router/xlink_transport/dialer.go:101","func":"github.com/openziti/ziti/router/xlink_transport.(*dialer).dialSplit","level":"info","linkId":"3MIE29zGJh6l3KHGAE5wOL","msg":"dialing link with split payload/ack channels","time":"2025-05-23T10:13:28.986Z"}
ziti-router-1 | {"connId":"7db657b5-2fec-4753-9892-96f4bc9aec41","file":"github.com/openziti/ziti/router/xlink_transport/dialer.go:123","func":"github.com/openziti/ziti/router/xlink_transport.(*dialer).dialSplit","level":"info","linkId":"3MIE29zGJh6l3KHGAE5wOL","msg":"dialing payload channel","time":"2025-05-23T10:13:28.986Z"}
ziti-router-1 | {"_channels":["link","linkListener"],"dialerBinding":"","file":"github.com/openziti/ziti/router/xlink_transport/listener.go:130","func":"github.com/openziti/ziti/router/xlink_transport.(*listener).BindChannel","iteration":2,"level":"info","linkId":"3MIE29zGJh6l3KHGAE5wOL","linkProtocol":"tls","msg":"binding link channel","routerId":"xUEQ-4UCo","routerVersion":"v1.5.4","time":"2025-05-23T10:13:29.004Z"}
ziti-router-1 | {"_channels":["link","linkListener"],"channelType":1,"connId":"7db657b5-2fec-4753-9892-96f4bc9aec41","dialerBinding":"","file":"github.com/openziti/ziti/router/xlink_transport/listener.go:155","func":"github.com/openziti/ziti/router/xlink_transport.(*listener).bindSplitChannel","iteration":2,"level":"info","linkId":"3MIE29zGJh6l3KHGAE5wOL","linkProtocol":"tls","msg":"accepted part of split conn","routerId":"xUEQ-4UCo","routerVersion":"v1.5.4","time":"2025-05-23T10:13:29.004Z"}
ziti-router-1 | {"dialed":true,"file":"github.com/openziti/ziti/router/handler_link/bind.go:97","func":"github.com/openziti/ziti/router/handler_link.(*bindHandler).BindChannel","iteration":2,"level":"info","linkId":"3MIE29zGJh6l3KHGAE5wOL","msg":"link destination support heartbeats","routerId":"xcPcN-mto","routerVersion":"v1.5.4","time":"2025-05-23T10:13:29.004Z"}
ziti-router-1 | {"connId":"7db657b5-2fec-4753-9892-96f4bc9aec41","file":"github.com/openziti/ziti/router/xlink_transport/dialer.go:144","func":"github.com/openziti/ziti/router/xlink_transport.(*dialer).dialSplit","level":"info","linkId":"3MIE29zGJh6l3KHGAE5wOL","msg":"dialing ack channel","time":"2025-05-23T10:13:29.004Z"}
ziti-router-1 | {"ctrlId":"NetFoundry Inc. Client LIboJaJ32","error":"exceeded maximum [2] retries creating circuit [c/lis8vQUaz] (error creating route for [s/lis8vQUaz] on [r/xUEQ-4UCo] (invalid link destination 2SYIhX0zqPktxzfpkuDpF6))","file":"github.com/openziti/ziti/router/xgress_edge_tunnel_v2/fabric.go:115","func":"github.com/openziti/ziti/router/xgress_edge_tunnel_v2.(*fabricProvider).TunnelService","level":"warning","msg":"failed to dial fabric","service":"ssh-service","time":"2025-05-23T10:13:29.018Z"}
ziti-router-1 | {"error":"exceeded maximum [2] retries creating circuit [c/lis8vQUaz] (error creating route for [s/lis8vQUaz] on [r/xUEQ-4UCo] (invalid link destination 2SYIhX0zqPktxzfpkuDpF6))","file":"github.com/openziti/ziti/tunnel/tunnel.go:49","func":"github.com/openziti/ziti/tunnel.DialAndRun","level":"error","msg":"tunnel failed","service":"ssh-service","time":"2025-05-23T10:13:29.018Z"}
