Android client stopped to authenticate "subject_token is invalid"
Yesterday, while I was using it on my phone, I lost the connection to my network.
Now my android Client is unable to authenticate.
The controller is up and the other tunnelers work just fine.
on the controller I can see
Oct 31 11:32:57 homeoverlay ziti[951]: 2025/10/31 11:32:57 WARN request error oidc_error.description="subject_token is invalid" oidc_error.type=invalid_request
I tried to reenroll the identity. From ZAC the identity seems enrolled, but no difference on my phone.
I just sent a debug email to developpers from my phone.
we are looking into OIDC auth issues. for now can you try turning of OIDC auth support in the controller? comment out edge-oidc binding block
Are you by chance using the identity configuration settings under web in your controller?
Example (See the “this section” comment in the YAML)
web:
  - name: all-apis-localhost
    bindPoints:
      - interface: 127.0.0.1:1280
        address: 127.0.0.1:1280
        # this section
        identity:
          cert:                 /some/path/to/some/cert.pem
          server_cert:          /some/path/to/some/cert.pem
          key:                  /some/path/to/some/key.pem
          ca:                   /some/path/to/some/cas.pem
    apis:
      - binding: health-checks
      - binding: fabric
      - binding: edge-management
      - binding: edge-client
      - binding: edge-oidc
my conf is
web:
bindPoints:
interface: 0.0.0.0:443
address: ziti.my.domain:443
identity:
ca:          "edge-controller-root-ca.cert"
key:         "server.key"
server_cert: "server.chain.pem"
cert:        "client.chain.pem"
readTimeout: 5000ms
writeTimeout: 100000ms
minTLSVersion: TLS1.2
maxTLSVersion: TLS1.3
apis:
options: { }
binding: edge-oidc
options: { }
Management is in another section with zac
I tried to comment edge-oidc binding with no success: android is still stuck on initial
Do you mind sharing the root identity section? It is normally the first stanza in the config file.
Openziti has been configured with the quickstart on February and has been working fine since then.
Yesterday I was using some service with my phone while a was on a train. I lost data connection in a tunnel and I was not able to connect any more. I switched to VPN connection without looking at the app. Since today, when I found I was unauthanticated.
Every other client is still working fine.
I cleared android storage and enrolled a new identity without success.
ziti binay is ziti-1.6.7
my conf is
v: 3
db:                     "/home/ziti/.ziti/quickstart/homeoverlay/db/ctrl.db"
identity:
  cert:        "/home/ziti/.ziti/quickstart/homeoverlay/pki/ziti.my.domain-intermediate/certs/ziti.my.domain-client.chain.pem"
  server_cert: "/home/ziti/.ziti/quickstart/homeoverlay/pki/ziti.my.domain-intermediate/certs/ziti.my.domain-server.chain.pem"
  key:         "/home/ziti/.ziti/quickstart/homeoverlay/pki/ziti.my.domain-intermediate/keys/ziti.my.domain-server.key"
  ca:          "/home/ziti/.ziti/quickstart/homeoverlay/pki/cas.pem"
ctrl:
    advertiseAddress: tls:ziti.my.domain:8440
  listener:             tls:0.0.0.0:8440
healthChecks:
  boltCheck:
    interval: 30s
    timeout: 20s
    initialDelay: 30s
edge:
  api:
    sessionTimeout: 30m
  enrollment:
    signingCert:
      cert: /home/ziti/.ziti/quickstart/homeoverlay/pki/signing.pem
      key:  /home/ziti/.ziti/quickstart/homeoverlay/pki/homeoverlay-signing-intermediate/keys/homeoverlay-signing-intermediate.key
    edgeIdentity:
      duration: 180m
    edgeRouter:
      duration: 180m
web:
  - name: client
    bindPoints:
      - interface: 0.0.0.0:443
    identity:
      ca:          "/home/ziti/.ziti/quickstart/homeoverlay/pki/homeoverlay-edge-controller-root-ca/certs/homeoverlay-edge-controller-root-ca.cert"
      key:         "/home/ziti/.ziti/quickstart/homeoverlay/pki/homeoverlay-edge-controller-intermediate/keys/ziti.my.domain-server.key"
      server_cert: "/home/ziti/.ziti/quickstart/homeoverlay/pki/homeoverlay-edge-controller-intermediate/certs/ziti.my.domain-server.chain.pem"
      cert:        "/home/ziti/.ziti/quickstart/homeoverlay/pki/homeoverlay-edge-controller-intermediate/certs/ziti.my.domain-client.chain.pem"
      readTimeout: 5000ms
    apis:
        options: { }
        options: { }
  - name: management
    bindPoints:
      - interface: 0.0.0.0:18441
        address: 127.0.0.1:18441
    identity:
      readTimeout: 5000ms
    apis:
        options: { }
      - binding: fabric
        options: { }
        options: { }
      - binding: zac
          indexFile: index.html
client log
10-31 22:21:10.434 31012  5089 E ziti-sdk:ziti.c:1560 update_identity_data(): ztx[2] failed to get identity_data: The request could not be completed. The session is not authorized or the credentials are invalid[UNAUTHORIZED]
