Controller client and management apis
I am working through the scenario where you can make the management API only accessible over the local host. (time got away from me)
.. this was covered in this post
When I started to investigate this further.. I noticed the following.
my controller yaml file only has an entry for client-management
there is no entry for
  • management-apis
maybe I have an old config.. as its been a while since I installed ziti from scratch
So.. I thought to confirm
  1. if there is no entry.. then by default.. the management API would not be accessible.. as there is no listener configured to find it
  2. could this be why I cannot access the management API documentation?
    .. as when I try to access it using the following url
https://IP-address:8441/edge/management/v1/docs
.. it retrieves the client documentation instead.
Actually.. to clarify further.. I just realised the following
.. in the example provided.. the entry of client-management is split into
  • management-apis
  • client-apis
change this entry
web:
to look like this:
web:
  • name: management-apis
bindPoints:
- interface: 127.0.0.1:5309
address: "127.0.0.1:5309"
identity: (removed section for brevity)
options: (
So.. I guess the naming of the entries does not really matter that much..
What is important is the details of the details of the bindings
this is documented pretty well in the change log ziti/CHANGELOG.md at release-next · openziti/ziti · GitHub
