Deploying router on k8s via helm gives identity secret mount error
I'm deploying via helm but i get
MountVolume.SetUp failed for volume "ziti-router-identity" : secret "ziti-router-gigo-internal-global1-identity" not found
Heres the cleaned up values
advertisedHost: ziti-router-gigo-internal-global1.gigo.gage.intranet
affinity: {}
configFile: ziti-router.yaml
configMountDir: /etc/ziti/config
csr:
  sans:
    dns: null
    ip: null
ctrl:
  endpoint: ziti-controller-ctrl.ziti.svc:6262
deleteIdentityScriptFile: delete-identity.bash
dnsPolicy: ClusterFirstWithHostNet
edge:
  advertisedPort: 443
  containerPort: 3022
  enabled: true
  ingress:
    annotations: null
    enabled: true
  service:
    annotations: null
    enabled: true
    labels: null
    type: ClusterIP
enrollJwtFile: enrollment.jwt
enrollmentJwt: >-
<TOKEN>
execMountDir: /usr/local/bin
fabric:
  metrics:
    enabled: false
identityMountDir: /etc/ziti/identity
image:
  args:
    - '{{ .Values.configMountDir }}/{{ .Values.configFile }}'
  command:
    - ziti
    - router
    - run
  pullPolicy: Always
  repository: docker.io/openziti/ziti-router
initScriptFile: ziti-router-init.bash
linkListeners:
  transport:
    advertisedHost: null
    advertisedPort: 443
    containerPort: 10080
    ingress:
      annotations: null
      enabled: false
    service:
      annotations: null
      enabled: true
      labels: null
      type: ClusterIP
nodeSelector: {}
persistence:
  VolumeName: null
  accessMode: ReadWriteOnce
  annotations: {}
  enabled: true
  existingClaim: ''
  storageClass: ''
podAnnotations: {}
podSecurityContext:
  fsGroup: 2171
resources: {}
securityContext: null
tolerations: null
tunnel:
  mode: host
  proxyAdditionalK8sServices: null
  proxyDefaultK8sService:
    enabled: true
    type: ClusterIP
  proxyServices: null
  resolver: none
Hey @sam-ulrich1 I'm looking at this now. I don't yet know if you're having a similar problem as another user did a couple of days ago (link), but it does sound suspiciously similar. Both cases involved pieces of the router's identity in Kubernetes. I suspect the other issue was caused by skipping Helm chart versions during an upgrade, and the problem didn't recur with a fresh install.
Are you seeing this on a fresh install?
Let's check for obvious problems with kubectl get events --all-namespaces --watch (or narrow to Ziti namespace) while creating the Helm release for the Ziti Router, and kubectl describe pods --selector app.kubernetes.io/component=ziti-router after creating the release.
Where was that MountVolume.SetUp error emitted?
Does that expected K8s Secret exist in any namespace?
I assume <TOKEN> is a redaction, and the token was valid. I often check tokens with https://jwt.io if not sensitive, or this Python script if I need to keep the token offline.
Thanks for the help man!
  1. This is deployed on an RKE2 cluster with project network isolation enabled but the ziti namespace has an allow all on egress & ingress.
  2. Controller is successfully deployed with cert-manager, trust-manager, and console in the same namespace.
  3. Token is a redaction, the token appears to be valid. It was retrieved from console after I created it there.
  4. This is a fresh install via helm with the latest version. I've fresh installed a couple times with the same issue.
  5. The secret is nowhere to be found in any of the secrets.
  6. The log comes from the event tab for the pod in rancher but I assume a kubectl describe on the pod would render the same answer since that is where rancher gets those logs from.
I'll perform a fresh install tomorrow and get the raw k8s logs from the install. I'm tied up for the rest of the day. Thanks so much for the help
You bet! The chart has life-cycle hooks for installation and upgrade, and they both do the same thing: check if the Secret exists, if not then enroll and create the Secret.
The app pod waits for that Secret to appear, but something must've gone wrong with the hook Job.