10-31 22:21:10.434 31012  5089 W ziti-sdk:ziti.c:1562 update_identity_data(): ztx[2] api session is no longer valid. Trying to re-auth
10-31 22:21:10.434 31012  5089 W ziti-sdk:ziti.c:223 ziti_set_unauthenticated(): ztx[2] auth error: The request could not be completed. The session is not authorized or the credentials are invalid
10-31 22:21:10.434 31012  5089 D ziti-sdk:ziti.c:226 ziti_set_unauthenticated(): ztx[2] setting auth_state[0] to 0
10-31 22:21:10.434 31012  5089 D ziti-sdk:ziti_ctrl.c:380 ziti_ctrl_clear_auth(): ctrl[https://ziti.my.domain:443] clearing api session token for ziti_controller
10-31 22:21:10.434 31012  5089 W tunnel-cbs:ziti_tunnel_ctrl.c:1018 on_ziti_event(): ziti_ctx controller connections failed: failed to authenticate
10-31 22:21:10.435 31012  5089 I Tunnel  : event: {"identifier":"mBlld39v8e","type":"ContextEvent","status":"failed to authenticate","code":-14}
10-31 22:21:10.435 31012  5089 D ziti-sdk:ziti.c:444 ziti_force_api_session_refresh(): ztx[2] forcing session refresh
10-31 22:21:10.435 31012  5089 D ziti-sdk:oidc.c:967 refresh_time_cb(): oidc[internal] refreshing OIDC token
10-31 22:21:10.436 31012 31012 D model   : received event[ContextEvent(identifier=mBlld39v8e, status=failed to authenticate, name=null, controller=null)]
10-31 22:21:10.446 31012  5089 D ziti-sdk:ziti_ctrl.c:500 ctrl_body_cb(): ctrl[https://ziti.my.domain:443] completed paging request GET[/current-identity/edge-routers] in 0.145 s
10-31 22:21:10.446 31012  5089 E ziti-sdk:ziti_ctrl.c:527 ctrl_body_cb(): ctrl[https://ziti.my.domain:443] API request[/current-identity/edge-routers?limit=25&offset=0] failed code[UNAUTHORIZED] message[The request could not be completed. The session is not authorized or the credentials are invalid]
10-31 22:21:10.447 31012  5089 E ziti-sdk:ziti.c:1484 edge_routers_cb(): ztx[2] failed to get current edge routers: code[401] UNAUTHORIZED/The request could not be completed. The session is not authorized or the credentials are invalid
10-31 22:21:10.500 31012  5089 D ziti-sdk:ziti_ctrl.c:505 ctrl_body_cb(): ctrl[https://ziti.my.domain:443] completed GET[/current-api-session/service-updates] in 0.198 s
10-31 22:21:10.500 31012  5089 E ziti-sdk:ziti_ctrl.c:527 ctrl_body_cb(): ctrl[https://ziti.my.domain:443] API request[/current-api-session/service-updates] failed code[UNAUTHORIZED] message[The request could not be completed. The session is not authorized or the credentials are invalid]
10-31 22:21:10.501 31012  5089 W ziti-sdk:ziti.c:1432 check_service_update(): ztx[2] failed to poll service updates: code[401] err[-14/The request could not be completed. The session is not authorized or the credentials are invalid]
10-31 22:21:10.520 31012  5089 D ziti-sdk:oidc.c:936 refresh_cb(): oidc[internal] token refresh success
10-31 22:21:10.520 31012  5089 E ziti-sdk:oidc.c:914 oidc_client_set_tokens(): oidc[internal] access_token was not provided by IdP
10-31 22:21:10.520 31012  5089 W ziti-sdk:ziti.c:223 ziti_set_unauthenticated(): ztx[2] auth error: failed to auth: 4
10-31 22:21:10.520 31012  5089 D ziti-sdk:ziti.c:226 ziti_set_unauthenticated(): ztx[2] setting auth_state[0] to 0
10-31 22:21:10.521 31012  5089 D ziti-sdk:ziti_ctrl.c:380 ziti_ctrl_clear_auth(): ctrl[https://ziti.my.domain:443] clearing api session token for ziti_controller
10-31 22:21:10.521 31012  5089 W tunnel-cbs:ziti_tunnel_ctrl.c:1018 on_ziti_event(): ziti_ctx controller connections failed: unexpected error
10-31 22:21:10.521 31012  5089 I Tunnel  : event: {"identifier":"mBlld39v8e","type":"ContextEvent","status":"unexpected error","code":4}
10-31 22:21:10.523 31012 31012 D model   : received event[ContextEvent(identifier=mBlld39v8e, status=unexpected error, name=null, controller=null)]
10-31 22:21:10.539 31012  5089 D ziti-sdk:oidc.c:936 refresh_cb(): oidc[internal] token refresh success
10-31 22:21:10.539 31012  5089 E ziti-sdk:oidc.c:914 oidc_client_set_tokens(): oidc[internal] access_token was not provided by IdP
10-31 22:21:10.539 31012  5089 W ziti-sdk:ziti.c:223 ziti_set_unauthenticated(): ztx[2] auth error: failed to auth: 4
10-31 22:21:10.539 31012  5089 D ziti-sdk:ziti.c:226 ziti_set_unauthenticated(): ztx[2] setting auth_state[0] to 0
10-31 22:21:10.539 31012  5089 D ziti-sdk:ziti_ctrl.c:380 ziti_ctrl_clear_auth(): ctrl[https://ziti.my.domain:443] clearing api session token for ziti_controller
10-31 22:21:10.539 31012  5089 W tunnel-cbs:ziti_tunnel_ctrl.c:1018 on_ziti_event(): ziti_ctx controller connections failed: unexpected error
10-31 22:21:10.540 31012  5089 I Tunnel  : event: {"identifier":"mBlld39v8e","type":"ContextEvent","status":"unexpected error","code":4}
10-31 22:21:10.541 31012 31012 D model   : received event[ContextEvent(identifier=mBlld39v8e, status=unexpected error, name=null, controller=null)]
