Ziti Edge Router General Questions
Ooooh i see, so maybe I don’t need to have all open ports since I’m already using 1280 and 6262, for example. I can close the 8441 and 8442 perhaps.
So the only one I’m missing is the 10080, that goes in the router right? Like so
ziti-controller:
    ports:
      - ${ZITI_EDGE_CONTROLLER_PORT:-1280}:${ZITI_EDGE_CONTROLLER_PORT:-1280}
      - ${ZITI_CTRL_PORT:-6262}:${ZITI_CTRL_PORT:-6262}
  ziti-edge-router:
    ports:
      - ${ZITI_EDGE_ROUTER_PORT:-3022}:${ZITI_EDGE_ROUTER_PORT:-3022}
      - 10080:100080 # I don't know if this port has a special variable name in OpenZiti?
Is this correct?
Yep. You can set a .env property if you like as I did:
ZITI_EDGE_ROUTER_LISTENER_BIND_PORT=8444
  ziti-controller:
    env_file:
      - ./.env
    restart: always
    ports:
      - "${ZITI_EDGE_CONTROLLER_PORT}:${ZITI_EDGE_CONTROLLER_PORT}"
      - "${ZITI_CTRL_PORT}:${ZITI_CTRL_PORT}"
and
  ziti-edge-router:
    environment:
      - ZITI_EDGE_ROUTER_RAWNAME=${ZITI_EDGE_ROUTER_RAWNAME}
    depends_on:
      - ziti-controller
    ports:
      - "${ZITI_EDGE_ROUTER_PORT}:${ZITI_EDGE_ROUTER_PORT}"
      - "${ZITI_EDGE_ROUTER_LISTENER_BIND_PORT}:${ZITI_EDGE_ROUTER_LISTENER_BIND_PORT}"
All right so I finally fixed it! It was the port 10080 that wasn't being mapped in the docker-compose.yml, such a dumb mistake but oh well, the thing is I registered successfully the router and it does appear indeed in the list!
However... I tried testing it doing what you mentioned here
My setup is currently as follows:
My plan was to try to connect to the SSH server on the server machine behind my router from the Client computer, and I thought it'd use the private router that it's running on the same machine.
There's a docker container with the edge router and a docker container with ziti-host and a docker continer running sshd server
The ssh connection works but I think I only see the public router
│ ID        │ CLIENT                    │ SERVICE            │ TERMINATOR             │ PATH
│ S6LzmlcG1 │ clh6l3x6n02sqc1mk83mizzmk │ test_ssh_service │ 2bGRWU70uvKvDH3Mz2SPnS │ r/publicmachine.mydomain.com │
│ X9gKRlpG1 │ clh6l3x6n02sqc1mk83mizzmk │ test_ssh_service │ 2TnxdeJJ3kouNQGOE2MOgc │ r/publicmachine.mydomain.com │
How can I verify what you mentioned here?
Progress! :slight_smile: My guess is that you have not authorized identities to use your new router and you need to add/update an “edge-router-policy”.
Refer back to:
Notice that the private router has an attribute of #private and the public router has an attribute of #public. Notice that “Computer n3” and “Computer n2” are identities with the #home attribute while the android/iOS phones are given #roaming attributes… That’s all for the specific purpose of being able to create edge-router-policies and authorizing which edge routers any given identity is authorized to connect to…
In that case, the person was using satellite internet and wanted to be more restrictive, only allowing the “local network clients” to connect to the #private router and then allowing identities with the #roaming attribute to connect to BOTH the public router and the private router…
You probably don’t need to be as restrictive, but you could if you choose to. You probably just need to add your new edge router to the erp/edge-router-policy
I’ve tried
ziti edge create edge-router-policy my-policy --identity-roles '#all' --edge-router-roles '#all'
But still seeing the same in the ziti fabric list circuits perhaps i need to restart the edge router or something? This is what i have in ziti edge list identities btw
│ ID         │ NAME            │ TYPE   │ ATTRIBUTES     │ AUTH-POLICY │
│ VHpEV6vmO  │ Default Admin   │ User   │                │ default     │
│ VpJLXZYt8  │ client          │ User   │ ssh-clients    │ default     │
│ aUq.ZZTt4w │ privateserverhost|Device │ ssh-server     │ default     │
│ gS9VdXTt4  │ publicserver    │ Router │                │ default     │
│ xEjedZYt4w │ privateserver   │ Router │                │ default     │
and can you run:
ziti edge list edge-routers
ziti edge list erps
and show that output here?