While creating the Helm release for the Router, you can watch for the hook Job to appear and check its logs if it throws an error. I've just released Router chart 0.9.0 with a delayed exit for installation and upgrade life cycle hooks errors.
Be sure to update:
helm repo update openziti
Do this if there's a Job running with this name due to a hook error (adjust to match your release name if needed). The Job will exit and vanish immediately if it succeeds.
kubectl logs --selector=job-name=ziti-router-post-install-job
The selector would be like --selector=job-name=ziti-router-post-upgrade-job if upgrading an existing Helm release.
reference link to init script used by Helm hooks: https://github.com/openziti/helm-charts/blob/ziti-router-0.9.0/charts/ziti-router/templates/configmap.yaml#L12
From what I can tell the post install hook never runs. Not sure what is happening.
Events
AST SEEN   TYPE      REASON                   OBJECT                                                         MESSAGE
31m         Normal    Pulling                  pod/ziti-console-88d848c54-shk2g                               Pulling image "openziti/zac:2.9.0"
31m         Normal    Created                  pod/ziti-console-88d848c54-shk2g                               Created container ziti-console
31m         Normal    Started                  pod/ziti-console-88d848c54-shk2g                               Started container ziti-console
4m49s       Warning   Unhealthy                pod/ziti-console-88d848c54-shk2g                               Liveness probe failed: Get "http://10.142.60.80:1408/login": context deadline exceeded (Client.Timeout exceeded while awaiting headers)
31m         Normal    Killing                  pod/ziti-console-88d848c54-shk2g                               Container ziti-console failed liveness probe, will be restarted
31m         Normal    Pulled                   pod/ziti-console-88d848c54-shk2g                               Successfully pulled image "openziti/zac:2.9.0" in 760.177134ms (760.209154ms including waiting)
35s         Normal    Sync                     ingress/ziti-console                                           Scheduled for sync
3m55s       Normal    Sync                     ingress/ziti-console                                           Scheduled for sync
4m28s       Warning   NodeNotReady             pod/ziti-controller-cert-manager-cainjector-6d69b886dc-cdsk7   Node is not ready
94s         Normal    Pulled                   pod/ziti-controller-cert-manager-cainjector-6d69b886dc-cdsk7   Container image "quay.io/jetstack/cert-manager-cainjector:v1.11.5" already present on machine
94s         Normal    Created                  pod/ziti-controller-cert-manager-cainjector-6d69b886dc-cdsk7   Created container cert-manager-cainjector
94s         Normal    Started                  pod/ziti-controller-cert-manager-cainjector-6d69b886dc-cdsk7   Started container cert-manager-cainjector
88s         Normal    TaintManagerEviction     pod/ziti-controller-cert-manager-cainjector-6d69b886dc-cdsk7   Cancelling deletion of Pod ziti/ziti-controller-cert-manager-cainjector-6d69b886dc-cdsk7
36s         Normal    Sync                     ingress/ziti-controller-client                                 Scheduled for sync
3m55s       Normal    Sync                     ingress/ziti-controller-client                                 Scheduled for sync
41m         Warning   FailedMount              pod/ziti-router-gigo-internal-global1-5dbb5f7988-s9m2f         MountVolume.SetUp failed for volume "ziti-router-identity" : secret "ziti-router-gigo-internal-global1-identity" not found
35m         Warning   FailedMount              pod/ziti-router-gigo-internal-global1-5dbb5f7988-s9m2f         Unable to attach or mount volumes: unmounted volumes=[ziti-router-identity], unattached volumes=[config-data ziti-router-config kube-api-access-ph6ff ziti-router-identity]: timed out waiting for the condition
