Error httpRequest on ziti
Hello everyone,
I’m a developer and I’ve been running into some issues with my POST requests when using Ziti.
I’m working on Electron with JavaScript and have integrated the Ziti SDK. While I have several components involving Ziti, the one that puzzles me the most is a simple POST request that consistently fails and throws the error: “Failed to create threadsafe_function.”
I’ve tried different approaches and tests, but no matter what I attempt, the same error keeps coming back.
Would anyone have a lead or suggestion that might help me move forward?
Hi @dorianEliptec Welcome to our community! Can you tell me which version of the ziti-sdk-nodejs you are using?
Hello thank you, I have this version of the ziti-sdk-nodejs : ^0.20.0.
Hello, do you have a solution to this problem please ?
I am doing an upgrade of the node sdk to pull in the latest (embedded) c-sdk. But meanwhile, until that is available, can you please set the following env vars, then re-run your test, then post the log here:
ZITI_LOG=99
ZITI_NODE_LOG=99
Thanks.
dorian@pc-dr:~/Bureau/PiX$ npm run start
> pix@1.0.0 start
> ZITI_LOG=99 ZITI_NODE_LOG=99 electron .
[VERSIONS] {
  node: '22.19.0',
  acorn: '8.15.0',
  ada: '2.9.2',
  amaro: '1.1.0',
  ares: '1.34.5',
  brotli: '1.0.9',
  cjs_module_lexer: '2.1.0',
  cldr: '44.1',
  icu: '74.2',
  llhttp: '9.3.0',
  modules: '139',
  napi: '10',
  nbytes: '0.1.1',
  ncrypto: '0.0.1',
  nghttp2: '1.64.0',
  openssl: '0.0.0',
  simdjson: '3.13.0',
  simdutf: '7.3.3',
  sqlite: '3.50.4',
  tz: '2025b',
  undici: '6.21.2',
  unicode: '15.1',
  uv: '1.51.0',
  uvwasi: '0.0.21',
  v8: '14.0.365.4-electron.0',
  zlib: '1.3.1',
  zstd: '1.5.8',
  electron: '38.1.2',
  chrome: '140.0.7339.133'
MESA-INTEL: warning: Haswell Vulkan support is incomplete
libva error: /usr/lib/x86_64-linux-gnu/dri/iHD_drv_video.so init failed
[10696:0923/162142.453686:ERROR:CONSOLE:1] "Request Autofill.enable failed. {"code":-32601,"message":"'Autofill.enable' wasn't found"}", source: devtools://devtools/bundled/core/protocol_client/protocol_client.js (1)
[10696:0923/162142.453782:ERROR:CONSOLE:1] "Request Autofill.setAddresses failed. {"code":-32601,"message":"'Autofill.setAddresses' wasn't found"}", source: devtools://devtools/bundled/core/protocol_client/protocol_client.js (1)
(10696)[        0.000]    INFO ziti-sdk:utils.c:198 ziti_log_set_level() set log level: root=6/TRACE
(10696)[        0.000]    INFO ziti-sdk:utils.c:167 ziti_log_init() Ziti C SDK version 1.4.4 @g9a16a32(HEAD) starting at (2025-09-23T14:21:42.517)
(10696)[        0.773]    INFO ziti-sdk:ziti.c:519 ziti_start_internal() ztx[0] enabling Ziti Context
(10696)[        0.773]    INFO ziti-sdk:ziti.c:536 ziti_start_internal() ztx[0] using tlsuv[v0.33.6/OpenSSL 3.4.0 22 Oct 2024]
(10696)[        0.773]    INFO ziti-sdk:ziti_ctrl.c:626 ziti_ctrl_init() ctrl[(null):] using https://zpix.vigitronic.eu:8440/edge/client/v1
(10696)[        0.773]   DEBUG ziti-sdk:ziti_ctrl.c:640 ziti_ctrl_init() ctrl[zpix.vigitronic.eu:8440] ziti controller client initialized
