Alternative DNS breaks tunneler connectivity
A Ziti controller configured without an alternative DNS, as per the helm chart values below, works as expected:
        clientApi:
          advertisedHost: "ziti-api.mydomain.com"
          advertisedPort: 443
          ingress:
            enabled: false
          service:
            type: ClusterIP
          traefikTcpRoute:
            enabled: true
        webBindingPki:
          enabled: false
Adding an alternative DNS name as below breaks the connection from a Linux tunneler:
        clientApi:
          advertisedPort: 443
          altDnsNames:
            - "ziti-web.mydomain.com"
          ingress:
            enabled: false
          service:
            type: ClusterIP
          traefikTcpRoute:
            enabled: true
        webBindingPki:
          enabled: true
          altServerCerts:
            - mode: certManager
              secretName: ziti-controller-trusted-cert
              altDnsNames:
              issuerRef:
                group: cert-manager.io
                kind: ClusterIssuer
              mountPath: /etc/ziti/trusted-cert
In order for the tunneler to work, I have to reconfigure it to use the alternate DNS and add the Let's Encrypt root CA to the config file. I was expecting the connection to the advertizedHost to continue working.
Here's the output of the error log:
(4011277)[        0.009]    INFO ziti-sdk:ziti.c:512 ziti_start_internal() ztx[1] enabling Ziti Context
(4011277)[        0.009]    INFO ziti-sdk:ziti.c:528 ziti_start_internal() ztx[1] using tlsuv[v1.7.12/OpenSSL 3.4.2 1 Jul 2025]
(4011277)[        0.009]    INFO ziti-sdk:ziti_ctrl.c:637 ziti_ctrl_init() ctrl[https://ziti-api.mydomain.com:443/] controller initialized
(4011277)[        0.009]    INFO ziti-sdk:ziti.c:606 ztx_init_controller() ztx[1] Loading ziti context with controller[https://ziti-api.mydomain.com:443/]
(4011277)[        0.468]   ERROR tlsuv:engine.c:868 openssl: handshake was terminated: SSL routines
(4011277)[        0.468]   ERROR tlsuv:tls_link.c:113 TLS(0x1babf120) handshake error certificate verify failed
(4011277)[        0.468]   ERROR tlsuv:http.c:192 handshake failed status[3]: certificate verify failed
(4011277)[        0.468]    WARN ziti-sdk:ziti_ctrl.c:177 ctrl_resp_cb() ctrl[https://ziti-api.mydomain.com:443/] request failed: -103(software caused connection abort)
(4011277)[        0.468]    WARN ziti-sdk:ziti_ctrl.c:336 internal_version_cb() ctrl[https://ziti-api.mydomain.com:443/] CONTROLLER_UNAVAILABLE(software caused connection abort)
(4011277)[        0.468]    WARN ziti-sdk:ziti.c:2042 version_pre_auth_cb() ztx[1] failed to get controller version: CONTROLLER_UNAVAILABLE/software caused connection abort
(4011277)[        0.468]    INFO ziti-sdk:ziti_ctrl.c:180 ctrl_resp_cb() ctrl[https://ziti-api.mydomain.com:443/] attempting to switch endpoint
(4011277)[        0.468]    WARN ziti-sdk:ziti_ctrl.c:602 ctrl_next_ep() ctrl[https://ziti-api.mydomain.com:443/] no controllers are online
(4011277)[        0.468]    WARN ziti-sdk:ziti.c:643 ext_jwt_singers_cb() ztx[1] failed to get external auth providers: software caused connection abort
(4011277)[        5.880]   ERROR tlsuv:engine.c:868 openssl: handshake was terminated: SSL routines
(4011277)[        5.880]   ERROR tlsuv:tls_link.c:113 TLS(0x1babf120) handshake error certificate verify failed
(4011277)[        5.880]   ERROR tlsuv:http.c:192 handshake failed status[3]: certificate verify failed
I'll gladly log an issue, but before I do, I want to make sure my configuration is correct.
The tunneler should continue using the same advertised host, not switch to any alternative hosts for alternative server certs, which are only for Ziti-naive clients, such as a web browser, which rely on a default OS trust store, typically.