10-31 22:21:30.313 31012  5089 D ziti-sdk:posture.c:192 ziti_send_posture_data(): ztx[2] api_session is partially authenticated, can't submit posture responses
10-31 22:21:50.351 31012  5089 D ziti-sdk:posture.c:192 ziti_send_posture_data(): ztx[2] api_session is partially authenticated, can't submit posture responses
10-31 22:26:02.004 31012 31012 I ZitiVPNService: onCreate()
10-31 22:26:02.008 31012  5108 I ZitiVPNService: network available: 110, caps:[ Transports: WIFI Capabilities: NOT_METERED&INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN&VALIDATED&NOT_ROAMING&FOREGROUND&NOT_CONGESTED&NOT_SUSPENDED LinkUpBandwidth>=321960Kbps LinkDnBandwidth>=338906Kbps SignalStrength: -59 AdministratorUids: [] RequestorUid: -1 RequestorPackageName: null]
10-31 22:26:02.008 31012  5108 I ZitiVPNService: active[110]
10-31 22:26:02.008 31012  5108 I ZitiVPNService: link change[110], active[110]
10-31 22:26:02.008 31012  5108 I ZitiVPNService: link[110] addresses: [/192.168.4.11, /xxxx:xxxx:xxxx:xxxx:e0e6:77b5:e864:8300, /xxxx:xxxx:xxxx:xxxx:e8f2:76f6:e994:2c62]
10-31 22:26:02.009 31012  5108 I ZitiVPNService: link[110] nameservers: [/192.168.4.250]
10-31 22:26:02.009 31012  5108 I ZitiVPNService: set upstream DNS[[192.168.4.250]]
10-31 22:26:02.009 31012  5108 D Tunnel  : cmd[122] = SetUpstreamDNS:[{"host":"192.168.4.250"}]
10-31 22:26:02.009 31012  5089 I tunnel-cbs:ziti_dns.c:273 ziti_dns_set_upstream(): DNS upstream[1] is set to 192.168.4.250:53
10-31 22:26:02.009 31012  5089 I Tunnel  : resp = {"Success":true,"Code":0}
10-31 22:26:02.009 31012  5089 D Tunnel  : result[122] = SetUpstreamDNS:TunnelResult(success=true, code=0, error=null, data=null)
10-31 22:26:02.011 31012 13498 I ZitiVPNService: command monitor started
10-31 22:26:02.011 31012 13498 I ZitiVPNService: received cmd[stop]
10-31 22:26:02.011 31012 13498 I ZitiVPNService: tunnel stop success
10-31 22:26:02.011 31012 13498 I ZitiVPNService: monitoring route updates
10-31 22:26:06.470 31012  5089 D ziti-sdk:posture.c:192 ziti_send_posture_data(): ztx[2] api_session is partially authenticated, can't submit posture responses
10-31 22:26:11.592 31012 31012 I ZitiVPNService: onDestroy
10-31 22:26:11.594 31012 13498 I ZitiVPNService: stopped route updates
10-31 22:26:16.679 31012  5078 W openziti.mobil: Reducing the number of considered missed Gc histogram windows from 120 to 100
10-31 22:26:16.682 31012  5080 W System  : A resource failed to call dispose.
10-31 22:26:26.414 31012  5089 W ziti-sdk:ziti_ctrl.c:817 verify_api_session(): ctrl[https://ziti.my.domain:443] no API session
10-31 22:26:26.415 31012  5089 E ziti-sdk:ziti.c:1560 update_identity_data(): ztx[2] failed to get identity_data: no api session token set for ziti_controller[UNAUTHORIZED]
10-31 22:26:26.415 31012  5089 W ziti-sdk:ziti.c:1562 update_identity_data(): ztx[2] api session is no longer valid. Trying to re-auth
10-31 22:26:26.415 31012  5089 W ziti-sdk:ziti.c:223 ziti_set_unauthenticated(): ztx[2] auth error: no api session token set for ziti_controller
10-31 22:26:26.415 31012  5089 D ziti-sdk:ziti.c:226 ziti_set_unauthenticated(): ztx[2] setting auth_state[0] to 0
10-31 22:26:26.415 31012  5089 D ziti-sdk:ziti_ctrl.c:380 ziti_ctrl_clear_auth(): ctrl[https://ziti.my.domain:443] clearing api session token for ziti_controller
10-31 22:26:26.416 31012  5089 W tunnel-cbs:ziti_tunnel_ctrl.c:1018 on_ziti_event(): ziti_ctx controller connections failed: failed to authenticate
10-31 22:26:26.416 31012  5089 I Tunnel  : event: {"identifier":"mBlld39v8e","type":"ContextEvent","status":"failed to authenticate","code":-14}
10-31 22:26:26.417 31012  5089 D ziti-sdk:ziti.c:444 ziti_force_api_session_refresh(): ztx[2] forcing session refresh
10-31 22:26:26.417 31012  5089 W ziti-sdk:ziti_ctrl.c:817 verify_api_session(): ctrl[https://ziti.my.domain:443] no API session
10-31 22:26:26.418 31012  5089 E ziti-sdk:ziti.c:1484 edge_routers_cb(): ztx[2] failed to get current edge routers: code[0] UNAUTHORIZED/no api session token set for ziti_controller
10-31 22:26:26.418 31012  5089 W ziti-sdk:ziti_ctrl.c:817 verify_api_session(): ctrl[https://ziti.my.domain:443] no API session
10-31 22:26:26.418 31012  5089 W ziti-sdk:ziti.c:1432 check_service_update(): ztx[2] failed to poll service updates: code[0] err[-14/no api session token set for ziti_controller]
10-31 22:26:26.418 31012  5089 D ziti-sdk:oidc.c:967 refresh_time_cb(): oidc[internal] refreshing OIDC token
10-31 22:26:26.418 31012  5089 D ziti-sdk:oidc.c:971 refresh_time_cb(): oidc[internal] must restart authentication flow: no refresh_token
10-31 22:26:26.418 31012  5089 D ziti-sdk:oidc_auth.c:161 token_cb(): restarting internal OIDC flow
