MFA posture check keeps failing after successful MFA enrollment/auth ("an MFA enrollment already exists") - Windows Desktop Edge, Controller 2.0.6 (also 1.6.21)
Hi everyone,
currently trying to role out MFA on one of my bigger networks, failed miserable and tried it now on my small home network first.
I can't get an MFA posture check to pass. MFA enrollment works and the controller accepts it, but the posture check never passes and I can't re-authenticate afterwards.
Setup
  • Controller: 2.0.6 (same behavior on 1.6.21 before I upgraded, hoping for a fix)
  • Edge router version: 2.0.6 (Same behavior on 1.6.21)
  • Client: Ziti Desktop Edge for Windows 2.1.1.3.2, service version 1.18.72
  • Identity runs under the system profile (Windows service)
  • MFA posture check created and attached to the DIAL service policy of the service "xxxx:ZTNA.svc"
  • Posture check settings: [-1 / promptOnWake:yes / promptOnUnlock:yes]
    • Also checked more combinations, results is the same no matter what I put here!
  • Other services of the same identity have no posture check and work fine
What happens
  1. The UI shows the toast "Authorization Required ... requires MFA setup to access services".
  2. I enroll MFA (fresh enrollment, brand-new identity state) and enter the TOTP code. The UI shows MFA as enabled/active.
  3. The posture check for the service still fails. The identity JSON shows MfaEnabled:true, MfaNeeded:false, and the MFA posture check on the service has "IsPassing": false, "IsAccessible": false.
  4. The UI still shows "Authorize". Clicking it and entering a valid TOTP fails with:
    ERROR ZitiDesktopEdge.MFAScreen AuthMFA failed. an MFA enrollment already exists
So the client seems to try to enroll instead of authenticate, and the controller rejects it because the enrollment already exists. My TOTP code is never actually evaluated.
The UI asks for the auth code when I restart the UI/Service and also accepts them the first time, but the posture check still fails.
Log excerpt (trimmed)
[2026-10-07T12:45:37Z] showing toast: Authorization Required JuTe: xxxx requires MFA setup to access services.
[2026-10-07T12:45:55Z] DataClient mfa event received
[2026-10-07T12:46:06Z] ZitiIdentity posture change. is a posture check failing: False
[2026-10-07T12:46:06Z] ZitiIdentity ... "MfaEnabled":true,"MfaNeeded":false ...
service "xxxx:ZTNA.svc": "PostureChecks":[{"IsPassing":false,"QueryType":"MFA","Id":"xxxxxxxxxx"}],"IsAccessible":false
(all other services: PostureChecks null, IsAccessible true)
[2026-10-07T12:49:36Z] DataClient mfa event received
[2026-10-07T12:49:36Z] MFAScreen ERROR AuthMFA failed. an MFA enrollment already exists
What I already tried
  • Restarting the Ziti service, the UI, and the controller
  • Fresh MFA enrollment
  • Upgrading the controller from 1.6.21 to 2.0.6 (no change)
  • different combinations for the posture check settings.
Related reports I found
  • ziti-sdk-c #1061 (MFA auth is not possible when service policy includes MFA posture check), including a comment with Desktop Edge for Windows 2.11.2.8 against a 2.0.4 controller
  • The macOS thread "Having issues with enforcing MFA on MacOS Tunneler", where a maintainer reproduced the same "an MFA enrollment already exists" after assigning an MFA-protected service
  • ziti #4375 (router on release-v2.0.x not seeding MFA posture)
I understand these are closed, but I still see the behavior on current versions, and it also occurs on 1.6.21, which was reported as not affected.
Questions
  1. Is this a known issue in a specific Desktop Edge for Windows / tunneler version, and which release contains the fix?
  2. Is there a client or router version combination that is known to work with MFA posture checks on a dial policy?
  3. Is there a workaround to make the identity re-authenticate (not re-enroll) while the service with the posture check is assigned?
  4. Which logs or debug output would help you? I can provide controller, router and tunneler logs at debug level.
Hi and thanks for the detailed report. The MFA posture checks should work as you're expecting, but as you've found there are a few issues that need to be addressed first. The ones that you pointed out are relevant (and still open):
I also wrote these up after looking at the entire path a little more closely:
I can't promise a date, but posture checks are on our list, and your report gave us what we needed to reproduce the whole problem end to end. Subscribe to those issues for progress, and we'll follow up here once fixes are available. Thanks for digging into this so thoroughly!
