I have a ziti overlay where I have a controller, console, edge router, edge tunnel and ZEDW. For this, I have an edge tunnel running on linux (dont think this is relevant).
I have a service pointing to the terminator on Linux, which will go through edge router. On the service (pointing to the linux edge tunnel) I have SSH and HTTP enabled. That is fine and all works. However, when I add a port to the intercept or if I have a port to the host configuration, I end up with another terminator (additional two when configuring all up). However, if I delete the service, and then recreate after I add the configs, I get one terminator for all the services (it deletes the three and then creates one). I was expecting that the terminator would be modified or replaced with an updated version as opposed to adding more. For this, I did this through the ZAC so may be different on the command line.
So, here, is the result after I added 9392 to the bind/intercept configurations
ziti@f39c5a9a35ef:/openziti$ ziti edge list terminators
│ ID │ SERVICE │ ROUTER │ BINDING │ ADDRESS │ IDENTITY │ COST │ PRECEDENCE │ DYNAMIC COST │
│ 8YXO │ ltvulscan01.svc │ zitiedgerouter.thesmithcave.nz │ edge │ hosted:9b25d875-e423-468e-8d33-8ce58110db3f │ │ 0 │ default │ 2 │
│ de4n │ ltvulscan01.svc │ zitiedgerouter.thesmithcave.nz │ edge │ hosted:909c7ea3-2d4f-48b9-ae14-0204853ccda6 │ │ 0 │ default │ 20 │
│ dl28 │ ltvulscan01.svc │ zitiedgerouter.thesmithcave.nz │ edge │ hosted:2ed6baeb-a105-4b36-b13b-3fc67a6ffd7f │ │ 0 │ default │ 2 │
ziti@f39c5a9a35ef:/openziti$ ziti edge list services
│ ID │ NAME │ ENCRYPTION │ TERMINATOR STRATEGY │ ATTRIBUTES │
│ │ │ REQUIRED │ │ │
│ av6FtKfKTW │ ltvulscan01.svc │ true │ smartrouting │ │
I cannot find the other commands I want, so here are some screenshots. Now I first came across this issue when I added port 80 alongside of port 22, so I deleted the service and re-created and then only got one terminator. So, all of this post shows what happens when I added 9392 into the Intercept/Host configs
Is this expected behaviour?
On a slight (un)related note - you can add a service name with a space ( ) at the beginning and this is allowed. I had not noticed as I was cutting/pasting. It was only when I was dumping some command line results from there that I noticed the indentation. This is on ZAC 2.3.4. I will log a bug for this.