(10696)[        0.773] VERBOSE ziti-sdk:ziti_ctrl.c:145 start_request() ctrl[zpix.vigitronic.eu:8440] starting GET[/version]
(10696)[        0.773]    INFO ziti-sdk:ziti.c:614 ztx_init_controller() ztx[0] Loading ziti context with controller[https://zpix.vigitronic.eu:8440/edge/client/v1]
(10696)[        0.773]   DEBUG ziti-sdk:ziti.c:545 ziti_start_internal() ztx[0] using metrics interval: 6
(10696)[        0.773]   DEBUG ziti-sdk:ziti.c:218 ziti_set_unauthenticated() ztx[0] setting auth_state[0] to 0
(10696)[        0.773]   DEBUG ziti-sdk:ziti_ctrl.c:379 ziti_ctrl_clear_api_session() ctrl[zpix.vigitronic.eu:8440] clearing api session token for ziti_controller
(10696)[        0.773]   DEBUG ziti-sdk:ziti_ctrl.c:1065 ctrl_paging_req() ctrl[zpix.vigitronic.eu:8440] starting paging request GET[/external-jwt-signers]
(10696)[        0.773] VERBOSE ziti-sdk:ziti_ctrl.c:1070 ctrl_paging_req() ctrl[zpix.vigitronic.eu:8440] requesting /external-jwt-signers?limit=25&offset=0
(10696)[        0.773] VERBOSE ziti-sdk:ziti_ctrl.c:145 start_request() ctrl[zpix.vigitronic.eu:8440] starting GET[/external-jwt-signers?limit=25&offset=0]
(10696)[        0.865] VERBOSE ziti-sdk:ziti_ctrl.c:200 ctrl_resp_cb() ctrl[zpix.vigitronic.eu:8440] received headers GET[/version]
(10696)[        0.865] VERBOSE ziti-sdk:ziti_ctrl.c:426 ctrl_body_cb() ctrl[zpix.vigitronic.eu:8440] HTTP RESPONSE: {"data":{"apiVersions":{"edge":{"v1":{"apiBaseUrls":["https://zpix.vigitronic.eu:8440/edge/client/v1"],"path":"/edge/client/v1"}},"edge-client":{"v1":{"apiBaseUrls":["https://zpix.vigitronic.eu:8440/edge/client/v1"],"path":"/edge/client/v1"}},"edge-management":{"v1":{"apiBaseUrls":["https://zpix.vigitronic.eu:8440/edge/management/v1"],"path":"/edge/management/v1"}},"edge-oidc":{"v1":{"apiBaseUrls":["https://zpix.vigitronic.eu:8440"],"path":"/oidc"}},"health-checks":{"v1":{"apiBaseUrls":[],"path":"/health-checks/v1"}}},"buildDate":"2025-07-25T17:21:06Z","capabilities":["OIDC_AUTH"],"revision":"207d28c6bdee","runtimeVersion":"go1.24.1","version":"v1.6.6"},"meta":{}}
(10696)[        0.865]   DEBUG ziti-sdk:ziti_ctrl.c:499 ctrl_body_cb() ctrl[zpix.vigitronic.eu:8440] completed GET[/version] in 0.077 s
(10696)[        0.865]    INFO ziti-sdk:ziti.c:1928 version_pre_auth_cb() ztx[0] connected to Legacy controller https://zpix.vigitronic.eu:8440/edge/client/v1 version v1.6.6(207d28c6bdee 2025-07-25T17:21:06Z)
(10696)[        0.866] VERBOSE ziti-sdk:ziti_ctrl.c:145 start_request() ctrl[zpix.vigitronic.eu:8440] starting POST[/authenticate?method=cert]
(10696)[        0.891] VERBOSE ziti-sdk:ziti_ctrl.c:200 ctrl_resp_cb() ctrl[zpix.vigitronic.eu:8440] received headers GET[/external-jwt-signers?limit=25&offset=0]
(10696)[        0.891] VERBOSE ziti-sdk:ziti_ctrl.c:426 ctrl_body_cb() ctrl[zpix.vigitronic.eu:8440] HTTP RESPONSE: {"data":[],"meta":{"filterableFields":["id","updatedAt","issuer","notBefore","enabled","createdAt","tags","isSystem","name","certPem","notAfter","clientId","kid","claimsProperty","useExternalId","scopes","targetToken","fingerprint","commonName","audience"],"pagination":{"limit":25,"offset":0,"totalCount":0}}}