10-31 22:26:26.419 31012  5089 D ziti-sdk:oidc.c:731 oidc_client_start(): oidc[internal] requesting authentication code from auth_url[https://ziti.my.domain:443/oidc/authorize]
10-31 22:26:26.478 31012  5089 D ziti-sdk:posture.c:192 ziti_send_posture_data(): ztx[2] api_session is partially authenticated, can't submit posture responses
10-31 22:26:26.575 31012  5089 D ziti-sdk:oidc.c:413 auth_cb(): oidc[internal] 302 Found err[(null)] body=null
10-31 22:26:26.576 31012  5089 D ziti-sdk:oidc.c:427 auth_cb(): oidc[internal] login with path[/oidc/login/cert?id=82f366da-123e-4d40-8dd4-ccbb64c0043e]
10-31 22:26:26.638 31012  5089 D ziti-sdk:oidc.c:358 login_cb(): oidc[internal] 302 login[(null)] body = null
10-31 22:26:26.649 31012  5089 I ziti-sdk:oidc.c:325 request_token(): requesting token path[https://ziti.my.domain:443/oidc/oauth/token] auth[DNCUrLBSvZ6rmA1HZPweDFfGPXUJe2JDz66NiXJgC8Ap5NZoMGF6p8gLKT3mv3Ywx4SUiA&state=I0SdUY4X26_9LG_hVvhjo-Z3XX0aKpOiUyjHk_n7]
10-31 22:26:26.733 31012  5089 D ziti-sdk:oidc.c:309 token_cb(): oidc[internal] 200 OK err[(null)]
10-31 22:26:26.733 31012  5089 D ziti-sdk:oidc.c:911 oidc_client_set_tokens(): oidc[internal] using access_token={"aud":["openziti"],"client_id":"openziti","exp":1761947787,"iat":1761945987,"iss":"https://ziti.my.domain:443/oidc","jti":"bc8492b5-2fc8-4680-b957-a5eb9262d84c","nbf":1761945987,"scopes":["openid","offline_access"],"sub":"mBlld39v8e","z_aid":"openziti","z_asid":"f222fc1e-f8c4-4c3d-8d2c-b51ad608af28","z_authid":"kzB5aOwv5","z_cer":false,"z_cfs":["7b81a15a9f5f8334999e79af450eaf01155e9275","3141b96844426efb84b4547f053443eae1e3cec3","836ae39f97e9628d877149315b5a2a8d47b575b8"],"z_ckrr":false,"z_env":{"arch":"aarch64","domain":"localdomain","hostname":"localhost","os":"Android","osRelease":"11","osVersion":"2022-10-05"},"z_iccc":false,"z_ice":true,"z_ra":"185.242.182.33:7850","z_sdk":{"appId":"org.openziti.mobile","appVersion":"v0.18.0","branch":"HEAD","revision":"ge4d8dc7","type":"ziti-sdk-c","version":"1.9.10"},"z_t":"a"}
10-31 22:26:26.733 31012  5089 D ziti-sdk:ziti.c:384 ziti_set_fully_authenticated(): ztx[2] setting auth_state[0] to 3
10-31 22:26:26.733 31012  5089 D ziti-sdk:ziti_ctrl.c:380 ziti_ctrl_clear_auth(): ctrl[https://ziti.my.domain:443] clearing api session token for ziti_controller
10-31 22:26:26.734 31012  5089 D ziti-sdk:ziti_ctrl.c:1108 ctrl_paging_req(): ctrl[https://ziti.my.domain:443] starting paging request GET[/controllers]
10-31 22:26:26.734 31012  5089 D ziti-sdk:oidc.c:928 oidc_client_set_tokens(): oidc[internal] scheduling token refresh in 1769 seconds
10-31 22:26:26.736 31012  5089 D ziti-sdk:ziti_ctrl.c:1108 ctrl_paging_req(): ctrl[https://ziti.my.domain:443] starting paging request GET[/current-identity/edge-routers]
10-31 22:26:26.736 31012  5089 D ziti-sdk:posture.c:213 ziti_send_posture_data(): ztx[2] posture checks must_send set to TRUE, new_session_id[TRUE], must_send_every_time[TRUE], new_controller_instance[FALSE]
10-31 22:26:26.841 31012  5089 D ziti-sdk:ziti_ctrl.c:500 ctrl_body_cb(): ctrl[https://ziti.my.domain:443] completed paging request GET[/controllers] in 0.107 s
10-31 22:26:26.841 31012  5089 E ziti-sdk:ziti_ctrl.c:527 ctrl_body_cb(): ctrl[https://ziti.my.domain:443] API request[/controllers?limit=25&offset=0] failed code[UNAUTHORIZED] message[The request could not be completed. The session is not authorized or the credentials are invalid]
10-31 22:26:26.841 31012  5089 W ziti-sdk:ziti.c:333 ctrl_list_cb(): ztx[2] failed to list HA controllers UNAUTHORIZED/The request could not be completed. The session is not authorized or the credentials are invalid
10-31 22:26:26.863 31012  5089 D ziti-sdk:ziti_ctrl.c:505 ctrl_body_cb(): ctrl[https://ziti.my.domain:443] completed GET[/current-api-session] in 0.129 s
10-31 22:26:26.863 31012  5089 E ziti-sdk:ziti_ctrl.c:527 ctrl_body_cb(): ctrl[https://ziti.my.domain:443] API request[/current-api-session] failed code[UNAUTHORIZED] message[The request could not be completed. The session is not authorized or the credentials are invalid]
10-31 22:26:26.863 31012  5089 E ziti-sdk:ziti_ctrl.c:389 ctrl_login_cb(): ctrl[https://ziti.my.domain:443] UNAUTHORIZED(The request could not be completed. The session is not authorized or the credentials are invalid)
10-31 22:26:26.863 31012  5089 D ziti-sdk:ziti_ctrl.c:380 ziti_ctrl_clear_auth(): ctrl[https://ziti.my.domain:443] clearing api session token for ziti_controller
10-31 22:26:26.872 31012  5089 D ziti-sdk:ziti_ctrl.c:505 ctrl_body_cb(): ctrl[https://ziti.my.domain:443] completed GET[/current-identity] in 0.138 s
10-31 22:26:26.873 31012  5089 E ziti-sdk:ziti_ctrl.c:527 ctrl_body_cb(): ctrl[https://ziti.my.domain:443] API request[/current-identity] failed code[UNAUTHORIZED] message[The request could not be completed. The session is not authorized or the credentials are invalid]
