Setting up a simple controller + edge router + zac on docker
ctrl.84.235.226.183.sslip.io:1280 doesn't work while https://ctrl.84.235.226.183.sslip.io:1280 does
You can access https://ctrl.84.235.226.183.sslip.io:1280/zac/ in a web browser on the same Windows computer that's reporting ctrl[ctrl.84.235.226.183.sslip.io:1280] no controllers are online, correct?
Yes, I can confirm (20 chars lol)
Looking at the windows logs some more... It looks like the windows keychain support is causing the issue connecting to that controller.
Can you:
See if that fixes the issue?
Sweet ! That fixed my issue thanks alot !