(10696)[        0.891]   DEBUG ziti-sdk:ziti_ctrl.c:484 ctrl_body_cb() ctrl[zpix.vigitronic.eu:8440] received 0/0 for paging request GET[/external-jwt-signers]
(10696)[        0.891]   DEBUG ziti-sdk:ziti_ctrl.c:494 ctrl_body_cb() ctrl[zpix.vigitronic.eu:8440] completed paging request GET[/external-jwt-signers] in 0.103 s
(10696)[        0.891]   DEBUG ziti-sdk:ziti.c:675 ext_jwt_singers_cb() ztx[0] 0 external auth providers available
(10696)[        0.907] VERBOSE ziti-sdk:ziti_ctrl.c:200 ctrl_resp_cb() ctrl[zpix.vigitronic.eu:8440] received headers POST[/authenticate?method=cert]
(10696)[        0.907] VERBOSE ziti-sdk:ziti_ctrl.c:426 ctrl_body_cb() ctrl[zpix.vigitronic.eu:8440] HTTP RESPONSE: {"data":{"_links":{"self":{"href":"./api-sessions/cmfwn8rcnyv8aeldvdoht12hw"},"sessions":{"href":"./api-sessions/cmfwn8rcnyv8aeldvdoht12hw/sessions"}},"createdAt":"2025-09-23T14:21:42.647Z","id":"cmfwn8rcnyv8aeldvdoht12hw","tags":{},"updatedAt":"2025-09-23T14:21:42.647Z","authQueries":[],"authenticatorId":"f44srmdmH","cachedLastActivityAt":"2025-09-23T14:21:42.647Z","configTypes":["all"],"identity":{"_links":{"auth-policies":{"href":"./auth-policies/default"},"authenticators":{"href":"./identities/zKzQx4d4AF/authenticators"},"edge-router-policies":{"href":"./identities/zKzQx4d4AF/edge-router-policies"},"edge-routers":{"href":"./identities/zKzQx4d4AF/edge-routers"},"enrollments":{"href":"./identities/zKzQx4d4AF/enrollments"},"failed-service-requests":{"href":"./identities/zKzQx4d4AF/failed-service-requests"},"posture-data":{"href":"./identities/zKzQx4d4AF/posture-data"},"self":{"href":"./identities/zKzQx4d4AF"},"service-configs":{"href":"./identities/zKzQx4d4AF/ser
(10696)[        0.907]   DEBUG ziti-sdk:ziti_ctrl.c:499 ctrl_body_cb() ctrl[zpix.vigitronic.eu:8440] completed POST[/authenticate?method=cert] in 0.041 s
(10696)[        0.907]   DEBUG ziti-sdk:ziti_ctrl.c:393 ctrl_login_cb() ctrl[zpix.vigitronic.eu:8440] authenticated successfully session[cmfwn8rcnyv8aeldvdoht12hw]
(10696)[        0.907]   DEBUG ziti-sdk:legacy_auth.c:171 login_cb() logged in successfully => api_session[cmfwn8rcnyv8aeldvdoht12hw]
(10696)[        0.907]   DEBUG ziti-sdk:ziti.c:371 ziti_set_fully_authenticated() ztx[0] setting auth_state[0] to 3
(10696)[        0.907] VERBOSE ziti-sdk:ziti_ctrl.c:145 start_request() ctrl[zpix.vigitronic.eu:8440] starting GET[/.well-known/est/cacerts]
(10696)[        0.907] VERBOSE ziti-sdk:ziti_ctrl.c:145 start_request() ctrl[zpix.vigitronic.eu:8440] starting GET[/current-identity]
(10696)[        0.907] VERBOSE ziti-sdk:ziti.c:1436 ziti_services_refresh() ztx[0] forcing service refresh
(10696)[        0.907]   TRACE ziti-sdk:legacy_auth.c:263 refresh_delay() API supports cached_last_activity_at
(10696)[        0.907]   DEBUG ziti-sdk:legacy_auth.c:293 refresh_delay() api session set, next refresh in 3540s
(10696)[        0.908] VERBOSE ziti-sdk:ziti_ctrl.c:145 start_request() ctrl[zpix.vigitronic.eu:8440] starting GET[/current-identity]