51m         Warning   FailedMount              pod/ziti-router-gigo-internal-global1-5dbb5f7988-s9m2f         Unable to attach or mount volumes: unmounted volumes=[ziti-router-identity], unattached volumes=[ziti-router-identity config-data ziti-router-config kube-api-access-ph6ff]: timed out waiting for the condition
33m         Normal    Sync                     ingress/ziti-router-gigo-internal-global1-edge                 Scheduled for sync
28m         Normal    Sync                     ingress/ziti-router-gigo-internal-global1-edge                 Scheduled for sync
36s         Normal    Sync                     ingress/ziti-router-gigo-internal-global1-edge                 Scheduled for sync
2m23s       Normal    Scheduled                pod/ziti-router-gigo-internal-global1-f9b44cd85-47lqv          Successfully assigned ziti/ziti-router-gigo-internal-global1-f9b44cd85-47lqv to gigo-worker-ab40529a-w9vjd
16s         Warning   FailedMount              pod/ziti-router-gigo-internal-global1-f9b44cd85-47lqv          MountVolume.SetUp failed for volume "ziti-router-identity" : secret "ziti-router-gigo-internal-global1-identity" not found
2m13s       Warning   FailedAttachVolume       pod/ziti-router-gigo-internal-global1-f9b44cd85-47lqv          AttachVolume.Attach failed for volume "pvc-bbf4f27f-3bbf-4fdf-a685-0819cbc7ce6c" : rpc error: code = Aborted desc = The PVC pvc-bbf4f27f-3bbf-4fdf-a685-0819cbc7ce6c in phase Pending is not ready to be attached
2m5s        Normal    SuccessfulAttachVolume   pod/ziti-router-gigo-internal-global1-f9b44cd85-47lqv          AttachVolume.Attach succeeded for volume "pvc-bbf4f27f-3bbf-4fdf-a685-0819cbc7ce6c"
2m2s        Warning   FailedMount              pod/ziti-router-gigo-internal-global1-f9b44cd85-47lqv          MountVolume.SetUp failed for volume "pvc-bbf4f27f-3bbf-4fdf-a685-0819cbc7ce6c" : rpc error: code = Aborted desc = The hot-plug volume pvc-bbf4f27f-3bbf-4fdf-a685-0819cbc7ce6c is not ready
21s         Warning   FailedMount              pod/ziti-router-gigo-internal-global1-f9b44cd85-47lqv          Unable to attach or mount volumes: unmounted volumes=[ziti-router-identity], unattached volumes=[ziti-router-identity config-data ziti-router-config kube-api-access-5xjpt]: timed out waiting for the condition
33m         Warning   FailedScheduling         pod/ziti-router-gigo-internal-global1-f9b44cd85-dn99c          0/21 nodes are available: persistentvolumeclaim "ziti-router-gigo-internal-global1" is being deleted. preemption: 0/21 nodes are available: 21 No preemption victims found for incoming pod..
33m         Warning   FailedScheduling         pod/ziti-router-gigo-internal-global1-f9b44cd85-dn99c          0/21 nodes are available: persistentvolumeclaim "ziti-router-gigo-internal-global1" not found. preemption: 0/21 nodes are available: 21 No preemption victims found for incoming pod..
32m         Warning   FailedScheduling         pod/ziti-router-gigo-internal-global1-f9b44cd85-dn99c          skip schedule deleting pod: ziti/ziti-router-gigo-internal-global1-f9b44cd85-dn99c
29m         Normal    Scheduled                pod/ziti-router-gigo-internal-global1-f9b44cd85-gx6k2          Successfully assigned ziti/ziti-router-gigo-internal-global1-f9b44cd85-gx6k2 to gigo-worker-ab40529a-hfqt2
12m         Warning   FailedMount              pod/ziti-router-gigo-internal-global1-f9b44cd85-gx6k2          MountVolume.SetUp failed for volume "ziti-router-identity" : secret "ziti-router-gigo-internal-global1-identity" not found
28m         Warning   FailedAttachVolume       pod/ziti-router-gigo-internal-global1-f9b44cd85-gx6k2          AttachVolume.Attach failed for volume "pvc-a9bcfb66-0df1-47bd-a7f9-f240559cbcd9" : rpc error: code = Aborted desc = The PVC pvc-a9bcfb66-0df1-47bd-a7f9-f240559cbcd9 in phase Pending is not ready to be attached
28m         Normal    SuccessfulAttachVolume   pod/ziti-router-gigo-internal-global1-f9b44cd85-gx6k2          AttachVolume.Attach succeeded for volume "pvc-a9bcfb66-0df1-47bd-a7f9-f240559cbcd9"