10-31 22:26:26.873 31012  5089 E ziti-sdk:ziti.c:1560 update_identity_data(): ztx[2] failed to get identity_data: The request could not be completed. The session is not authorized or the credentials are invalid[UNAUTHORIZED]
10-31 22:26:26.873 31012  5089 W ziti-sdk:ziti.c:1562 update_identity_data(): ztx[2] api session is no longer valid. Trying to re-auth
10-31 22:26:26.873 31012  5089 W ziti-sdk:ziti.c:223 ziti_set_unauthenticated(): ztx[2] auth error: The request could not be completed. The session is not authorized or the credentials are invalid
10-31 22:26:26.873 31012  5089 D ziti-sdk:ziti.c:226 ziti_set_unauthenticated(): ztx[2] setting auth_state[3] to 0
10-31 22:26:26.873 31012  5089 D ziti-sdk:ziti_ctrl.c:380 ziti_ctrl_clear_auth(): ctrl[https://ziti.my.domain:443] clearing api session token for ziti_controller
10-31 22:26:26.873 31012  5089 W tunnel-cbs:ziti_tunnel_ctrl.c:1018 on_ziti_event(): ziti_ctx controller connections failed: failed to authenticate
10-31 22:26:26.873 31012  5089 I Tunnel  : event: {"identifier":"mBlld39v8e","type":"ContextEvent","status":"failed to authenticate","code":-14}
10-31 22:26:26.873 31012  5089 D ziti-sdk:ziti.c:444 ziti_force_api_session_refresh(): ztx[2] forcing session refresh
10-31 22:26:26.873 31012  5089 D ziti-sdk:oidc.c:967 refresh_time_cb(): oidc[internal] refreshing OIDC token
10-31 22:26:26.884 31012  5089 D ziti-sdk:ziti_ctrl.c:505 ctrl_body_cb(): ctrl[https://ziti.my.domain:443] completed GET[/current-identity] in 0.148 s
10-31 22:26:26.884 31012  5089 E ziti-sdk:ziti_ctrl.c:527 ctrl_body_cb(): ctrl[https://ziti.my.domain:443] API request[/current-identity] failed code[UNAUTHORIZED] message[The request could not be completed. The session is not authorized or the credentials are invalid]
10-31 22:26:26.884 31012  5089 E ziti-sdk:ziti.c:1560 update_identity_data(): ztx[2] failed to get identity_data: The request could not be completed. The session is not authorized or the credentials are invalid[UNAUTHORIZED]
10-31 22:26:26.884 31012  5089 W ziti-sdk:ziti.c:1562 update_identity_data(): ztx[2] api session is no longer valid. Trying to re-auth
10-31 22:26:26.884 31012  5089 W ziti-sdk:ziti.c:223 ziti_set_unauthenticated(): ztx[2] auth error: The request could not be completed. The session is not authorized or the credentials are invalid
10-31 22:26:26.884 31012  5089 D ziti-sdk:ziti.c:226 ziti_set_unauthenticated(): ztx[2] setting auth_state[0] to 0
10-31 22:26:26.884 31012  5089 D ziti-sdk:ziti_ctrl.c:380 ziti_ctrl_clear_auth(): ctrl[https://ziti.my.domain:443] clearing api session token for ziti_controller
10-31 22:26:26.884 31012  5089 W tunnel-cbs:ziti_tunnel_ctrl.c:1018 on_ziti_event(): ziti_ctx controller connections failed: failed to authenticate
10-31 22:26:26.885 31012  5089 I Tunnel  : event: {"identifier":"mBlld39v8e","type":"ContextEvent","status":"failed to authenticate","code":-14}
10-31 22:26:26.885 31012  5089 D ziti-sdk:ziti.c:444 ziti_force_api_session_refresh(): ztx[2] forcing session refresh
10-31 22:26:26.885 31012  5089 D ziti-sdk:oidc.c:967 refresh_time_cb(): oidc[internal] refreshing OIDC token
10-31 22:26:26.906 31012  5089 D ziti-sdk:ziti_ctrl.c:500 ctrl_body_cb(): ctrl[https://ziti.my.domain:443] completed paging request GET[/current-identity/edge-routers] in 0.169 s
10-31 22:26:26.906 31012  5089 E ziti-sdk:ziti_ctrl.c:527 ctrl_body_cb(): ctrl[https://ziti.my.domain:443] API request[/current-identity/edge-routers?limit=25&offset=0] failed code[UNAUTHORIZED] message[The request could not be completed. The session is not authorized or the credentials are invalid]
10-31 22:26:26.906 31012  5089 E ziti-sdk:ziti.c:1484 edge_routers_cb(): ztx[2] failed to get current edge routers: code[401] UNAUTHORIZED/The request could not be completed. The session is not authorized or the credentials are invalid
10-31 22:26:26.945 31012  5089 D ziti-sdk:ziti_ctrl.c:505 ctrl_body_cb(): ctrl[https://ziti.my.domain:443] completed GET[/current-api-session/service-updates] in 0.209 s
10-31 22:26:26.945 31012  5089 E ziti-sdk:ziti_ctrl.c:527 ctrl_body_cb(): ctrl[https://ziti.my.domain:443] API request[/current-api-session/service-updates] failed code[UNAUTHORIZED] message[The request could not be completed. The session is not authorized or the credentials are invalid]
10-31 22:26:26.945 31012  5089 W ziti-sdk:ziti.c:1432 check_service_update(): ztx[2] failed to poll service updates: code[401] err[-14/The request could not be completed. The session is not authorized or the credentials are invalid]
10-31 22:26:26.963 31012  5089 D ziti-sdk:oidc.c:936 refresh_cb(): oidc[internal] token refresh success
10-31 22:26:26.963 31012  5089 E ziti-sdk:oidc.c:914 oidc_client_set_tokens(): oidc[internal] access_token was not provided by IdP