(10696)[        0.908]   DEBUG ziti-sdk:ziti_ctrl.c:1065 ctrl_paging_req() ctrl[zpix.vigitronic.eu:8440] starting paging request GET[/current-identity/edge-routers]
(10696)[        0.908] VERBOSE ziti-sdk:ziti_ctrl.c:1070 ctrl_paging_req() ctrl[zpix.vigitronic.eu:8440] requesting /current-identity/edge-routers?limit=25&offset=0
(10696)[        0.908] VERBOSE ziti-sdk:ziti_ctrl.c:145 start_request() ctrl[zpix.vigitronic.eu:8440] starting GET[/current-identity/edge-routers?limit=25&offset=0]
(10696)[        0.908] VERBOSE ziti-sdk:ziti_ctrl.c:145 start_request() ctrl[zpix.vigitronic.eu:8440] starting GET[/current-api-session/service-updates]
(10696)[        0.922] VERBOSE ziti-sdk:ziti_ctrl.c:200 ctrl_resp_cb() ctrl[zpix.vigitronic.eu:8440] received headers GET[/.well-known/est/cacerts]
(10696)[        0.938] VERBOSE ziti-sdk:ziti_ctrl.c:200 ctrl_resp_cb() ctrl[zpix.vigitronic.eu:8440] received headers GET[/current-identity]
(10696)[        0.938] VERBOSE ziti-sdk:ziti_ctrl.c:426 ctrl_body_cb() ctrl[zpix.vigitronic.eu:8440] HTTP RESPONSE: {"data":{"_links":{"mfa":{"href":"./current-identity/mfa"},"self":{"href":"./current-identity"}},"createdAt":"2025-09-15T06:54:45.901Z","id":"zKzQx4d4AF","tags":{"type":"Term"},"updatedAt":"2025-09-23T07:28:11.743Z","appData":{},"authPolicy":{"_links":{"self":{"href":"./auth-policies/default"}},"entity":"auth-policies","id":"default","name":"Default"},"authPolicyId":"default","authenticators":{"cert":{"fingerprint":"81739062db6c81cded9cef4648f63997eae3754a","id":"f44srmdmH"}},"defaultHostingCost":0,"defaultHostingPrecedence":"default","disabled":false,"edgeRouterConnectionStatus":"offline","enrollment":{},"envInfo":{"arch":"x86_64","domain":"(none)","hostname":"pc-dr","os":"Linux","osRelease":"6.1.0-39-amd64","osVersion":"#1 SMP PREEMPT_DYNAMIC Debian 6.1.148-1 (2025-08-26)"},"externalId":null,"hasApiSession":true,"hasEdgeRouterConnection":false,"interfaces":null,"isAdmin":false,"isDefaultAdmin":false,"isMfaEnabled":false,"name":"335aa6dd-e67b-42b9-a5eb-0eb1919328
(10696)[        0.938]   DEBUG ziti-sdk:ziti_ctrl.c:499 ctrl_body_cb() ctrl[zpix.vigitronic.eu:8440] completed GET[/current-identity] in 0.031 s
(10696)[        0.953] VERBOSE ziti-sdk:ziti_ctrl.c:200 ctrl_resp_cb() ctrl[zpix.vigitronic.eu:8440] received headers GET[/current-identity]
(10696)[        0.953] VERBOSE ziti-sdk:ziti_ctrl.c:426 ctrl_body_cb() ctrl[zpix.vigitronic.eu:8440] HTTP RESPONSE: {"data":{"_links":{"mfa":{"href":"./current-identity/mfa"},"self":{"href":"./current-identity"}},"createdAt":"2025-09-15T06:54:45.901Z","id":"zKzQx4d4AF","tags":{"type":"Term"},"updatedAt":"2025-09-23T07:28:11.743Z","appData":{},"authPolicy":{"_links":{"self":{"href":"./auth-policies/default"}},"entity":"auth-policies","id":"default","name":"Default"},"authPolicyId":"default","authenticators":{"cert":{"fingerprint":"81739062db6c81cded9cef4648f63997eae3754a","id":"f44srmdmH"}},"defaultHostingCost":0,"defaultHostingPrecedence":"default","disabled":false,"edgeRouterConnectionStatus":"offline","enrollment":{},"envInfo":{"arch":"x86_64","domain":"(none)","hostname":"pc-dr","os":"Linux","osRelease":"6.1.0-39-amd64","osVersion":"#1 SMP PREEMPT_DYNAMIC Debian 6.1.148-1 (2025-08-26)"},"externalId":null,"hasApiSession":true,"hasEdgeRouterConnection":false,"interfaces":null,"isAdmin":false,"isDefaultAdmin":false,"isMfaEnabled":false,"name":"335aa6dd-e67b-42b9-a5eb-0eb1919328