We need to figure out why "Adding an alternative DNS name as below breaks the connection from a Linux tunneler". There should be no ambiguity during server certificate selection as long as the advertised host and alt host are distinct, e.g., ziti-api.mydomain.com and ziti-web.mydomain.com. With this example, you tunneler should always use the ziti-api name, and you could access the web console on the ziti-web name to enjoy a publicly-trusted cert with HTTPS there.
The logs show only that the tunneler is continuing to use the ziti-api name, as it should, but encounters an unspecified TLS problem, or I'm unable to recognize it from the cryptic output.
You configuration looks fine at a glance, and I've certainly used that approach myself to bind a publicly trusted cert for the web listener for the console.
Let's first ensure the ziti-api path still exists after you redeploy the controller with the alt cert config. Hopefully, we can see what is the TLS problem the tunneler encountered.
openssl s_client -connect ziti-api.mydomain.com:443 -alpn h2,http/1.1 <>/dev/null
The HTTP ALPN is used by the tunneler to request the client API's protocol because, often, there are multiple protocols available on the same TCP port. For a controller's client port, ALPN ziti-ctrl is also tyically available.
I tested successfully with these values in my dev env. It's not usually necessary to override the chart's default app version, which is tested in tandem with the chart itself. Still, I wanted to ensure the problem couldn't be reproduced in the latest Ziti release, 1.7.0. I suspect the problem is a misalignment of these tricky input values. You can use any K8s service type or ingress controller that provides TLS passthrough.
clientApi:
  advertisedHost: miniziti-controller.192.168.58.2.sslip.io
  altDnsNames:
  - miniziti-controller.minikube1.bingnet.cloud
  ingress:
    annotations:
    enabled: true
    ingressClassName: nginx
  service:
    enabled: true
    type: ClusterIP
ctrlPlane:
  ingress:
    enabled: false
  service:
    enabled: false
image:
  additionalArgs:
  - --verbose
  repository: openziti/ziti-controller
  tag: 1.7.0
webBindingPki:
  altServerCerts:
  - altDnsNames:
    issuerRef:
      kind: ClusterIssuer
    mode: certManager
    mountPath: /etc/ziti/alt-server-cert
    secretName: ziti-controller-alt-server-cert1
This seems to work:
CONNECTED(00000003)
Certificate chain
 0 s:CN=openziti-controller-web-identity
   i:CN=openziti-controller-web-intermediate
   a:PKEY: rsaEncryption, 4096 (bit); sigalg: ecdsa-with-SHA256
   v:NotBefore: Sep 23 12:18:50 2025 GMT; NotAfter: Oct  1 12:18:50 2035 GMT
 1 s:CN=openziti-controller-web-intermediate
   i:CN=openziti-controller-web-root
   a:PKEY: id-ecPublicKey, 256 (bit); sigalg: ecdsa-with-SHA256
   v:NotBefore: Sep 23 12:18:47 2025 GMT; NotAfter: Oct  1 12:18:47 2035 GMT
Server certificate
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
subject=CN=openziti-controller-web-identity
issuer=CN=openziti-controller-web-intermediate
Acceptable client certificate CA names
CN=openziti-controller-edge-signer
CN=openziti-controller-ctrl-plane-root
CN=openziti-controller-edge-root
Requested Signature Algorithms: RSA-PSS+SHA256:ECDSA+SHA256:ed25519:RSA-PSS+SHA384:RSA-PSS+SHA512:RSA+SHA256:RSA+SHA384:RSA+SHA512:ECDSA+SHA384:ECDSA+SHA512:RSA+SHA1:ECDSA+SHA1
Shared Requested Signature Algorithms: RSA-PSS+SHA256:ECDSA+SHA256:ed25519:RSA-PSS+SHA384:RSA-PSS+SHA512:RSA+SHA256:RSA+SHA384:RSA+SHA512:ECDSA+SHA384:ECDSA+SHA512
Peer signing digest: SHA256
Peer signature type: RSA-PSS
Server Temp Key: X25519, 253 bits
SSL handshake has read 2663 bytes and written 443 bytes
Verification error: unable to get local issuer certificate
New, TLSv1.3, Cipher is TLS_AES_128_GCM_SHA256
Protocol: TLSv1.3
Server public key is 4096 bit
This TLS version forbids renegotiation.
