Hi @0xRy4n, welcome to the community and to zrok! (and OpenZiti/BrowZer)
I'm not exactly sure how you deployed zrok to begin with. If it was me, I would probably try to find the services that are running, trace the config files back and figure it out from there.
You could do sudo ss -lntp and find what process has the port and go from there?
sudo ss -lntp
State Recv-Q Send-Q Local Address:Port Peer Address:Port Process
LISTEN 0 4096 0.0.0.0:2000 0.0.0.0:* users:(("docker-proxy",pid=182459,fd=4))
LISTEN 0 511 0.0.0.0:8445 0.0.0.0:* users:(("nginx",pid=181396,fd=9),("nginx",pid=181395,fd=9))
LISTEN 0 4096 0.0.0.0:8446 0.0.0.0:* users:(("docker-proxy",pid=182390,fd=4))
LISTEN 0 4096 0.0.0.0:4100 0.0.0.0:* users:(("docker-proxy",pid=182386,fd=4))
LISTEN 0 128 0.0.0.0:22 0.0.0.0:* users:(("sshd",pid=2102618,fd=3))
LISTEN 0 4096 0.0.0.0:443 0.0.0.0:* users:(("docker-proxy",pid=182380,fd=4))
LISTEN 0 4096 0.0.0.0:8558 0.0.0.0:* users:(("docker-proxy",pid=2222548,fd=4))
LISTEN 0 511 0.0.0.0:8448 0.0.0.0:* users:(("nginx",pid=181396,fd=10),("nginx",pid=181395,fd=10))
LISTEN 0 4096 127.0.0.53%lo:53 0.0.0.0:* users:(("systemd-resolve",pid=2102625,fd=14))
LISTEN 0 4096 [::]:2000 [::]:* users:(("docker-proxy",pid=182486,fd=4))
LISTEN 0 4096 *:10080 *:* users:(("ziti",pid=181692,fd=7))
LISTEN 0 4096 [::]:8446 [::]:* users:(("docker-proxy",pid=182403,fd=4))
LISTEN 0 4096 *:8441 *:* users:(("ziti",pid=181273,fd=10))
LISTEN 0 4096 *:6262 *:* users:(("ziti",pid=181273,fd=9))
LISTEN 0 4096 [::]:4100 [::]:* users:(("docker-proxy",pid=182407,fd=4))
LISTEN 0 128 [::]:22 [::]:* users:(("sshd",pid=2102618,fd=4))
LISTEN 0 4096 [::]:443 [::]:* users:(("docker-proxy",pid=182388,fd=4))
LISTEN 0 4096 [::]:8558 [::]:* users:(("docker-proxy",pid=2222554,fd=4))
LISTEN 0 4096 *:8505 *:* users:(("ziti",pid=181692,fd=9))
LISTEN 0 4096 *:3022 *:* users:(("ziti",pid=181692,fd=8))
LISTEN 0 4096 *:9001 *:* users:(("zrok",pid=181634,fd=3))
LISTEN 0 4096 *:9000 *:* users:(("zrok",pid=181495,fd=10))
