My share is not working
My zrok account has a reserved public name:
foreverchat-2205-private.shares.zrok.io
The reservation exists, but creating a share using:
zrok2 share public http://127.0.0.1:3000 -n public:foreverchat-2205-private --headless
fails with:
[ERROR]: unable to create share (unable to create share: [POST /share][500] shareInternalServerError "")
The same HTTP 500 occurs with a normal public share, so this is not specific to the reserved name.
The reservation was deleted and recreated successfully, but the share still cannot be created.
Please repair/clear the stale share/frontend mapping or controller-side environment state for this account so that the existing reserved hostname can be used again.
I need to preserve this hostname because existing clients already use:
https://foreverchat-2205-private.shares.zrok.io
Please do not delete the reservation unless necessary; I want this exact hostname restored.
For security reasons, I probably would edit away the subdomain name of my account. But maybe that's just me.
Just following up here to let you know in case you haven't seen.. Please follow that thread for updates
Hi. Just following up here too. I made this post on the pinned topic but just FYI here to make sure I cover all the bases... [duplicating the summary of that post here follows]
If you had stuck sessions that cannot be deleted, I'm told you should now be able to delete them on your own again. I don't have any I can test myself personally but if someone does and if they could post a follow-up here with success (or failure but let's hope not) that would be appreciated.
Thanks again for reporting the issues and bearing with us while we make zrok better!