Compression: NONE
Expansion: NONE
ALPN protocol: http/1.1
Early data was not sent
Verify return code: 20 (unable to get local issuer certificate)
Post-Handshake New Session Ticket arrived:
SSL-Session:
    Protocol  : TLSv1.3
    Cipher    : TLS_AES_128_GCM_SHA256
    Session-ID: 921953DEB95579FA015D5CBE8E99DD26F0F23DC2E724870A38321122AEDE5E39
    Session-ID-ctx:
    Resumption PSK: E757D249F4F45FBAA8740691EFA815A6F340D3A5FE2F7B54B84CC5B14A2F0748
    PSK identity: None
    PSK identity hint: None
    SRP username: None
    TLS session ticket lifetime hint: 604800 (seconds)
    TLS session ticket:
    0000 - 59 ee fe 46 b5 44 c5 e8-e6 5e ad 48 b9 d1 09 0a   Y..F.D...^.H....
    0010 - 27 6e e8 d6 73 4c 11 25-b8 dc 79 9c 65 ea e5 af   'n..sL.%..y.e...
    0020 - 7b 54 4c a2 8e 66 31 87-ad e6 1c bc 55 ba 6c 88   {TL..f1.....U.l.
    0030 - 11 31 63 13 a5 f9 c1 5b-81 bc f4 f2 e0 63 38 4e   .1c....[.....c8N
    0040 - 4c d4 b9 43 fa a6 b0 27-cc 60 bb 73 5c 1d e1 e1   L..C...'.`.s\...
    0050 - f9 3e fb f2 d0 5e a2 28-86 40 ca 82 27 59 db b3   .>...^.(.@..'Y..
    0060 - 3f 9d f0 50 6c fb 8e 11-f0                        ?..Pl....
    Start Time: 1760701570
    Timeout   : 7200 (sec)
    Extended master secret: no
    Max Early Data: 0
read R BLOCK
closed
I modified the chart values to match what you shared:
clientApi:
  advertisedPort: 443
  altDnsNames:
  ingress:
    enabled: false
  service:
    type: ClusterIP
  traefikTcpRoute:
    enabled: true
ctrlPlane:
  ingress:
    enabled: false
  service:
    enabled: false
image:
  additionalArgs:
    - --verbose
  tag: 1.7.0
webBindingPki:
  enabled: true
  altServerCerts:
    - mode: certManager
      altDnsNames:
      issuerRef:
        kind: ClusterIssuer
Unfortunately, I still get the same result. The controller logs show:
{"_context":"tls:0.0.0.0:1280","client":{"IP":"10.42.3.45","Port":42008,"Zone":""},"file":"github.com/openziti/transport/v2@v2.0.198/tls/listener.go:303","func":"github.com/openziti/transport/v2/tls.(*sharedListener).getConfig","level":"debug","msg":"client requesting protocols = [http/1.1]","time":"2025-10-17T12:16:24.560Z"}
{"_context":"tls:0.0.0.0:1280","client":{"IP":"10.42.3.45","Port":42008,"Zone":""},"file":"github.com/openziti/transport/v2@v2.0.198/tls/listener.go:326","func":"github.com/openziti/transport/v2/tls.(*sharedListener).getConfig","level":"debug","msg":"found handler for proto[]","time":"2025-10-17T12:16:24.560Z"}
{"_context":"tls:0.0.0.0:1280","error":"local error: tls: bad record MAC","file":"github.com/openziti/transport/v2@v2.0.198/tls/listener.go:260","func":"github.com/openziti/transport/v2/tls.(*sharedListener).processConn","level":"error","msg":"handshake failed","remote":"10.42.3.45:42008","time":"2025-10-17T12:16:24.765Z"}
The traefik ingressroute tcp is created with TLS passthrough:
apiVersion: v1
items:
- apiVersion: traefik.io/v1alpha1
  kind: IngressRouteTCP
  metadata:
    annotations:
      kubectl.kubernetes.io/last-applied-configuration: |
        {"apiVersion":"traefik.io/v1alpha1","kind":"IngressRouteTCP","metadata":{"annotations":{},"labels":{"argocd.argoproj.io/instance":"ziti-controller"},"name":"openziti-controller","namespace":"openziti"},"spec":{"entryPoints":["websecure"],"routes":[{"match":"HostSNI(`ziti-api.mydomain.com`)","services":[{"name":"openziti-controller-client","port":443}]}],"tls":{"passthrough":true}}}
    creationTimestamp: "2025-09-23T12:18:36Z"
    generation: 10
    labels:
      argocd.argoproj.io/instance: ziti-controller
    namespace: openziti