Also can you confirm the listeners.binding(edge).options.advertise of the private router config? It’s found in this section here:
listeners:
  - binding: edge
    address: tls:0.0.0.0:8442
      advertise: ec2-3-134-108-218.us-east-2.compute.amazonaws.com:8442
That advertise address is “some.resolvable.host:3022” (or whatever). Can you then probe that port from one of the client machines and make sure it can reach that configured host:port?
ziti@6654d0aa7325:/persistent$ ziti edge list edge-routers
│ ID         │ NAME            │ ONLINE │ ALLOW TRANSIT │ COST │ ATTRIBUTES │
│ gS9VdXTt4  │ public.machine.com│ true   │ true          │    0 │ public     │
│ xEjedZYt4w │ privatemachine  │ true   │ true          │    0 │ private    │
results: 1-2 of 2
ziti@6654d0aa7325:/persistent$ ziti edge list erps
│ ID                     │ NAME                          │ EDGE ROUTER ROLES │ IDENTITY ROLES   │
│ 2tNBkkIBZtlcOrGjhCIn2t │ my-policy                     │ #all              │ #all             │
│ 31ZUdnk2rzkkzzFFtvy8Qr │ all-endpoints-public-routers  │ #public           │ #all             │
│ gS9VdXTt4              │ edge-router-gS9VdXTt4-system  │ @public.machine.com│ @public.machine.com│
│ xEjedZYt4w             │ edge-router-xEjedZYt4w-system │ @privatemachine   │ @privatemachine  │
Ah it might be this where i messed up
listeners:
  - binding: edge
    address: tls:0.0.0.0:3022
      advertise: privatemachine:3022
      connectTimeoutMs: 1000
      getSessionTimeout: 60
  - binding: tunnel
      mode: host #tproxy|host
In my LAN, the privatemachine:3022 is not resolvable, so I assume I should change this to my local machine's IP which is something like 192.168.1.123 so the above should be this instead
listeners:
  - binding: edge
      advertise: 192.168.1.123:3022
  - binding: tunnel
Am I right?
Can I edit this file directly on the container's data (with nano or something)? After editing, should I restart the container and will it work?
Yes you are correct. That 'advertise' is what clients will try to connect to your edge router at. They need to be able to get to that host/port on the local/private network.
But, you'll need to delete the router now and re-enroll it. ALSO make sure you go down and change the "edge.csr.sans" section... that needs to match what you plan to advertise:
    sans:
      dns:
        - ec2-3-134-108-218.us-east-2.compute.amazonaws.com
        - localhost
      ip:
        - "127.0.0.1"
you can add more than one entry there or more than one IP. When you enroll the router, the router PKI will get generated and it will have these values in the certificate... So you'll need to re-enroll... Hopefully that makes sense?