ziti-router-1 | {"file":"github.com/openziti/ziti/router/handler_link/bind.go:140","func":"github.com/openziti/ziti/router/handler_link.(*bindHandler).verifyRouter","level":"info","linkId":"3MIE29zGJh6l3KHGAE5wOL","msg":"successfully verified router for link","routerId":"xUEQ-4UCo","time":"2025-05-23T10:13:29.035Z"}
ziti-router-1 | {"dialed":false,"file":"github.com/openziti/ziti/router/handler_link/bind.go:97","func":"github.com/openziti/ziti/router/handler_link.(*bindHandler).BindChannel","iteration":2,"level":"info","linkId":"3MIE29zGJh6l3KHGAE5wOL","msg":"link destination support heartbeats","routerId":"xUEQ-4UCo","routerVersion":"v1.5.4","time":"2025-05-23T10:13:29.035Z"}
ziti-router-1 | {"_channels":["link","linkListener"],"dialerBinding":"","file":"github.com/openziti/ziti/router/xlink_transport/listener.go:130","func":"github.com/openziti/ziti/router/xlink_transport.(*listener).BindChannel","iteration":2,"level":"info","linkId":"3MIE29zGJh6l3KHGAE5wOL","linkProtocol":"tls","msg":"binding link channel","routerId":"xUEQ-4UCo","routerVersion":"v1.5.4","time":"2025-05-23T10:13:29.036Z"}
ziti-router-1 | {"_channels":["link","linkListener"],"channelType":2,"connId":"7db657b5-2fec-4753-9892-96f4bc9aec41","dialerBinding":"","file":"github.com/openziti/ziti/router/xlink_transport/listener.go:155","func":"github.com/openziti/ziti/router/xlink_transport.(*listener).bindSplitChannel","iteration":2,"level":"info","linkId":"3MIE29zGJh6l3KHGAE5wOL","linkProtocol":"tls","msg":"accepted part of split conn","routerId":"xUEQ-4UCo","routerVersion":"v1.5.4","time":"2025-05-23T10:13:29.036Z"}
ziti-router-1 | {"dialed":true,"file":"github.com/openziti/ziti/router/handler_link/bind.go:97","func":"github.com/openziti/ziti/router/handler_link.(*bindHandler).BindChannel","iteration":2,"level":"info","linkId":"3MIE29zGJh6l3KHGAE5wOL","msg":"link destination support heartbeats","routerId":"xcPcN-mto","routerVersion":"v1.5.4","time":"2025-05-23T10:13:29.036Z"}
ziti-router-1 | {"destId":"xcPcN-mto","dialed":true,"file":"github.com/openziti/ziti/router/accepter.go:23","func":"github.com/openziti/ziti/router.(*xlinkAccepter).Accept","iteration":2,"level":"info","linkId":"3MIE29zGJh6l3KHGAE5wOL","msg":"accepted new link","time":"2025-05-23T10:13:29.036Z"}
ziti-router-1 | {"dest":"xcPcN-mto","dialed":true,"file":"github.com/openziti/ziti/router/link/link_registry.go:274","func":"github.com/openziti/ziti/router/link.(*linkRegistryImpl).applyLink","level":"info","linkProtocol":"tls","msg":"link registered","newLinkId":"3MIE29zGJh6l3KHGAE5wOL","newLinkIteration":2,"time":"2025-05-23T10:13:29.036Z"}
ziti-router-1 | {"file":"github.com/openziti/ziti/router/link/link_state.go:106","func":"github.com/openziti/ziti/router/link.(*linkState).updateStatus","iteration":2,"key":"default-\u003etls:xcPcN-mto-\u003edefault","level":"info","linkId":"3MIE29zGJh6l3KHGAE5wOL","msg":"status updated","newState":"established","oldState":"dialing","time":"2025-05-23T10:13:29.036Z"}
ziti-router-1 | {"file":"github.com/openziti/ziti/router/link/link_registry.go:691","func":"github.com/openziti/ziti/router/link.(*linkRegistryImpl).notifyControllersOfLinks","level":"info","msg":"attempting to queue link notifications","op":"link-notify","time":"2025-05-23T10:13:29.036Z"}