(10696)[        0.953]   DEBUG ziti-sdk:ziti_ctrl.c:499 ctrl_body_cb() ctrl[zpix.vigitronic.eu:8440] completed GET[/current-identity] in 0.045 s
(10696)[        0.967] VERBOSE ziti-sdk:ziti_ctrl.c:200 ctrl_resp_cb() ctrl[zpix.vigitronic.eu:8440] received headers GET[/current-identity/edge-routers?limit=25&offset=0]
(10696)[        0.967] VERBOSE ziti-sdk:ziti_ctrl.c:426 ctrl_body_cb() ctrl[zpix.vigitronic.eu:8440] HTTP RESPONSE: {"data":[{"_links":{"edge-router-policies":{"href":"./edge-routers/S.OmCR3eox/edge-router-policies"},"self":{"href":"./edge-routers/S.OmCR3eox"}},"createdAt":"2025-04-21T12:53:48.329Z","id":"S.OmCR3eox","tags":{},"updatedAt":"2025-09-04T19:00:36.045Z","cost":null,"disabled":null,"hostname":"","isOnline":true,"name":"zpixr01","noTraversal":null,"supportedProtocols":{"tls":"tls://zpixr01.vigitronic.eu:8442"},"syncStatus":"SYNC_DONE"}],"meta":{"filterableFields":["online","noTraversal","name","isSystem","disabled","updatedAt","tags","isTunnelerEnabled","cost","id","fingerprint","roleAttributes","isVerified","createdAt","connected"],"pagination":{"limit":25,"offset":0,"totalCount":1}}}
(10696)[        0.967]   DEBUG ziti-sdk:ziti_ctrl.c:484 ctrl_body_cb() ctrl[zpix.vigitronic.eu:8440] received 1/1 for paging request GET[/current-identity/edge-routers]
(10696)[        0.967]   DEBUG ziti-sdk:ziti_ctrl.c:494 ctrl_body_cb() ctrl[zpix.vigitronic.eu:8440] completed paging request GET[/current-identity/edge-routers] in 0.062 s
(10696)[        0.967]   TRACE ziti-sdk:ziti.c:1482 edge_routers_cb() ztx[0] connecting to zpixr01(tls://zpixr01.vigitronic.eu:8442)
(10696)[        0.967]    INFO ziti-sdk:channel.c:272 new_ziti_channel() ch[0] (zpixr01) new channel for ztx[0] identity[335aa6dd-e67b-42b9-a5eb-0eb19193288e.zpix]
(10696)[        0.967]    INFO ziti-sdk:channel.c:819 reconnect_channel() ch[0] reconnecting NOW
(10696)[        0.971]   DEBUG ziti-sdk:channel.c:785 reconnect_cb() ch[0] connecting to tls://zpixr01.vigitronic.eu:8442
(10696)[        0.987] VERBOSE ziti-sdk:ziti_ctrl.c:200 ctrl_resp_cb() ctrl[zpix.vigitronic.eu:8440] received headers GET[/current-api-session/service-updates]
(10696)[        0.987] VERBOSE ziti-sdk:ziti_ctrl.c:426 ctrl_body_cb() ctrl[zpix.vigitronic.eu:8440] HTTP RESPONSE: {"data":{"lastChangeAt":"2025-09-15T06:54:45.909Z"},"meta":{}}
(10696)[        0.987]   DEBUG ziti-sdk:ziti_ctrl.c:499 ctrl_body_cb() ctrl[zpix.vigitronic.eu:8440] completed GET[/current-api-session/service-updates] in 0.079 s
(10696)[        0.987] VERBOSE ziti-sdk:ziti.c:1406 check_service_update() ztx[0] ztx last_update = 2025-09-15T06:54:45.909Z
(10696)[        0.987]   DEBUG ziti-sdk:ziti_ctrl.c:1065 ctrl_paging_req() ctrl[zpix.vigitronic.eu:8440] starting paging request GET[/services?configTypes=all]