All right so I’ve deleted the edge router (welp i just deleted the docker volume and recreated it)
I changed some variables in the .env so it would enroll with the ip instead of the name i gave to it
│ BEarjXYt4w             │ edge-router-BEarjXYt4w-system │ @192.168.1.123    │ @192.168.1.123   │
│ gS9VdXTt4              │ edge-router-gS9VdXTt4-system  │ @publicmachine    │ @publicmachine │
results: 1-5 of 5
│ BEarjXYt4w │ 192.168.1.123   │ true   │ true          │    0 │ private    │
│ gS9VdXTt4  │ publicmachine   │ true   │ true          │    0 │ public     │
│ xEjedZYt4w │ privatemachine  │ false  │ true          │    0 │ private    │
And the config is now named 192.168.1.123.yaml
v: 3
identity:
  cert:                 "/persistent/192.168.1.123.cert"
  server_cert:          "/persistent/192.168.1.123.server.chain.cert"
  key:                  "/persistent/192.168.1.123.key"
  ca:                   "/persistent/192.168.1.123.cas"
ctrl:
  endpoint:             tls:publicmachine.mydomain.com:6262
link:
  dialers:
    - binding: transport
  listeners:
      advertise:        tls:192.168.1.123:10080
        outQueueSize:   4
listeners:
  - binding: edge
  - binding: tunnel
edge:
  csr:
    country: US
    province: NC
    locality: Charlotte
    organization: NetFoundry
    organizationalUnit: Ziti
    sans:
      dns:
        - 192.168.1.123
        - localhost
      ip:
        - "127.0.0.1"
#transport:
#  ws:
#    writeTimeout: 10
#    readTimeout: 5
#    idleTimeout: 5
#    pongTimeout: 60
#    pingInterval: 54
#    handshakeTimeout: 10
#    readBufferSize: 4096
#    writeBufferSize: 4096
#    enableCompression: true
#    server_cert: /persistent/192.168.1.123.server.chain.cert
#    key: /persistent/192.168.1.123.key
forwarder:
  latencyProbeInterval: 10
  xgressDialQueueLength: 1000
  xgressDialWorkerCount: 128
  linkDialQueueLength: 1000
  linkDialWorkerCount: 32
But im still seeing the same in the ziti fabric list circuits, while I was typing this I noticed that this section migh have an error now
link:
  dialers:
  listeners:
      advertise:        tls:192.168.1.123:10080 # <-- Here, shouldnt it be the public machine's address?
        outQueueSize:   4
Since I’m using the docker container quickstart, I think it’s getting the variables from the .env file and perhaps I’m misusing a variable. This is what I currently have
# OpenZiti Variables
ZITI_VERSION=latest
# The duration of the enrollment period (in minutes), default if not set
ZITI_EDGE_IDENTITY_ENROLLMENT_DURATION=
ZITI_EDGE_ROUTER_ENROLLMENT_DURATION=
# From gooselegs response
ZITI_EDGE_ROUTER_ROLES=private
# Credentials
ZITI_USER=admin
ZITI_PWD=mysupermegasecretpassword
# From clint's script
ZITI_EDGE_ROUTER_PORT=3022
ZITI_CONTROLLER_HOSTNAME=publicmachine.mydomain.com
ZITI_CTRL_EDGE_ADVERTISED_PORT=1280
ZITI_CTRL_LISTENER_PORT=6262
ZITI_CTRL_PORT=${ZITI_CTRL_LISTENER_PORT}
ZITI_EDGE_CONTROLLER_PORT=${ZITI_CTRL_EDGE_ADVERTISED_PORT}
ZITI_CTRL_ADVERTISED_ADDRESS=${ZITI_CONTROLLER_HOSTNAME}
ZITI_CTRL_EDGE_ADVERTISED_ADDRESS=${ZITI_CONTROLLER_HOSTNAME}
# These ones were provided because the container complained
# These two were 'privatemachine' before so i changed it to the local IP 'fix' it
ZITI_EDGE_ROUTER_HOSTNAME=192.168.1.123
ZITI_EDGE_ROUTER_RAWNAME_OVERRIDE=192.168.1.123
I think I’m missing the variable to set the hostname of the public router because right now it seems to pick up the same variable as the private router
Anyways, I feel like I’m so close! :smiley:
i am going to make a whole walkthrough video and a new gist… i found other things about the instructions/gist that I didn’t like and I want to make this simpler for you to follow. You are indeed very close, but let me try to make a new gist which will hopefully make this easier…
Sure! No problem :slight_smile: I’m now curious though to know which env variable refers to the public router address and which to the private router…
I’m going to get some sleep, I’ll read about it tomorrow, forgot to mention but thanks again for all the help :people_hugging:
Ok, hopefully this will get you what you need. Video will be at the bottom of this post.