28m         Warning   FailedMount              pod/ziti-router-gigo-internal-global1-f9b44cd85-gx6k2          MountVolume.SetUp failed for volume "pvc-a9bcfb66-0df1-47bd-a7f9-f240559cbcd9" : rpc error: code = Aborted desc = The hot-plug volume pvc-a9bcfb66-0df1-47bd-a7f9-f240559cbcd9 is not ready
9m1s        Warning   FailedMount              pod/ziti-router-gigo-internal-global1-f9b44cd85-gx6k2          Unable to attach or mount volumes: unmounted volumes=[ziti-router-identity], unattached volumes=[ziti-router-identity config-data ziti-router-config kube-api-access-h8qvf]: timed out waiting for the condition
24m         Warning   FailedMount              pod/ziti-router-gigo-internal-global1-f9b44cd85-gx6k2          Unable to attach or mount volumes: unmounted volumes=[ziti-router-identity], unattached volumes=[config-data ziti-router-config kube-api-access-h8qvf ziti-router-identity]: timed out waiting for the condition
17m         Warning   FailedMount              pod/ziti-router-gigo-internal-global1-f9b44cd85-gx6k2          Unable to attach or mount volumes: unmounted volumes=[ziti-router-identity], unattached volumes=[ziti-router-config kube-api-access-h8qvf ziti-router-identity config-data]: timed out waiting for the condition
15m         Warning   FailedMount              pod/ziti-router-gigo-internal-global1-f9b44cd85-gx6k2          Unable to attach or mount volumes: unmounted volumes=[ziti-router-identity], unattached volumes=[kube-api-access-h8qvf ziti-router-identity config-data ziti-router-config]: timed out waiting for the condition
33m         Normal    SuccessfulCreate         replicaset/ziti-router-gigo-internal-global1-f9b44cd85         Created pod: ziti-router-gigo-internal-global1-f9b44cd85-dn99c
29m         Normal    SuccessfulCreate         replicaset/ziti-router-gigo-internal-global1-f9b44cd85         Created pod: ziti-router-gigo-internal-global1-f9b44cd85-gx6k2
2m24s       Normal    SuccessfulCreate         replicaset/ziti-router-gigo-internal-global1-f9b44cd85         Created pod: ziti-router-gigo-internal-global1-f9b44cd85-47lqv
35m         Normal    Scheduled                pod/ziti-router-gigo-internal-global1-pre-delete-job-jqvtk     Successfully assigned ziti/ziti-router-gigo-internal-global1-pre-delete-job-jqvtk to gigo-worker-ab40529a-hfqt2
35m         Normal    Pulling                  pod/ziti-router-gigo-internal-global1-pre-delete-job-jqvtk     Pulling image "docker.io/openziti/ziti-router:0.30.4"
35m         Normal    Pulled                   pod/ziti-router-gigo-internal-global1-pre-delete-job-jqvtk     Successfully pulled image "docker.io/openziti/ziti-router:0.30.4" in 9.642524779s (9.642548165s including waiting)
35m         Normal    Created                  pod/ziti-router-gigo-internal-global1-pre-delete-job-jqvtk     Created container pre-install-job
35m         Normal    Started                  pod/ziti-router-gigo-internal-global1-pre-delete-job-jqvtk     Started container pre-install-job
32m         Normal    Scheduled                pod/ziti-router-gigo-internal-global1-pre-delete-job-mq9jl     Successfully assigned ziti/ziti-router-gigo-internal-global1-pre-delete-job-mq9jl to gigo-worker-ab40529a-w9vjd
32m         Normal    Pulling                  pod/ziti-router-gigo-internal-global1-pre-delete-job-mq9jl     Pulling image "docker.io/openziti/ziti-router:0.31.0"
32m         Normal    Pulled                   pod/ziti-router-gigo-internal-global1-pre-delete-job-mq9jl     Successfully pulled image "docker.io/openziti/ziti-router:0.31.0" in 8.396640338s (8.396659618s including waiting)
32m         Normal    Created                  pod/ziti-router-gigo-internal-global1-pre-delete-job-mq9jl     Created container pre-install-job
32m         Normal    Started                  pod/ziti-router-gigo-internal-global1-pre-delete-job-mq9jl     Started container pre-install-job