10-31 22:26:26.963 31012  5089 W ziti-sdk:ziti.c:223 ziti_set_unauthenticated(): ztx[2] auth error: failed to auth: 4
10-31 22:26:26.963 31012  5089 D ziti-sdk:ziti.c:226 ziti_set_unauthenticated(): ztx[2] setting auth_state[0] to 0
10-31 22:26:26.963 31012  5089 D ziti-sdk:ziti_ctrl.c:380 ziti_ctrl_clear_auth(): ctrl[https://ziti.my.domain:443] clearing api session token for ziti_controller
10-31 22:26:26.963 31012  5089 W tunnel-cbs:ziti_tunnel_ctrl.c:1018 on_ziti_event(): ziti_ctx controller connections failed: unexpected error
10-31 22:26:26.963 31012  5089 I Tunnel  : event: {"identifier":"mBlld39v8e","type":"ContextEvent","status":"unexpected error","code":4}
10-31 22:26:26.981 31012  5089 D ziti-sdk:oidc.c:936 refresh_cb(): oidc[internal] token refresh success
10-31 22:26:26.981 31012  5089 E ziti-sdk:oidc.c:914 oidc_client_set_tokens(): oidc[internal] access_token was not provided by IdP
10-31 22:26:26.981 31012  5089 W ziti-sdk:ziti.c:223 ziti_set_unauthenticated(): ztx[2] auth error: failed to auth: 4
10-31 22:26:26.981 31012  5089 D ziti-sdk:ziti.c:226 ziti_set_unauthenticated(): ztx[2] setting auth_state[0] to 0
10-31 22:26:26.981 31012  5089 D ziti-sdk:ziti_ctrl.c:380 ziti_ctrl_clear_auth(): ctrl[https://ziti.my.domain:443] clearing api session token for ziti_controller
10-31 22:26:26.982 31012  5089 W tunnel-cbs:ziti_tunnel_ctrl.c:1018 on_ziti_event(): ziti_ctx controller connections failed: unexpected error
10-31 22:26:26.982 31012  5089 I Tunnel  : event: {"identifier":"mBlld39v8e","type":"ContextEvent","status":"unexpected error","code":4}
10-31 22:26:46.775 31012  5089 D ziti-sdk:posture.c:192 ziti_send_posture_data(): ztx[2] api_session is partially authenticated, can't submit posture responses
10-31 22:27:06.796 31012  5089 D ziti-sdk:posture.c:192 ziti_send_posture_data(): ztx[2] api_session is partially authenticated, can't submit posture responses
10-31 22:27:26.813 31012  5089 D ziti-sdk:posture.c:192 ziti_send_posture_data(): ztx[2] api_session is partially authenticated, can't submit posture responses
10-31 22:27:46.816 31012  5089 D ziti-sdk:posture.c:192 ziti_send_posture_data(): ztx[2] api_session is partially authenticated, can't submit posture responses
10-31 22:28:02.282 31012 31012 I ZitiVPNService: onCreate()
10-31 22:28:02.283 31012 13655 I ZitiVPNService: command monitor started
10-31 22:28:02.283 31012 13655 I ZitiVPNService: received cmd[stop]
10-31 22:28:02.283 31012 13655 I ZitiVPNService: tunnel stop success
10-31 22:28:02.283 31012 13655 I ZitiVPNService: monitoring route updates
10-31 22:28:02.284 31012  5108 I ZitiVPNService: network available: 110, caps:[ Transports: WIFI Capabilities: NOT_METERED&INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN&VALIDATED&NOT_ROAMING&FOREGROUND&NOT_CONGESTED&NOT_SUSPENDED LinkUpBandwidth>=321960Kbps LinkDnBandwidth>=338906Kbps SignalStrength: -59 AdministratorUids: [] RequestorUid: -1 RequestorPackageName: null]
10-31 22:28:02.284 31012  5108 I ZitiVPNService: active[110]
10-31 22:28:02.285 31012  5108 I ZitiVPNService: link change[110], active[110]
10-31 22:28:02.285 31012  5108 I ZitiVPNService: link[110] addresses: [/192.168.4.11, /xxxx:xxxx:xxxx:xxxx:e0e6:77b5:e864:8300, /xxxx:xxxx:xxxx:xxxx:e8f2:76f6:e994:2c62]
10-31 22:28:02.285 31012  5108 I ZitiVPNService: link[110] nameservers: [/192.168.4.250]
10-31 22:28:02.285 31012  5108 I ZitiVPNService: set upstream DNS[[192.168.4.250]]
10-31 22:28:02.285 31012  5108 D Tunnel  : cmd[123] = SetUpstreamDNS:[{"host":"192.168.4.250"}]
10-31 22:28:02.285 31012  5089 I tunnel-cbs:ziti_dns.c:273 ziti_dns_set_upstream(): DNS upstream[1] is set to 192.168.4.250:53
10-31 22:28:02.285 31012  5089 I Tunnel  : resp = {"Success":true,"Code":0}
10-31 22:28:02.285 31012  5089 D Tunnel  : result[123] = SetUpstreamDNS:TunnelResult(success=true, code=0, error=null, data=null)
10-31 22:28:06.821 31012  5089 D ziti-sdk:posture.c:192 ziti_send_posture_data(): ztx[2] api_session is partially authenticated, can't submit posture responses
10-31 22:28:13.133 31012 31012 D Tunnel  : cmd[124] = ZitiDump:{"Identifier":"mBlld39v8e"}
10-31 22:28:13.133 31012  5089 I tunnel-cbs:ziti_tunnel_ctrl.c:323 process_cmd(): ziti dump started
10-31 22:28:13.133 31012  5089 I tunnel-cbs:ziti_tunnel_ctrl.c:383 process_cmd(): ziti dump finished
10-31 22:28:13.133 31012  5089 I Tunnel  : resp = {"Success":true,"Data":{ },"Code":0}
10-31 22:28:13.134 31012  5089 D Tunnel  : result[124] = ZitiDump:TunnelResult(success=true, code=0, error=null, data={})
10-31 22:28:13.152 31012 31012 I ZitiVPNService: onDestroy
10-31 22:28:13.401 31012  6601 E DatabaseUtils: Writing exception to parcel
10-31 22:28:13.401 31012  6601 E DatabaseUtils: java.lang.SecurityException: Permission Denial: reading org.openziti.mobile.debug.FeedbackProvider uri content://org.openziti.mobile.provider/logs/logs/log.zip from pid=4241, uid=1000 requires the provider be exported, or grantUriPermission()
