Management API authentication
@arslane I do think this issue is the same as mentioned in the PSA. To fix your existing environment, as mentioned in that PSA you can run one sed command and a few cat commands:
sed -i 's#'"${ZITI_PKI}/${ZITI_PKI_CTRL_EDGE_INTERMEDIATE_NAME}/certs/${ZITI_PKI_CTRL_EDGE_INTERMEDIATE_NAME}.cert"'#'"${ZITI_PKI}/${ZITI_PKI_CTRL_EDGE_ROOTCA_NAME}/certs/${ZITI_PKI_CTRL_EDGE_ROOTCA_NAME}.cert"'#g' $ZITI_HOME/$ZITI_NETWORK.yaml
echo "adding controller root CA to ca bundle: $ZITI_PKI/$ZITI_PKI_CTRL_ROOTCA_NAME/certs/$ZITI_PKI_CTRL_ROOTCA_NAME.cert"
cat "$ZITI_PKI/$ZITI_PKI_CTRL_ROOTCA_NAME/certs/$ZITI_PKI_CTRL_ROOTCA_NAME.cert" > "${ZITI_PKI_CTRL_CA}"
echo "adding signing root CA to ca bundle: $ZITI_PKI/$ZITI_PKI_SIGNER_ROOTCA_NAME/certs/$ZITI_PKI_SIGNER_ROOTCA_NAME.cert"
cat "$ZITI_PKI/$ZITI_PKI_SIGNER_ROOTCA_NAME/certs/$ZITI_PKI_SIGNER_ROOTCA_NAME.cert" >>"${ZITI_PKI_CTRL_CA}" >> "${ZITI_PKI_CTRL_CA}"
echo "adding secondary signing intermediate into ca bundle: $ZITI_PKI/$ZITI_PKI_SIGNER_ROOTCA_NAME/certs/${ZITI_PKI_SIGNER_INTERMEDIATE_NAME}_spurious_intermediate.cert"
cat "$ZITI_PKI/$ZITI_PKI_SIGNER_ROOTCA_NAME/certs/${ZITI_PKI_SIGNER_INTERMEDIATE_NAME}_spurious_intermediate.cert" >> "${ZITI_PKI_CTRL_CA}"
sudo systemctl restart ziti-controller
This will patch the flawed controller config file, create a new ca bundle, and restart the controller. After that your environment should be back in shape.
Hey @arslane, just wanted to touch base and see how you are faring?
Hey @arslane I'm following up to see if you've finished these modules for Ansible and how i'd set them up - this would be very cool stuff for automating a Zero-Trust homelab, I'm slowly getting into the whole Ansible/Taraform/Git CI/CD pipelines and OpenZiti is a tough cookie to crack when it comes to automation so far.