5m34s       Normal    Scheduled                pod/ziti-router-gigo-internal-global1-pre-delete-job-rwdt4     Successfully assigned ziti/ziti-router-gigo-internal-global1-pre-delete-job-rwdt4 to gigo-worker-ab40529a-hfqt2
5m34s       Normal    Pulling                  pod/ziti-router-gigo-internal-global1-pre-delete-job-rwdt4     Pulling image "docker.io/openziti/ziti-router:0.31.0"
5m26s       Normal    Pulled                   pod/ziti-router-gigo-internal-global1-pre-delete-job-rwdt4     Successfully pulled image "docker.io/openziti/ziti-router:0.31.0" in 8.063878514s (8.063903882s including waiting)
5m26s       Normal    Created                  pod/ziti-router-gigo-internal-global1-pre-delete-job-rwdt4     Created container pre-install-job
5m26s       Normal    Started                  pod/ziti-router-gigo-internal-global1-pre-delete-job-rwdt4     Started container pre-install-job
35m         Normal    SuccessfulCreate         job/ziti-router-gigo-internal-global1-pre-delete-job           Created pod: ziti-router-gigo-internal-global1-pre-delete-job-jqvtk
35m         Normal    Completed                job/ziti-router-gigo-internal-global1-pre-delete-job           Job completed
32m         Normal    SuccessfulCreate         job/ziti-router-gigo-internal-global1-pre-delete-job           Created pod: ziti-router-gigo-internal-global1-pre-delete-job-mq9jl
32m         Normal    Completed                job/ziti-router-gigo-internal-global1-pre-delete-job           Job completed
5m35s       Normal    SuccessfulCreate         job/ziti-router-gigo-internal-global1-pre-delete-job           Created pod: ziti-router-gigo-internal-global1-pre-delete-job-rwdt4
5m14s       Normal    Completed                job/ziti-router-gigo-internal-global1-pre-delete-job           Job completed
33m         Normal    ScalingReplicaSet        deployment/ziti-router-gigo-internal-global1                   Scaled up replica set ziti-router-gigo-internal-global1-f9b44cd85 to 1
29m         Normal    ExternalProvisioning     persistentvolumeclaim/ziti-router-gigo-internal-global1        waiting for a volume to be created, either by external provisioner "driver.harvesterhci.io" or manually created by system administrator
29m         Normal    Provisioning             persistentvolumeclaim/ziti-router-gigo-internal-global1        External provisioner is provisioning volume for claim "ziti/ziti-router-gigo-internal-global1"
29m         Normal    ProvisioningSucceeded    persistentvolumeclaim/ziti-router-gigo-internal-global1        Successfully provisioned volume pvc-a9bcfb66-0df1-47bd-a7f9-f240559cbcd9
29m         Normal    ScalingReplicaSet        deployment/ziti-router-gigo-internal-global1                   Scaled up replica set ziti-router-gigo-internal-global1-f9b44cd85 to 1
2m24s       Normal    ExternalProvisioning     persistentvolumeclaim/ziti-router-gigo-internal-global1        waiting for a volume to be created, either by external provisioner "driver.harvesterhci.io" or manually created by system administrator
2m24s       Normal    Provisioning             persistentvolumeclaim/ziti-router-gigo-internal-global1        External provisioner is provisioning volume for claim "ziti/ziti-router-gigo-internal-global1"
2m24s       Normal    ProvisioningSucceeded    persistentvolumeclaim/ziti-router-gigo-internal-global1        Successfully provisioned volume pvc-bbf4f27f-3bbf-4fdf-a685-0819cbc7ce6c
2m24s       Normal    ScalingReplicaSet        deployment/ziti-router-gigo-internal-global1                   Scaled up replica set ziti-router-gigo-internal-global1-f9b44cd85 to 1
There's a lot going on cause I have installed and deleted multiple times
Are you perchance wrapping helm CLI with a something like an Ansible module or TF provider? I've noticed that some wrappers do not fire the hooks unless wait=false, which is not intuitive, and I don't understand why this is necessary. There is a long-running GitHub issue about it.