10-31 22:28:13.401 31012  6601 E DatabaseUtils: 	at android.content.ContentProvider.enforceReadPermissionInner(ContentProvider.java:820)
10-31 22:28:13.401 31012  6601 E DatabaseUtils: 	at android.content.ContentProvider$Transport.enforceReadPermission(ContentProvider.java:684)
10-31 22:28:13.401 31012  6601 E DatabaseUtils: 	at android.content.ContentProvider$Transport.query(ContentProvider.java:239)
10-31 22:28:13.401 31012  6601 E DatabaseUtils: 	at android.content.ContentProviderNative.onTransact(ContentProviderNative.java:106)
10-31 22:28:13.401 31012  6601 E DatabaseUtils: 	at android.os.Binder.execTransactInternal(Binder.java:1154)
10-31 22:28:13.401 31012  6601 E DatabaseUtils: 	at android.os.Binder.execTransact(Binder.java:1123)
10-31 22:28:13.422 31012  6601 E DatabaseUtils: Writing exception to parcel
10-31 22:28:13.422 31012  6601 E DatabaseUtils: java.lang.SecurityException: Permission Denial: reading org.openziti.mobile.debug.FeedbackProvider uri content://org.openziti.mobile.provider/logs/logs/log.zip from pid=4241, uid=1000 requires the provider be exported, or grantUriPermission()
10-31 22:28:13.422 31012  6601 E DatabaseUtils: 	at android.content.ContentProvider.enforceReadPermissionInner(ContentProvider.java:820)
10-31 22:28:13.422 31012  6601 E DatabaseUtils: 	at android.content.ContentProvider$Transport.enforceReadPermission(ContentProvider.java:684)
10-31 22:28:13.422 31012  6601 E DatabaseUtils: 	at android.content.ContentProvider$Transport.query(ContentProvider.java:239)
10-31 22:28:13.422 31012  6601 E DatabaseUtils: 	at android.content.ContentProviderNative.onTransact(ContentProviderNative.java:106)
10-31 22:28:13.422 31012  6601 E DatabaseUtils: 	at android.os.Binder.execTransactInternal(Binder.java:1154)
10-31 22:28:13.422 31012  6601 E DatabaseUtils: 	at android.os.Binder.execTransact(Binder.java:1123)
10-31 22:28:13.555 31012  6601 E DatabaseUtils: Writing exception to parcel
10-31 22:28:13.555 31012  6601 E DatabaseUtils: java.lang.SecurityException: Permission Denial: reading org.openziti.mobile.debug.FeedbackProvider uri content://org.openziti.mobile.provider/logs/logs/log.zip from pid=4241, uid=1000 requires the provider be exported, or grantUriPermission()
10-31 22:28:13.555 31012  6601 E DatabaseUtils: 	at android.content.ContentProvider.enforceReadPermissionInner(ContentProvider.java:820)
10-31 22:28:13.555 31012  6601 E DatabaseUtils: 	at android.content.ContentProvider$Transport.enforceReadPermission(ContentProvider.java:684)
10-31 22:28:13.555 31012  6601 E DatabaseUtils: 	at android.content.ContentProvider$Transport.query(ContentProvider.java:239)
10-31 22:28:13.555 31012  6601 E DatabaseUtils: 	at android.content.ContentProviderNative.onTransact(ContentProviderNative.java:106)
10-31 22:28:13.555 31012  6601 E DatabaseUtils: 	at android.os.Binder.execTransactInternal(Binder.java:1154)
10-31 22:28:13.555 31012  6601 E DatabaseUtils: 	at android.os.Binder.execTransact(Binder.java:1123)
10-31 22:28:15.097 31012 31012 I ZitiVPNService: onCreate()
10-31 22:28:15.100 31012  5108 I ZitiVPNService: network available: 110, caps:[ Transports: WIFI Capabilities: NOT_METERED&INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN&VALIDATED&NOT_ROAMING&FOREGROUND&NOT_CONGESTED&NOT_SUSPENDED LinkUpBandwidth>=321960Kbps LinkDnBandwidth>=338906Kbps SignalStrength: -59 AdministratorUids: [] RequestorUid: -1 RequestorPackageName: null]
10-31 22:28:15.100 31012  5108 I ZitiVPNService: active[110]
10-31 22:28:15.100 31012  5108 I ZitiVPNService: link change[110], active[110]
10-31 22:28:15.100 31012  5108 I ZitiVPNService: link[110] addresses: [/192.168.4.11, /xxxx:xxxx:xxxx:xxxx:e0e6:77b5:e864:8300, /xxxx:xxxx:xxxx:xxxx:e8f2:76f6:e994:2c62]
10-31 22:28:15.100 31012  5108 I ZitiVPNService: link[110] nameservers: [/192.168.4.250]
10-31 22:28:15.100 31012  5108 I ZitiVPNService: set upstream DNS[[192.168.4.250]]
10-31 22:28:15.100 31012  5108 D Tunnel  : cmd[125] = SetUpstreamDNS:[{"host":"192.168.4.250"}]
10-31 22:28:15.101 31012  5089 I tunnel-cbs:ziti_dns.c:273 ziti_dns_set_upstream(): DNS upstream[1] is set to 192.168.4.250:53
10-31 22:28:15.101 31012  5089 I Tunnel  : resp = {"Success":true,"Code":0}
10-31 22:28:15.101 31012 13689 I ZitiVPNService: command monitor started
10-31 22:28:15.101 31012 13689 I ZitiVPNService: received cmd[stop]
10-31 22:28:15.101 31012  5089 D Tunnel  : result[125] = SetUpstreamDNS:TunnelResult(success=true, code=0, error=null, data=null)
10-31 22:28:15.101 31012 13689 I ZitiVPNService: tunnel stop success
10-31 22:28:15.101 31012 13689 I ZitiVPNService: monitoring route updates
10-31 22:28:17.163 31012 31012 I ZitiVPNService: onDestroy