Here are the steps shown in the video:
  1. source a file named ziti.creds in order to get ZITI_USER and ZITI_PWD in your environment variables
  2. login to the controller:
    ziti edge login https://ec2-3-134-108-218.us-east-2.compute.amazonaws.com:8441 -u $ZITI_USER -p $ZITI_PWD -y`
  3. set some environment variables – you’ll need to modify these:
    export ZITI_BIN_DIR=/home/cd/.ziti/quickstart/ziti-bin/ziti-v0.27.8/
    export PERSISTENT_DIR=$(pwd)
    export ZITI_CONTROLLER_HOSTNAME=ec2-3-134-108-218.us-east-2.compute.amazonaws.com
    export ZITI_EDGE_PORT=8441
    export ZITI_CONTROL_PLANE_PORT=8440
    export ROUTER_NAME=my-private-router
    export ROUTER_ADDRESS=docker.env
    export ROUTER_IP_OVERRIDE=1.2.3.4
    export ROUTER_DATA_PORT=23022
  4. make the directory specified above for your persistent files and cd there
    mkdir ${PERSISTENT_DIR}
    cd ${PERSISTENT_DIR}
  5. wget down the gist
    wget -N https://gist.githubusercontent.com/dovholuknf/2637742f34ec7b885ed921de9eeaf2ea/raw/9c0cb542d44dbadd59dc73b755cc766bf7b93ac7/quick-docker-compose-router.sh
  6. chmod +x the script and run it
    chmod +x ./quick-docker-compose-router.sh
  7. docker compose up the compose file!
    docker compose -f /tmp/new-router-2/docker-compose.yaml up
Video walkthrough:
I followed your steps but in the middle I noticed a couple things:
1- The router config was almost exactly the same as the one I have, but the section link → dialers → listeners was commented out in your private router’s config and it was not commented out in the config I made
2- I searched through OpenZiti’s Ziti repository and I found the script run-external-router.sh and I realized that there are 4 possible parameters to call the script with: edge, wss, fabric and, the one that’s probably most important, private
And I was running the script inside my docker-compose.yml using the edge parameter, not the private parameter, probably that’s why the config wasn’t generating properly and it wasn’t working
So without touching anything else from my .env file the final docker-compose.yml that I’m using is the following
docker-compose.yml
services:
  ziti-edge-router:
    env_file:
      - ./.env
    ports:
      - "3022:3022"
    networks:
      - ziti
    volumes:
      - ziti-fs:/persistent
    entrypoint: /bin/bash
    command: "/var/openziti/scripts/run-router-external.sh private" # <- This is the only thing I changed, changed edge to private
networks:
  ziti:
volumes:
  ziti-fs:
After running docker compose up (and after deleting old routers / volumes that weren’t working of course) and establishing a ssh connection, it seems to be working properly.
@TheLumberjack is this the expected result to the command you mentioned the other day?
│ nc2F3RcKD │ clh7m9pd71exnc1mk4y0v8x7i │ test_ssh_service │ 2TnxdeJJ3kouNQGOE2MOgc │ r/public.mydomain.com |
│ uXou3mpKD │ clh7m9pd71exnc1mk4y0v8x7i │ test_ssh_service │ 2bGRWU70uvKvDH3Mz2SPnS │ r/192.168.1.123 -> l/IjKPVAFzneryWxu5322Mq -> r/public.mydomain.com │
ziti edge list sessions 'id="clh7m9pd71exnc1mk4y0v8x7i"'
│ ID                        │ API SESSION ID            │ SERVICE NAME       │ TYPE │
│ clh7m9pd71exnc1mk4y0v8x7i │ clh7hlzz818wac1mkbhjhj7j7 │ test_ssh_service │ Dial │
results: 1-1 of 1
ziti@6654d0aa7325:/persistent$ ziti edge list api-sessions 'id="clh7hlzz818wac1mkbhjhj7j7"'
│ ID                        │ TOKEN                                │ IDENTITY NAME │
│ clh7hlzz818wac1mkbhjhj7j7 │ 0a1bcb0d-b516-4afe-aa91-ed2a1ac80007 │ my-client │
Hey great, glad you got something working! I need to brush up on my path reading.
