CertificateAuthorityDeletion
Hi, I have a question regarding identities linked to a Certificate Authority (CA). If I delete this CA, OpenZiti deletes it —so will those linked identities continue to function? If they won’t, could you explain why the deletion of a CA is permitted in this case?
The identities will not continue to function if you delete the CA. It's allowed because there's no way for OpenZiti to know what identities (if any) any given CA is being used to authenticate with.