(10696)[        0.987] VERBOSE ziti-sdk:ziti_ctrl.c:1070 ctrl_paging_req() ctrl[zpix.vigitronic.eu:8440] requesting /services?configTypes=all&limit=25&offset=0
(10696)[        0.987] VERBOSE ziti-sdk:ziti_ctrl.c:145 start_request() ctrl[zpix.vigitronic.eu:8440] starting GET[/services?configTypes=all&limit=25&offset=0]
(10696)[        1.002] VERBOSE ziti-sdk:ziti_ctrl.c:200 ctrl_resp_cb() ctrl[zpix.vigitronic.eu:8440] received headers GET[/services?configTypes=all&limit=25&offset=0]
(10696)[        1.002] VERBOSE ziti-sdk:ziti_ctrl.c:426 ctrl_body_cb() ctrl[zpix.vigitronic.eu:8440] HTTP RESPONSE: {"data":[{"_links":{"configs":{"href":"./services/6yT6ZZqkrBKv9TluLZkOCQ/configs"},"self":{"href":"./services/6yT6ZZqkrBKv9TluLZkOCQ"},"service-edge-router-policies":{"href":"./services/6yT6ZZqkrBKv9TluLZkOCQ/service-edge-router-policies"},"service-policies":{"href":"./services/6yT6ZZqkrBKv9TluLZkOCQ/service-policies"},"terminators":{"href":"./services/6yT6ZZqkrBKv9TluLZkOCQ/terminators"}},"createdAt":"2025-07-31T09:16:05.401Z","id":"6yT6ZZqkrBKv9TluLZkOCQ","tags":{},"updatedAt":"2025-09-12T05:55:54.721Z","config":{"host.v1":{"address":"localhost","listenOptions":{"bindUsingEdgeIdentity":true},"port":2612,"protocol":"tcp"},"intercept.v1":{"addresses":["winpreprod.zpix","vigicloud.zpix"],"dialOptions":{"identity":"$dst_hostname"},"portRanges":[{"high":2612,"low":2612}],"protocols":["tcp"]}},"configs":["45rCWr913oSR3Ivl55TYzL","q2Up7IFp38ntc6r05O2Gq"],"encryptionRequired":true,"maxIdleTimeMillis":0,"name":"2612","permissions":["Dial"],"postureQueries":[{"isPassing":
(10696)[        1.002]   DEBUG ziti-sdk:ziti_ctrl.c:484 ctrl_body_cb() ctrl[zpix.vigitronic.eu:8440] received 2/2 for paging request GET[/services?configTypes=all]
(10696)[        1.002]   DEBUG ziti-sdk:ziti_ctrl.c:494 ctrl_body_cb() ctrl[zpix.vigitronic.eu:8440] completed paging request GET[/services?configTypes=all] in 0.014 s
(10696)[        1.002] VERBOSE ziti-sdk:ziti.c:1438 ziti_services_refresh() ztx[0] scheduling service refresh 60 seconds from now
(10696)[        1.002] VERBOSE ziti-sdk:ziti.c:1276 update_services() ztx[0] processing service updates
(10696)[        1.002]   DEBUG ziti-sdk:ziti.c:1353 update_services() ztx[0] sending service event initial[true] 2 added, 0 removed, 0 changed
✅ SDK Ziti initialisé sur /home/dorian/Bureau/PiX/ziti/temp.json
(10696)[        1.062]   DEBUG ziti-sdk:channel.c:954 on_tls_connect() ch[0] connected alpn[ziti-edge]
(10696)[        1.062]   TRACE ziti-sdk:channel.c:420 ziti_channel_send_message() ch[0] => ct[0000] seq[1] len[19]
(10696)[        1.062]   TRACE ziti-sdk:channel.c:390 on_channel_send() ch[0] write delay = 0.000d q=1 qs=92
(10696)[        1.080]   TRACE ziti-sdk:channel.c:920 on_channel_data() ch[0] read no data
(10696)[        1.094]   TRACE ziti-sdk:channel.c:920 on_channel_data() ch[0] read no data
(10696)[        1.107]   TRACE ziti-sdk:channel.c:925 on_channel_data() ch[0] on_data [len=140]
(10696)[        1.107]   TRACE ziti-sdk:channel.c:595 process_inbound() ch[0] <= ct[0002] seq[-1] len[0] hdrs[120]
