Still with 429 and 500 on shares, Your zrok account Anamaiastudio@gmail.com
and when trying to regenerate the account token got: URL da solicitação
https://api-v1.zrok.io/api/v1/regenerateAccountToken
Método da solicitação
POST
Código de status
404 Not Found
Política do referenciador
strict-origin-when-cross-origin
PLEASE HELP
Hi everyone. If you had stuck sessions that cannot be deleted, I'm told you should now be able to delete them on your own again. I don't have any I can test myself personally but if someone does and if they could post a follow-up here with success (or failure but let's hope not) that would be appreciated.
Thanks again for reporting the issues and bearing with us while we make zrok better!
I wouldn't be able to delete it on my own as the session was created on a virtual machine that is no longer available. I forgot to disable zrok before deleting the vm. So I require your help to delete it please. The stuck environment ID is 5-aZ3oicjK
If you login to the v2 console with your same account you should be able to delete the environments from there. We highly recommend moving to v2 as we will be deprecating v1 soon.
This worked. Thanks very much. I was using the v1 console even after moving to v2.I didnt know there was a v2 console. Thanks again
