When I disable environment with:
!/kaggle/working/zrok/zrok disable
I get confirmation that environment is disabled:
zrok environment disabled...
But my share listener which is defined like this:
cmd = f"/kaggle/working/zrok/zrok share public http://localhost:7801 --headless"
get_ipython().system(cmd)
is not killed and is sending error messages non-stop, so I have to stop kaggle session every time to get rid of these error messages.
What am I doing wrong? Please help!
How can I terminate the zrok share process before calling zrok disable ?
This is little part of error messages which I get in the output:
[ 6.759] INFO sdk-golang/ziti.(*listenerManager).createSessionWithBackoff: {session token=[24ad73e5-cb0b-4ce6-bfca-13920c04273e]} new service session
[ 7.320] INFO main.(*sharePublicCommand).run: access your zrok share at the following endpoints:
https://9mh6g4yy83db.share.zrok.io/
[ 92.917] ERROR sdk-golang/ziti/edge/network.(*edgeListener).close: {sessionId=[24ad73e5-cb0b-4ce6-bfca-13920c04273e] error=[channel closed] connId=[3]} unable to unbind session for conn
[ 92.917] ERROR sdk-golang/ziti/edge/network.(*edgeConn).close: {connId=[3] marker=[] error=[channel closed] serviceName=[9mh6g4yy83db]} failed to close listener
[ 97.773] ERROR sdk-golang/ziti/edge/network.(*edgeConn).listen [ch{ziti-sdk[router=tls:60042e42-5eef-4378-9ade-538b5cde57a0.production.netfoundry.io:443]}->u{classic}->i{rKaEp}]: {error=[timeout waiting for message reply: context deadline exceeded] connId=[3] serviceName=[9mh6g4yy83db] sessionId=[cm5wb8s2r7g8wamqciu929a59]} failed to bind
[ 97.773] ERROR sdk-golang/ziti/edge/network.(*edgeConn).unbind [ch{ziti-sdk[router=tls:60042e42-5eef-4378-9ade-538b5cde57a0.production.netfoundry.io:443]}->u{classic}->i{rKaEp}]: {error=[channel closed] connId=[3] serviceName=[9mh6g4yy83db] sessionId=[cm5wb8s2r7g8wamqciu929a59]} unable to send unbind msg for conn
[ 97.773] ERROR sdk-golang/ziti/edge/network.(*routerConn).Listen: {error=[timeout waiting for message reply: context deadline exceeded] connId=[3] router=[AWS US-West-1-1(custom config)] serviceId=[3E9W59WNX0IvP5wDsWq9AS] serviceName=[9mh6g4yy83db]} failed to establish listener
[ 97.773] ERROR sdk-golang/ziti.(*listenerManager).createListener: {serviceName=[9mh6g4yy83db]} creating listener failed after 5001ms: timeout waiting for message reply: context deadline exceeded
[ 97.773] INFO sdk-golang/ziti/edge/network.(*multiListener).NotifyOfChildError: notify error handler of error: timeout waiting for message reply: context deadline exceeded
[ 102.929] ERROR sdk-golang/ziti/edge/network.(*edgeConn).listen [ch{ziti-sdk[router=tls:ed9935f5-5d9d-4898-a3cf-4a8a05b4e4a6.production.netfoundry.io:443]}->u{classic}->i{bwpay}]: {sessionId=[cm5wb8s2r7g8wamqciu929a59] error=[timeout waiting for message reply: context deadline exceeded] connId=[1] serviceName=[9mh6g4yy83db]} failed to bind
[ 102.929] ERROR sdk-golang/ziti/edge/network.(*routerConn).Listen: {error=[timeout waiting for message reply: context deadline exceeded] connId=[1] router=[Public OCI Singapore(custom config)] serviceId=[3E9W59WNX0IvP5wDsWq9AS] serviceName=[9mh6g4yy83db]} failed to establish listener
[ 102.930] ERROR sdk-golang/ziti.(*listenerManager).createListener: {serviceName=[9mh6g4yy83db]} creating listener failed after 5000ms: timeout waiting for message reply: context deadline exceeded