10-31 22:28:19.137 31012 31012 I ZitiVPNService: onCreate()
10-31 22:28:19.140 31012 13692 I ZitiVPNService: command monitor started
10-31 22:28:19.140 31012 13692 I ZitiVPNService: received cmd[stop]
10-31 22:28:19.140 31012 13692 I ZitiVPNService: tunnel stop success
10-31 22:28:19.140 31012 13692 I ZitiVPNService: monitoring route updates
10-31 22:28:19.140 31012  5108 I ZitiVPNService: network available: 110, caps:[ Transports: WIFI Capabilities: NOT_METERED&INTERNET&NOT_RESTRICTED&TRUSTED&NOT_VPN&VALIDATED&NOT_ROAMING&FOREGROUND&NOT_CONGESTED&NOT_SUSPENDED LinkUpBandwidth>=321960Kbps LinkDnBandwidth>=338906Kbps SignalStrength: -59 AdministratorUids: [] RequestorUid: -1 RequestorPackageName: null]
10-31 22:28:19.141 31012  5108 I ZitiVPNService: active[110]
10-31 22:28:19.141 31012  5108 I ZitiVPNService: link change[110], active[110]
10-31 22:28:19.142 31012  5108 I ZitiVPNService: link[110] addresses: [/192.168.4.11, /xxxx:xxxx:xxxx:xxxx:e0e6:77b5:e864:8300, /xxxx:xxxx:xxxx:xxxx:e8f2:76f6:e994:2c62]
10-31 22:28:19.142 31012  5108 I ZitiVPNService: link[110] nameservers: [/192.168.4.250]
10-31 22:28:19.142 31012  5108 I ZitiVPNService: set upstream DNS[[192.168.4.250]]
10-31 22:28:19.142 31012  5108 D Tunnel  : cmd[126] = SetUpstreamDNS:[{"host":"192.168.4.250"}]
10-31 22:28:19.143 31012  5089 I tunnel-cbs:ziti_dns.c:273 ziti_dns_set_upstream(): DNS upstream[1] is set to 192.168.4.250:53
10-31 22:28:19.143 31012  5089 I Tunnel  : resp = {"Success":true,"Code":0}
10-31 22:28:19.143 31012  5089 D Tunnel  : result[126] = SetUpstreamDNS:TunnelResult(success=true, code=0, error=null, data=null)
10-31 22:28:26.824 31012  5089 D ziti-sdk:posture.c:192 ziti_send_posture_data(): ztx[2] api_session is partially authenticated, can't submit posture responses
10-31 22:28:32.350 31012 31012 I ZitiVPNService: onDestroy
10-31 22:28:32.351 31012 13692 I ZitiVPNService: stopped route updates
10-31 22:28:32.362 31012 31012 W TabLayout: MODE_SCROLLABLE + GRAVITY_FILL is not supported, GRAVITY_START will be used instead
10-31 22:28:46.845 31012  5089 D ziti-sdk:posture.c:192 ziti_send_posture_data(): ztx[2] api_session is partially authenticated, can't submit posture responses
I have been dealing with connectivity issues, and somewhat covered in this thread
I noticed that my android devices were unable to connect, but other tunnels, including new users (on android) connect perfectly.
I arrived here by noticing the subject_token is invalid error line in the controller logs.
I am running GrapheneOS, and I have Ziti Mobile Edge installed directly from GitHub via Obtainium.
Other users are running stock Android, and they exhibit no issues.
I have both the controller and router installed via helm.
I inspected the ConfigMap for the controller, and the OIDC section is blank:
    options: { }
I have been debugging this from every angle, and I am curious if there is something specific about the release directly from GitHub, or using GrapheneOS, or both.
This has been a recent failure, and it is quite maddening.
At this point, I think my upgrading the controller and router was not the issue, and feeling that the upgrade was the issue is a red herring. At the very least, it may have set all of this in motion.
My instinct tells me that it is something about a direct install and/or GrapheneOS.
Why it recently stopped functioning out of nowhere is something I have not been able to deduce.
One additional note, in the Android tunnel logs, I noticed this:
I’m using LineageOS and it recently stopped functioning out of nowhere.
I upgrade ziti binaries on controller and routers about a month ago
This is probably because Google Play store releases are delayed compared to Github releases. Before Google Play gets a new ZME release it is tested via Beta program.
the current release process is as follows:
Github released -> Google Play (Alpha) -> Google Play (Beta) -> Google Play (Production/general availability)
That was the problem!
I started an issue here that will help to prevent things like this in the future: Release Cadence Pairing With GA · Issue #379 · openziti/ziti-tunnel-android · GitHub
Downgrading the apk I was able to authenticate again.
I'm abroad for a week and I really needed the android client to work.
And this has ben the major failure I experienced since installation.
Thanks for the config.
I have visually identified a potential bug that your config would trigger. @ekoby was asking some great questions that lead me to reading through it.
I am updating the integration tests today to verify the bug actually exists.
I've been very busy, but I'm still stuck with SDK 1.7 with android or Windows clients. If I upgrade the clients I'm getting the unable to authenticate error.
How can I modify my controller configuration?
Does the bug exist?
