Hostname Resolution With Homarr/nextjs
Thanks. That's an important detail!
OK, to restate the essential details: only Homarr consistently fails to look up the address in Ziti DNS. It's a Next.js application running in Alpine w/ MUSL. The Ziti nameserver is provided by a ziti tunnel tproxy sidecar container sharing the pod interface with Homarr. The same Ziti address can be resolved in the same Homarr container by running curl, dig, or drill, ruling out the possibility that MUSL is breaking Ziti DNS because the same call to getaddrinfo is used by cURL.
Is Homarr configured like AUTH_OIDC_URI=auth.domain.com? I'm wondering precisely which part of Homarr is failing to look up that domain name. At a glance, Homarr is only using system call getaddrinfo, not doing any DNS tricks.
from: homarr/src/env.js at master · ajnart/homarr · GitHub
Based on the Dockerfile you linked earlier, are you using container image ghcr.io/homarr-labs/homarr:v1.13.0?
EDIT: I incorrectly assumed cURL was using getaddrinfo (asking the OS to resolve the name in Ziti DNS), when in fact cURL was built for Alpine to use ares_getaddrinfo (c-ares - Alpine Linux packages), so curl, dig, and drill are each using an alternative DNS resolver configuration, and only Homarr is using the pod's full DNS config.
Now I'll confirm whether getaddrinfo ever works with ziti tunnel's NS.
Sure thing!
That all seems correct :slight_smile:
Yes, the environment variable is set as such: AUTH_OIDC_ISSUER: https://auth.domain.com/realms/realmname.
From what I can tell, nothing odd with DNS.
Yes :slight_smile:
Ah, well spotted!
My suspicion is that does not :slight_smile:
@qrkourier Have you been able to poke around? :slight_smile:
Yes, I poked around and found some scenarios where leveraging Alpine-based applications with TPROXY mode is unreliable or impossible.
I've documented the issues w/ MUSL in:
There's no appealing workaround, though it is possible to manage this by running a separate nameserver like dnsmasq.
TL;DR Alpine-based containers that rely on the OS's resolver are currently unable to discover Ziti intercepts by domain name