    resourceVersion: "270592960"
    uid: d091b0bf-62e0-4808-b27f-3a75251ae60c
  spec:
    entryPoints:
    - websecure
    routes:
    - match: HostSNI(`ziti-api.mydomain.com`)
      services:
      - name: openziti-controller-client
        port: 443
    tls:
      passthrough: true
  "_context": "tls:0.0.0.0:1280",
  "error": "local error: tls: bad record MAC",
  "file": "github.com/openziti/transport/v2@v2.0.198/tls/listener.go:260",
  "func": "github.com/openziti/transport/v2/tls.(*sharedListener).processConn",
  "level": "error",
  "msg": "handshake failed",
  "remote": "10.42.3.45:42008",
  "time": "2025-10-17T12:16:24.765Z"
I think this points toward Traefik terminating TLS, not passing it through to the controller pod.
It seems this error is a red herring and appears with and without an alternative DNS:
  "error": "remote error: tls: unknown certificate authority",
  "level": "error",
  "remote": "10.42.2.105:49350",
  "time": "2025-11-28T06:56:17.993Z"
If traefik was terminating TLS, I would expect to see the default traefik cert, but I'm seeing the same cert with and without alternative DNS:
> openssl s_client -connect zitictl.mycity.co.za:443 -showcerts
CONNECTED(00000003)
depth=1 CN=openziti-controller-ctrl-plane-intermediate
verify error:num=20:unable to get local issuer certificate
verify return:1
depth=0 CN=openziti-controller-ctrl-plane-identity
verify return:1
I tried this in a new cluster with a new tunneler and got the same results. The moment I add the alternative DNS, it breaks. Once I revert, it works again.
It's not a high-priority issue for me, and it's more a matter of convenience. I'm leaning toward adding the controller CA to all hosts and providing users with instructions on how to add it to their OS. I don't like that we're adding more security to the network, yet users are suddenly seeing security warnings in their browsers.
We're solving for "Adding an alternative DNS name as below breaks the connection from a Linux tunneler" in an attempt to bind an alternative server cert issued by a publicly-trusted CA like LE to the Ziti controller's web TLS listener where edge-management is bound so that users can access the included web console in a regular web browser.
For some reason, configuring the alt_server_cert identity property on the controller is both:
  1. causing the ZET connection to break,
  2. not causing the new LE certificate to be presented for the alt DNS name, e.g., "ziti-web.mydomain.com"
Is that accurate?
Things to check:
  1. Traefik passes through TLS for both server names to the same Ziti controller pod port: ziti-web.mydomain.com, ziti-api.mydomain.com
  2. Both identity.server_cert and identity.alt_server_cert have distinctive DNS SANs matching your desired servername routes in Traefik
  3. The controller is not complaining about any web TLS bindings
I found this thread while searching for issues looking a lot like this issue, and disabling alt DNS did fix it (though I don’t know why).
The big difference in this case is that my alt DNS is only on the management API port (I’m using the helm chart and have the management API split off to a separate subdomain), so there’s no extra PKI being generated for the clientApi part.
eg:
  • clientApi points to ctrl0.ziti.mydomain.net
  • managementApi is at mgmt.ziti.mydomain.net
  • alt DNS for management for web ZAC purposes is at web.ziti.mydomain.net
Seeing this thread and turning off web.ziti.mydomain.net by removing the altDnsNames field and removing the webBindingPki section appears to have made the issue go away.