I expected to only see r/192.168.1.123 on that path if you’re ssh’ing locally. What’s on both ends – is it a tunneler initiating ssh and a tunneler offloading toward sshd? Are you ssh’ing to something local or are you ssh’ing to something the public router can reach? I need a tiny bit better picture in my head to understand exactly. If you’re ssh’ing from local network to something ‘public router’ can reach that path can definitely make sense though. Can you give me a bit more information?
Still, that private router sure looks like it’s setup correctly now! I see the link formed and I see your client is connecting to that local router too!
Sure let me try to illustrate
I have my personal computer at home
I also have a computer that I use as a server connected to the same router as the PC
The personal computer is enrolled with a user identity, client
The private server is using the docker container ziti-host enrolled with a device identity privatemachine
In that same private server machine, I’ve also started another container, sshd server, which is listening on port 2222 on that local machine. I did this because apparently I couldn’t connect to that machine’s ssh on port 22 using OpenZiti, so I assume it’s some firewall stuff and that’s why I tried the sshd container.
The whole picture is like this
So the client sends the connection request through OpenZiti (Ziti Desktop Edge) and it should exit through the Ziti Host container in the Server to reach the SSHD Server that’s also there.
I did it like this to test because it was the simplest setup I could think of that worked, but if you think that in order to be 100% sure that this works we should try another setup (with maybe another machine) I can also try that
I was reading the forums and correct me if I’m wrong but you can use the Private Router as a Tunneler just like the Ziti Host container? Perhaps my setup is a little bit wrong then…
Hi @jruiz94,
Based on what you are showing, with the ziti-private-rotuer and ziti-host in the same docker ecosystem, the first thing that strikes me is that you don’t need the ziti-host. If it was me, I would probably just use the ziti-private-router for acessing sshd targets within docker.
Based on the nice diagram you provided, it makes sense that you wouldn’t expect to see traffic going to the public router when you were home. The traffic should flow from client to private router to sshd.
The first thing I would do, is remove that ziti host / identity. Then I would make sure the private edge router was “tunneler” enabled. Meaning -t was used when issuing ziti edge create edge-router. Then I would setup the “bind” config for sshd to be the identity of the private router.
As to ‘why’ it looks like you’re seeing the path go back through the public router, I still find that strange. I haven’t been able to try debugging the situation and the fella that is might be able to help has been under the weather. I’ll see how he’s feeling today and point him to his post and see if he has other thoughts I missed.
Cheers
Thanks for the guidance!
Yeah that's what I suspected, I'll have the ziti-host container removed and I'll have the router set in tunneler mode as you said, I'll try to figure out how to do that with the docker container or, if i can't, I'll use the github gist you provided.
Don't worry, in fact, I'm in no hurry right now and also starting tomorrow I'll be unavailable until sunday afternoon, so I won't be able to provide more details if needed.
I'll try to leave the final docker-compose.yml and .env files that I'm using for my public and private machines though, in case they help somehow.
before you go too far, just run:
ziti edge list identities 'type = "Router"'
If you see an identity, you know you already are good to go!
This is what i got
│ -2Z8CrYt4 │ 192.168.1.123   │ Router │            │ default     │
│ gS9VdXTt4 │ publicmachine...│ Router │            | default     │
So if I understood you correctly, currently I have the following entities (all of them)
│ VpJLXZYt8  │ client          │ User   │ sshd-clients   │ default     │
│ aUq.ZZTt4w │ privatemachine  │ Device │ sshd           │ default     │
│ gS9VdXTt4  │ publicmachine   │ Router │                │ default     │
You mean that I can remove the ziti-host docker container, alongside the privatemachine identity and if i put the same attributes sshd to the 192.168.1.123 Router, it will start working the same as the ziti-host? Or should I also check what you mentioned here?
I also think that I'll have to set the network type of the router container as "host" just like the ziti-host currently has, because currently the host config is mapped to 127.0.0.1, but that's a super easy fix., if you can confirm what I said on previous paragraph, I'll give it a go when I come back!