The workaround is to unset wait and atomic when creating or upgrading the Helm Release. The helm CLI default settings seem to work fine, but when wrapping Helm I've noticed that hooks don't fire without the additional setting. Let me know if you have any ideas for making this more robust.
EDIT: It's starting to make sense why we're seeing what we're seeing. The default for Helm CLI is wait=false, and post-install and post-upgrade don't run when wait=true. It's because those Jobs are only scheduled after the main app pod is "ready," which can't happen until after those Jobs run, so it's a pickle. Maybe those hooks need to be pre-install and pre-upgrade. I don't recall now what forced me to use post-x at the time, but the constraint may have only applied to certain charts, not all. I'll investigate.
I'm running it via rancher so I'm sure wait is set to true. I'll try overriding it or manually running helm. I would've never guessed that cause the controller and console installed just fin with rancher's helm wrapper.
Rancher v2.7.5 if it makes a differenece
Tried it via rancher with wait=false and the job did run. It failed but it appears to be a config thing on my end. I'll dig into that and update
Still working on it but as an anecdote, one of my issues was the controller ingress config. The SSL passthrough needed one more annotation to use the secure backed nginx.ingress.kubernetes.io/backend-protocol=https
The Controller chart has a sample values.yaml for Nginx Ingress that worked with some version, so it would be great for those samples to be more robust.
The particular annotation you added configures Nginx to use TLS for the reverse proxy backend, no? If so, I doubt that will work in the end because it must passthrough TLS (L4 TCP proxy).
ref: The Router chart's sample values.yaml for Ingress Nginx
Interesting, does the current configuration setup a L4 proxy? On my RKE2 cluster it doesn't. I can configure it I just didn't want to cause it's a more involved configuration
In my (albeit limited) experience, L4 proxy with nginx ingress normally requires a custom configmap and a patch to the ingress deployment
Yes, the sample values for Nginx Ingress represent a combination of annotations that I found necessary to configure ingress-nginx for passthrough TLS, i.e. L4 TCP proxy.
I've definitely used those annotations on some version of RKE2 that I provisioned with Rancher. I was using the Harvester cloud provider/node driver to provide the LB from an IP pool, but alas, some other version of RKE2 or provider may not work the same way. It's a weakness of Ingress that L4 TCP proxy is not a primitive, and all hail our savior, Gateway API.
Seems the annotation I set worked, I'll see if other problems occur down the road... Gotta love the gamble
The reason it needs passthrough TLS, not backend TLS, is that at the last stage of your deployment your Ziti Edge Identities will try to authenticate with the Controller's Client API TLS Service using mTLS by presenting the client certificate they obtained during "edge enrollment."
Looks like it does the same thing as the secure-backend annotation for newer ingress versions
I'm not entirely sure how the nginx config is working here but I can say that I am getting the controllers cert from the config. To the best of my knowledge the only way to do a SSL pass through is L4 so maybe it worked.
Cool. Let's get it working and If the best way to get L4 passthrough proves to be annotating nginx.ingress.kubernetes.io/backend-protocol=https then I'll update the Nginx sample values.
Since you're using Rancher, would you have been likely to use a Rancher app catalog launcher for Ziti Controller or Ziti Router, or both, or have preferred less magic? I've only placed a simple Ziti reverse proxy in the Rancher catalog up to this point, but an opinionated launcher is probably feasible, if we assume RKE2 was provisioned by Rancher with the default ingress-nginx enabled. I'm unsure how much flexibility the catalog will give me for pivoting the values based on the target cluster's parameters.