ziti-router-1 | {"file":"github.com/openziti/ziti/router/link/link_registry.go:694","func":"github.com/openziti/ziti/router/link.(*linkRegistryImpl).notifyControllersOfLinks.func1","level":"info","msg":"link notifications starting","op":"link-notify","time":"2025-05-23T10:13:29.036Z"}
ziti-router-1 | {"ctrlId":"NetFoundry Inc. Client LIboJaJ32","file":"github.com/openziti/ziti/router/link/link_registry.go:749","func":"github.com/openziti/ziti/router/link.(*linkRegistryImpl).sendNewLinks","iteration":2,"level":"info","linkId":"3MIE29zGJh6l3KHGAE5wOL","msg":"notified controller of new link","op":"link-notify","time":"2025-05-23T10:13:29.036Z"}
ziti-router-1 | {"file":"github.com/openziti/ziti/router/link/link_registry.go:698","func":"github.com/openziti/ziti/router/link.(*linkRegistryImpl).notifyControllersOfLinks.func1.1","level":"info","msg":"link notifications exiting","op":"link-notify","time":"2025-05-23T10:13:29.036Z"}
ziti-router-1 | {"file":"github.com/openziti/ziti/router/handler_link/bind.go:140","func":"github.com/openziti/ziti/router/handler_link.(*bindHandler).verifyRouter","level":"info","linkId":"3MIE29zGJh6l3KHGAE5wOL","msg":"successfully verified router for link","routerId":"xUEQ-4UCo","time":"2025-05-23T10:13:29.066Z"}
ziti-router-1 | {"dialed":false,"file":"github.com/openziti/ziti/router/handler_link/bind.go:97","func":"github.com/openziti/ziti/router/handler_link.(*bindHandler).BindChannel","iteration":2,"level":"info","linkId":"3MIE29zGJh6l3KHGAE5wOL","msg":"link destination support heartbeats","routerId":"xUEQ-4UCo","routerVersion":"v1.5.4","time":"2025-05-23T10:13:29.066Z"}
ziti-router-1 | {"destId":"xUEQ-4UCo","dialed":false,"file":"github.com/openziti/ziti/router/accepter.go:23","func":"github.com/openziti/ziti/router.(*xlinkAccepter).Accept","iteration":2,"level":"info","linkId":"3MIE29zGJh6l3KHGAE5wOL","msg":"accepted new link","time":"2025-05-23T10:13:29.066Z"}
ziti-router-1 | {"_channels":["link","linkListener"],"channelType":2,"connId":"7db657b5-2fec-4753-9892-96f4bc9aec41","dialerBinding":"","file":"github.com/openziti/ziti/router/xlink_transport/listener.go:181","func":"github.com/openziti/ziti/router/xlink_transport.(*listener).bindSplitChannel","iteration":2,"level":"info","linkId":"3MIE29zGJh6l3KHGAE5wOL","linkProtocol":"tls","msg":"accepted link","routerId":"xUEQ-4UCo","routerVersion":"v1.5.4","time":"2025-05-23T10:13:29.066Z"}
ziti-router-1 | {"dest":"xUEQ-4UCo","dialed":false,"file":"github.com/openziti/ziti/router/link/link_registry.go:274","func":"github.com/openziti/ziti/router/link.(*linkRegistryImpl).applyLink","level":"info","linkProtocol":"tls","msg":"link registered","newLinkId":"3MIE29zGJh6l3KHGAE5wOL","newLinkIteration":2,"time":"2025-05-23T10:13:29.066Z"}
ziti-router-1 | {"_channels":["link","linkListener"],"channelType":2,"connId":"7db657b5-2fec-4753-9892-96f4bc9aec41","dialerBinding":"","file":"github.com/openziti/ziti/router/xlink_transport/listener.go:184","func":"github.com/openziti/ziti/router/xlink_transport.(*listener).bindSplitChannel","iteration":2,"level":"info","linkId":"3MIE29zGJh6l3KHGAE5wOL","linkProtocol":"tls","msg":"link registered","routerId":"xUEQ-4UCo","routerVersion":"v1.5.4","time":"2025-05-23T10:13:29.066Z"}
