Failed to enroll: expected 1 or more CAs from controller, got 0
I verified two external CAs with my controller running in the Docker Compose quickstart and got an error when I tried to auto-enroll with a client cert from the CA that has autoca enabled.
the verified external autoca CA
$ ziti edge list cas 'name="magenta"'
│ ID                     │ NAME    │ FLAGS  │ TOKEN │ FINGERPRINT │ CONFIGURATION                                                 │
│ 1AmYoBfMGi5TZMLhjEyOAf │ magenta │ [VAE]  │ -     │ 4e85...32   │ AutoCA        │ Identity Name Format │ [caName]-[commonName]  │
│                        │         │        │       │             │               │ Identity Roles       │                        │
results: 1-1 of 1
Flags: (V) Verified, (A) AutoCa Enrollment, (O) OttCA Enrollment, (E) Authentication Enabled
The enrollment attempt
$ ziti edge enroll \
        --cert ~/.config/ziti/environments/pki/magenta/certs/kentest2.cert \
        --key ~/.config/ziti/environments/pki/magenta/keys/kentest2.key \
        --jwt /tmp/magenta.jwt \
        --out /tmp/kentest2.json \
        --verbose
DEBUG   jwt to parse: eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCJ9.eyJlbSI6ImNhIiwiaXNzIjoiaHR0cHM6Ly96aXRpLWVkZ2UtY29udHJvbGxlcjoxMjgwLyJ9.pd8BdLDugCtijAa-c81TOJyP3qaPeA-rmSeLqatpmPgXnssfm7J905-2gsCXk_r2ASeoWgyNtBavXhDJOOCK3fZT7nNz6jhO-Zqlcn1pjb-dLG7UjLjiCf6W01Ri8n9yywS6Jm_HKv3Ysw0te_zsMe5sWrUBz3XzY1Lqg_f7bWeMRX21loSNEqjjtQz_IajHzHfJphyUeprwu4K39_CAFFujk743FWlOel0Ju1wqN6DT4mjsY4e7GLiAFGDZYaDl2qVkYoBdOcH9Md6KhdAJyahVgEazaqE6M4A6FLDJBXx9x9V2LkUtSxKQYLmStwhioOFEp-RiFmXEHnACBH2CE8dOMb8TuelBq296C0UT_2N9JqFmAWJCMnFrGIBBjt-XoiXoEFDRZlvOrp0J2C3N6OxvdmsMW5RSZmDLkW3lA_KPyxzoX1Hawb5XNNeHFRKSUD4yjU3EdTRo0-YSTJAHjuS6ys1v-iqGkGBKCUh5k-rG4g9y-Xp9Lbr6NU-8G-TNzc34ygydWoC0EDr9CME6h62wVx_48xxVOQ8h7POKTGPxZjGE63k6cbn-2iwbRpLKDH5F8GvrcAn3jcLJUVwcLJGIw9ICYuCschKeGmuVS9mBsoTfDmTGvnuUHXAm2Z4M84SIhfNqXhtSlyY17T9POvuzx7waoSBIymUx4hWMtKA
DEBUG   fetching certificates from server
Usage:
  ziti edge enroll path/to/jwt [flags]
Flags:
      --ca string         Additional trusted certificates
  -c, --cert string       The certificate to present when establishing a connection.
  -h, --help              help for enroll
  -n, --idname string     Names the identity. Ignored if not 3rd party auto enrollment
  -j, --jwt string        Enrollment token (JWT file). Required
  -k, --key string        The key to use with the certificate. Optionally specify the engine to use. supported engines: [parsec]
  -a, --keyAlg RSA|EC     Crypto algorithm to use when generating private key (default RSA)
  -o, --out string        Output configuration file.
  -p, --password string   Password for updb enrollment, prompted if not provided and necessary
      --rm                Remove the JWT on success
  -u, --username string   Username for updb enrollment, prompted if not provided and necessary
  -v, --verbose           Enable verbose logging
failed to enroll: expected 1 or more CAs from controller, got 0
CA enroll token
Exepectedly, the reusable autoca enroll token contains the issuer URL where the client certificate should be presented to complete enrollment.
  "em": "ca",
  "iss": "https://ziti-edge-controller:1280/"
the issuer API
Expectedly, the Ziti controller provdes its edge client API at the issuer URL.
curl -sk https://ziti-edge-controller:1280/edge/client/v1 | jq
  "data": {
    "apiVersions": {
      "edge": {
        "v1": {
          "apiBaseUrls": [
            "https://ziti-edge-controller:1280/edge/client/v1"
          "path": "/edge/client/v1"
      "edge-client": {
        "v1": {
          "apiBaseUrls": [
      "edge-management": {
        "v1": {
          "apiBaseUrls": [
            "https://ziti-edge-controller:1280/edge/management/v1"
          "path": "/edge/management/v1"
    "buildDate": "2023-06-23T15:08:25Z",
    "revision": "65d1dda821a3",
    "runtimeVersion": "go1.20.5",
    "version": "v0.28.4"
  "meta": {}
Troubleshooting
Which client API endpoint provides the list of external CAs that the enrolling edge SDK is attempting to obtain when it emits this error?
This error appears in the Go SDK's enroll.go after calling ListWellKnownCas.
It appears to be the same well-known certs bundle endpoint consumed by all edge clients during enrollment of client certs from the built-in edge enrollment signer, /.well-known/est/cacerts.
I verified that ott and ottca enrollment methods succeed with ziti edge enroll CLI and do result in an identity context JSON file with appropriate values, i.e., in-line cert from edge enrollment signer for ott method, and file:// URI to cert from external CA for ottca method.
I tried autoca with Ziti 0.28.0 and obtained a different result.
│ 7LN2KHZ7m1ZS97o1n9inJ1 │ magenta │ [VAE]  │ -     │ 79e0...1b   │ AutoCA          │ Identity Name Format │ [caName]-[commonName]  │
│                        │         │        │       │             │ ExternalIdClaim │ Index                │ 0                      │
│                        │         │        │       │             │                 │ Location             │                        │
│                        │         │        │       │             │                 │ Matcher              │                        │
│                        │         │        │       │             │                 │ Matcher Criteria     │                        │
│                        │         │        │       │             │                 │ Parser               │                        │
│                        │         │        │       │             │                 │ Parser Criteria      │                        │
results: 1-1 of 1
$ ziti edge enroll --cert ${ZITI_PKI_ROOT}/magenta/certs/${ZITI_CLIENT}.cert  --key ${ZITI_PKI_ROOT}/magenta/keys/${ZITI_CLIENT}.key --jwt /tmp/magenta.jwt --out /tmp/${ZITI_CLIENT}.json
Usage:
Flags:
failed to enroll: enroll error: 400 Bad Request: MISSING_CERT_CLAIM: The certificate is expected to contain and externalId, which was not found
