Enrollment Failed ZDEW
I’ve been following the OpenZiti “Local” tutorial - Docker Compose" Quickstart Overview on YouTube. But I’m unable to enrol the identity.
enrollment failed
After that, I tried to restart my laptop. Then the enrollment identity is there.
Then, I realised it was not the same as in the video. Should be some link of https://ziti-edge-controller:1280… below the http.client
After that, I followed the documentation and added the services. Also did not work, and I still cannot detect the services.
[2022-12-12T04:21:44.811Z]   ERROR ziti-sdk:ziti_enroll.c:219 well_known_certs_cb() D:/a/desktop-edge-win/desktop-edge-win/ziti-edge-tunnel/deps/ziti-tunneler-sdk-c/build/_deps/ziti-sdk-c-src/library/ziti_enroll.c:148 - ZITI_JWT_VERIFICATION_FAILED => -7 (JWT verification failed)
[2022-12-12T04:21:44.811Z]   ERROR ziti-edge-tunnel:ziti-edge-tunnel.c:316 tunnel_enroll_cb() enrollment failed: CONTROLLER_UNAVAILABLE(-7)
[2022-12-12T04:26:17.870Z]   ERROR ziti-sdk:ziti.c:236 ziti_init_opts() D:/a/desktop-edge-win/desktop-edge-win/ziti-edge-tunnel/deps/ziti-tunneler-sdk-c/build/_deps/ziti-sdk-c-src/library/ziti.c:200 - load_config(options->config, &cfg) => -13 (Configuration is invalid)
[2022-12-12T04:26:17.870Z]   ERROR ziti-edge-tunnel:ziti-edge-tunnel.c:1109 load_id_cb() identity[C:\Windows\system32\config\systemprofile\AppData\Roaming/NetFoundry/http.client.json] failed to load: failed to initialize ziti
Some of the errors are inside the ziti-tunneler.log.
Is there something I’m missing out? Or if I want to start from scratch again, is it fine?
Yes that's totally fine. In your home directory, there will be a .ziti directory. You can just stop ziti-controller and ziti-router and then delete that whole $HOME/.ziti directory, exit your shell and then start again. @qrkourier actually has a small guide he's been working on showing people how to do exactly this so it's timely. You can find it here https://openziti.github.io/docs/quickstarts/network/help/reset-quickstart
As for the ZDEW, I would remove that identity by clicking on it and choosing 'forget this identity' and then stop it and start the client. That'll make sure it's cleaned up properly. I think you hit a bug around removing identities which I'll go file.
I still encounter the same problem with the ZDE; the identity would only appear after I disable and enable it again.
I check the log and the error shows the
[2022-12-13T01:24:03.091Z]   ERROR ziti-sdk:ziti_ctrl.c:154 ctrl_resp_cb() ctrl[ziti-edge-controller] request failed: -3008(unknown node or service)
[2022-12-13T01:24:03.091Z]   ERROR ziti-sdk:ziti_enroll.c:219 well_known_certs_cb() D:/a/desktop-edge-win/desktop-edge-win/ziti-edge-tunnel/deps/ziti-tunneler-sdk-c/build/_deps/ziti-sdk-c-src/library/ziti_enroll.c:148 - ZITI_JWT_VERIFICATION_FAILED => -7 (JWT verification failed)
[2022-12-13T01:24:03.091Z]   ERROR ziti-edge-tunnel:ziti-edge-tunnel.c:316 tunnel_enroll_cb() enrollment failed: CONTROLLER_UNAVAILABLE(-7)
The third error seems like my controller is not available. Moreover, for the next step, we need to zitiLogin. It seems like my zitiLogin says it is not authenticated.
error: unable to authenticate to https://ziti-edge-controller:1280/edge/management/v1. Status code: 401 Unauthorized, Server returned: {
    "error": {
        "code": "INVALID_AUTH",
        "requestId": "mU4-aj-nm"
    "meta": {
        "apiVersion": "0.0.1"
But before this, still able to zitiLogin.
And you’re doing all these steps “relatively” close together? Like within say, five minutes? Can you access https://ziti-edge-controller:1280/version successfully? If not, you need to make sure you update your hosts file. The error almost looks like the jwt is invalid.
If you can access that url, can you send me the jwt to look at? Email clint at openziti.org. Also can you send a feedback zip file? Go to main menu->feeback and send that zip file too?
Already changed that part to 600m since I followed the tutorial. Also, I cannot access the URL. I already sent the mail just now.
To access the URL, do I need to change this one too?
      - interface: 0.0.0.0:1280
        # address - required
That's what I expected. I'm glad to see that. Since you're using docker-compose you will need to update your hosts file. In your C:\Windows\System32\drivers\etc\hosts file you need to add:
#local docker-compose
127.0.0.1 ziti-edge-controller
127.0.0.1 ziti-edge-router
Once you do that, you'll be able to access the url https://ziti-edge-controller:1280/version. Then your enrollment should succeed as well.
Let's do these steps:
  • stop the ZDEW using the big green button
  • navigate to C:\Windows\System32\config\systemprofile\AppData\Roaming\NetFoundry - if there is a file named http.client.json delete it
  • update the hosts file as per above
  • make sure you can access https://ziti-edge-controller:1280/version
  • start your ZDEW
  • make a new identity
  • enroll it
It should succeed. One thing to note is that with this setup, other machines on your local network won't be available unless you update their hosts files too. I don't recommend you do that though, I'd recommend if you get to that point you probably want to deploy your docker-compose environment a bit differently so that other machines on the local network can access the controller and router. I'm assuming you only want to keep it all local though?
You should be able to enroll after doing those steps
If you’re not aware of it, I’d recommend you read up about what the hosts file is and why you’d want to edit it and why I’m recommending you update it. Check out hosts (file) - Wikipedia for example. It has some decent info.
Do you mean by success access the url it shows like this?
{"data":{"apiVersions":{"edge":{"v1":{"apiBaseUrls":["https://ziti-edge-controller:1280/edge/client/v1"],"path":"/edge/client/v1"}},"edge-client":{"v1":{"apiBaseUrls":["https://ziti-edge-controller:1280/edge/client/v1"],"path":"/edge/client/v1"}},"edge-management":{"v1":{"apiBaseUrls":["https://ziti-edge-controller:1280/edge/management/v1"],"path":"/edge/management/v1"}}},"buildDate":"2022-11-10T14:53:29Z","revision":"807dd591b1f5","runtimeVersion":"go1.19.2","version":"v0.26.11"},"meta":{}}
Yes. That means you were able to contact the controller. Enrollment should succeed now
It works now. Thank you so much. I’ve been watching and reading a lot of forums to find out why mine still cannot enrol. Have a good day :star_struck:
Glad we were able to get you going.
