First, thanks for making OpenZiti.
We're running a 3-node HA controller cluster (v2.0.0-pre10) behind an AWS NLB. All three nodes are healthy, fully connected, and Raft consensus is working correctly (ziti agent cluster list shows all three connected with a stable leader).
When an enrollment token is created and then consumed, if the NLB routes the consumption request to a follower, we get one of two behaviors:
400 INVALID_ENROLLMENT_TOKENimmediately (fast fail) -
60 second timeout before failure
We expected follower controllers to forward write requests to the leader transparently, as described in the HA docs. This appears to work for other operations but not for enrollment token consumption.
We attempted to set edge.api.address to a per-node address on each controller so that inter-controller forwarding wouldn't loop back through the NLB. However this breaks OIDC login because edge.api.address also controls the OIDC issuer URL, which must match the address clients connect to via the NLB.
This is our config for each controller instance:
v: 3
cluster:
dataDir: /var/lib/private/ziti-controller/raft
ctrl:
listener: tls:0.0.0.0:6262
advertiseAddress: tls:controller-1.<env>.example.net:6262
edge:
api:
address: controller.<env>.example.net:1280
web:
- name: all-apis
bindPoints:
- interface: 0.0.0.0:1280
apis:
- binding: health-checks
- binding: fabric
- binding: edge-management
- binding: edge-client
- binding: edge-oidc
We want to understand Is enrollment token consumption excluded from follower-to-leader forwarding. And is there a supported config pattern for separating the inter-controller forwarding address from the edge.api.address OIDC issuer URL in an NLB deployment?
