Enabling MFA Posture Check
Hi all, I鈥檓 new to OpenZiti so be kind :wink:
I have successfully setup and tested connectivity to an MS RDS Host.
I used the ZAC to create the service and policies. There are 4 policies that were created:
RDP-Server-bind-policy
RDP-Server-dial-policy
RDP-bind-policy
RDP-dial-policy
I have enabled MFA on the Ziti Desktop Edge Client and that works when I enable the service- I get prompted for MFA and am able to enter the MFA code.
I鈥檓 now trying to setup and test MFA using Posture Check but cannot get it to work.
I create a Posture check using MFA under Identities.
If I assign my MFA posture check to RDP-bind-policy I never get the RDP Host login prompt nor do I get the MFA prompt.
If I assign my MFA posture check to the other 3 policies above I can connect to the RDP Host without MFA.
Any thoughts? Thanks in advance.
Could this be related to another post I found that described a potential bug with MFA?
Hi @czopper, welcome to the community and to OpenZiti! Sorry for a slight delay in responding... We're always kind here! :slight_smile:
Oh, I wonder if we have ever tested this for bind. That's an interesting use and one I've never tested myself. I almost exclusively use posture checks and MFA on dial policies. Never bind...
I assume that is intentional right? I'll have to test this myself...
Hi thanks for the reply. I have tried Dial but nothing happens and my RDP connection works. When I enabled Posture Check on Bind that is when nothing happens and my RDP connection eventually times out.
FYI I'll get to this but it might take me a bit. If I (or someone) don't reply before say next tuesday, please bump this thread? :slight_smile: cheers
Thanks. No rush, when you can, thanks.
Saturday bump, thanks
We were able to find and fix the problem in development branches and it's working its way through a deployment. Should be getting fixed "pretty soon". :slight_smile: I'll post back here when I push out the latest zssh code and works for zssh and any changes that are necessary (which I don't think any would be but I don't exactly remember at the moment)
Awesome and thanks for the find!
Oh no... My bad, I see now I posted my reply here but that was the wrong thread :confused: I'll have to have a look at this again. Sorry to get your hopes up.
No worries. Hope to here back soon
FYI I've filed this bug to track MFA on Bind services never prompt 路 Issue #886 路 openziti/desktop-edge-win 路 GitHub
Hi any progress on this issue?
Hello and thanks for the bump. Unfortunately we haven鈥檛 gotten started on this issue yet!