(10696)[        1.107]   TRACE ziti-sdk:channel.c:606 process_inbound() ch[0] completing msg seq[-1] body+hrds=0+120, in_offset=0, want=120, got=120
(10696)[        1.107]   TRACE ziti-sdk:channel.c:620 process_inbound() ch[0] message is complete seq[-1] ct[0002]
(10696)[        1.107]   TRACE ziti-sdk:message.c:91 parse_hdrs() parsing headers len[120]
(10696)[        1.107]   TRACE ziti-sdk:message.c:104 parse_hdrs() hdr[0] id[2] len[1]
(10696)[        1.107]   TRACE ziti-sdk:message.c:104 parse_hdrs() hdr[1] id[4] len[52]
(10696)[        1.107]   TRACE ziti-sdk:message.c:104 parse_hdrs() hdr[2] id[1024] len[1]
(10696)[        1.107]   TRACE ziti-sdk:message.c:104 parse_hdrs() hdr[3] id[0] len[4]
(10696)[        1.107]   TRACE ziti-sdk:message.c:104 parse_hdrs() hdr[4] id[8] len[10]
(10696)[        1.107]   TRACE ziti-sdk:message.c:104 parse_hdrs() hdr[5] id[1] len[4]
(10696)[        1.107]    INFO ziti-sdk:channel.c:717 hello_reply_cb() ch[0] connected. EdgeRouter version: v1.6.6|207d28c6bdee|2025-07-25T17:21:06Z|linux|amd64
(10696)[        1.107]   TRACE ziti-sdk:channel.c:920 on_channel_data() ch[0] read no data
(10696)[        1.909] VERBOSE ziti-sdk:posture.c:201 ziti_send_posture_data() ztx[0] starting to send posture data
(10696)[        1.909]    INFO ziti-sdk:posture.c:211 ziti_send_posture_data() ztx[0] first run or potential controller restart detected
(10696)[        1.909]   DEBUG ziti-sdk:posture.c:215 ziti_send_posture_data() ztx[0] posture checks must_send set to TRUE, new_session_id[TRUE], must_send_every_time[TRUE], new_controller_instance[TRUE]
(10696)[        1.909] VERBOSE ziti-sdk:posture.c:244 ziti_send_posture_data() ztx[0] checking posture queries on 2 service(s)
(10696)[        1.909] VERBOSE ziti-sdk:posture.c:611 ziti_pr_send_bulk() ztx[0] no change in posture data, not sending
[10732:0923/162145.658150:ERROR:ui/gl/gl_surface_presentation_helper.cc:260] GetVSyncParametersIfAvailable() failed for 1 times!
[10732:0923/162145.661162:ERROR:ui/gl/gl_surface_presentation_helper.cc:260] GetVSyncParametersIfAvailable() failed for 2 times!
[10732:0923/162145.671004:ERROR:ui/gl/gl_surface_presentation_helper.cc:260] GetVSyncParametersIfAvailable() failed for 3 times!
(10696)[       21.923] VERBOSE ziti-sdk:posture.c:201 ziti_send_posture_data() ztx[0] starting to send posture data
(10696)[       21.923]   DEBUG ziti-sdk:posture.c:215 ziti_send_posture_data() ztx[0] posture checks must_send set to TRUE, new_session_id[FALSE], must_send_every_time[TRUE], new_controller_instance[FALSE]
(10696)[       21.923] VERBOSE ziti-sdk:posture.c:244 ziti_send_posture_data() ztx[0] checking posture queries on 2 service(s)
(10696)[       21.923] VERBOSE ziti-sdk:posture.c:611 ziti_pr_send_bulk() ztx[0] no change in posture data, not sending
That all i have :thinking:
Hmmm. I do not see the Failed to create threadsafe_function issue in your log.
only in the toggle developers tools and in the application not on the terminal
Do you have a solution? For the moment, I’m using the tunnelers, but I need to use the SDK.
