Facing this error when I try zrok share private --backend-mode web after configuring the api endpoint in a instance node pointing to the self hosted zrok-ziti controller-router.
│[ 0.733] ERROR main.(*sharePrivateCommand).run.func3: error running http web backend: loading new config: http app│
│module: start: listening on zrok/{token}:0: failed to listen: no apiSession, authentication attempt failed: Get │
│"https://ziti.{hostname}:8441/oidc/authorize?client_id=native&code_challenge=│
│&code_challenge_method=S256&method=cert&prompt=Welcome+back%21&redirect_uri=http%3│ redirect is not allowed as per DomainCheckRedirectPolicy
I am able to see the nodes connecting from the dashboard, but no fetch calls are being transmitted.
Thanks for reaching out @michael.quigley, here's the situation:
The dashboard shows that both the nodes are connecting off the deployed self hosted zrok node:
But I am facing this error when I try to use any share mechanism from my local instance to another instance, configured to use this hosted relayer node:
