I know how to load a new identity via enrollment token, but what if wish to pre-enroll identities using certificates from my own organization’s trusted CA? I can generate the identity config file, but I’m not sure how to tell Ziti Desktop Edge for Windows how to use the config file. It only seems to accept JWT files.
Adding a 3rd party CA is a feature that hasn't been implemented yet in the ZDEW yet. You can manually import the .json file by dropping the identity into this folder: %WINDIR%\System32\config\systemprofile\AppData\Roaming\NetFoundry and then restarting the ziti service using the 'big button' in the UI or net stop/start ziti from an admin prompt.
I haven't tested it but as long as the paths are correct I would expect it work work fine. It's just not "easy"...
I’ve filed a ticket to add support to ZDEW: Support 3rd Party CA · Issue #468 · openziti/desktop-edge-win · GitHub
Good stuff. I’ll track that GitHub issue and try to be one of the first to use it. As a reference, a file:// scheme URI doesn’t seem to work for id.key and id.cert in the identity config. I moved those files to the same directory as the identity config which looks like this.
"ztAPI":"https://62cc184f-93f5-4081-b5e3-1dcf4ad182af.staging.netfoundry.io:443/",
"id":
"key":"file:///C:/Windows/System32/config/systemprofile/AppData/Roaming/NetFoundry/auto-created-01.key",
"cert":"file:///C:/Windows/System32/config/systemprofile/AppData/Roaming/NetFoundry/auto-created-01.cert",
"ca":"pem:-----BEGIN CERTIFICATE-----\nMIIF5jCCA86gAwIBAgIJANxtOWXlDgqTMA0GCSqGSIb3DQEBCwUAMH4xCzAJBgNV\nBAYTAlVTMQswCQYDVQQIEwJOQzESMBAGA1UEBxMJQ2hhcmxvdHRlMRMwEQYDVQQK\nEwpOZXRGb3VuZHJ5MRMwEQYDVQQDEwpOZXRGb3VuZHJ5MSQwIgYJKoZIhvcNAQkB\nFhVzdXBwb3J0QG5ldGZvdW5kcnkuaW8wHhcNMjExMDE3MDAwNTM0WhcNMzExMDE1\nMDAwNTM0WjB/MQswCQYDVQQGEwJVUzELMAkGA1UECBMCTkMxEzARBgNVBAoTCk5l\ndEZvdW5kcnkxKDAmBgNVBAMTH1ppdGkgQ29udHJvbGxlciBJbnRlcm1lZGlhdGUg\nQ0ExJDAiBgkqhkiG9w0BCQEWFXN1cHBvcnRAbmV0Zm91bmRyeS5pbzCCAiIwDQYJ\nKoZIhvcNAQEBBQADggIPADCCAgoCggIBALi59SF9PxBUmp7fFJASEhHHsevJB666\nuUGVvD2ghpjBLdcJDnSdX2FIOnxCApUJrCJ+LP+prQ5Ye7dQr5J8SeF3Nf7A+Drb\nldqozZjfQFF9wZjIQZpWqGct1rGIp0wG+p9zjPHfEAEQnKR+ep8f+bJGMNwDPDor\n/7XwBgxUy1tViVrOB5DOOA08Rgkj3Tt5tRc6kN3JyyWZalINShgjUp2ySotBuRlI\nhFnSEqGtMBVfIZxfSxDEuy5BRp5LWNFkbG2ei3UT7tweGMJXecE7U/hBDDcGG0fi\niUcH87Ge3YcvlTJxPLGr93GkN0VxHBcbkjxV010USXCMiztOedRkVzfaFJ0YFpBj\nl4QGBb4vhDD8CRsx+AuRTKo0W8BBHeHuXKAaT4Sd6hXgcL1U9Wn+RE/H89WhKMXa\nkZJbYzX7fz5qJX8VUUlTKyk9u/WAcue7Vo9XobWlS7QBaJg1Nt/mt72mr3DDcDIy\nNEWRKGeFrbRAryFuURpulvctZg55pSIxyOWKyhTPo/v1hwWonC9qdfP1IK4HDKGO\ncXJAUpTZgr2DhVTu06tvdbEHyixTbE+h4UGUMNMa6FQGmkMy6wLeN3HRnf8rmfm/\npPdRsWQcpoDMQycu9VqGLFk40JoMvEArdW/OThl36LnGuTOphAmX2oK9GAUaOa4d\naHgN+3KQ/Hu7AgMBAAGjZjBkMB0GA1UdDgQWBBSIx7vlPRTrG6VBcdvvFHgYv8Zw\n4zAfBgNVHSMEGDAWgBQY4OS1Bc9aZaHJ7DtcqiV1EPzJsDASBgNVHRMBAf8ECDAG\nAQH/AgEAMA4GA1UdDwEB/wQEAwIBhjANBgkqhkiG9w0BAQsFAAOCAgEAdn2QowwZ\n58O9NXnvrFWhTkj2xAKxChYshVTqVI3lUF0Tj4J1i0ZDjCoWLuWGjf4NahbK44ab\nAhCIWzeALIOJ0J03muz7fXvau8gA3e54EasT3EyFBeIC6LPWudjKtR5V0fyw7oMF\nZuHdpA9Lizt8GjngRzYIjeeHwyZNjZx1m5NGxzg9Uk5D/hfVNxg1HD1DvpFLDKil\njXGRPMSDrXTPvgpoRSodA1bS+rhEoNRY/QVEhEanSgAaaXXR3DqGZktxFE6BW2av\nTqkXmYUq7agbqFEG2upDd/uSUHwc1/zXf1TR91eZmMCW/AZ8sbCaoaAwoCbD5Iwd\nLQSQRJFkuGSv888oVWBPg7ileB9/USLH5cQuWx+GYgJ+wOpK2u9Jmh0InuZxZ3/1\nT+WtofRGGmibEQNJK8c/SnRqY5fauaegE/TNRgt/mLb9xJGldE1FSsu+yVH23DX8\nrfFR6FSBjd4RgfmnKVP8ik0ZWX0edOvDqoA1YZk4ZJhr3z1qNSqvaVAXJFyFiKNL\nQay/FQJQ/qTZlVNkYWfOB3Q6C60S8ixOPmkYSpdxFO8ntlzdqYMk1kw6M3UD1YLS\nmJgzpZ4HJW8tal39y264faU6S0TuDOU30Yhz8mfkZvuPvfbdi9fCJuL+B4cIvduK\noUWZKG+qd/SD34+Z0VTUMqIXJBs0+t6Hn1E=\n-----END CERTIFICATE-----\n-----BEGIN CERTIFICATE-----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\nB8zTRKJnIXKm\n-----END CERTIFICATE-----\n-----BEGIN CERTIFICATE-----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\noUWZKG+qd/SD34+Z0VTUMqIXJBs0+t6Hn1E=\n-----END CERTIFICATE-----\n-----BEGIN CERTIFICATE-----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\nB8zTRKJnIXKm\n-----END CERTIFICATE-----\n-----BEGIN CERTIFICATE-----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\noUWZKG+qd/SD34+Z0VTUMqIXJBs0+t6Hn1E=\n-----END CERTIFICATE-----\n-----BEGIN CERTIFICATE-----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\nB8zTRKJnIXKm\n-----END CERTIFICATE-----\n-----BEGIN CERTIFICATE-----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\noUWZKG+qd/SD34+Z0VTUMqIXJBs0+t6Hn1E=\n-----END CERTIFICATE-----\n-----BEGIN CERTIFICATE-----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\nB8zTRKJnIXKm\n-----END CERTIFICATE-----\n-----BEGIN CERTIFICATE-----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\noUWZKG+qd/SD34+Z0VTUMqIXJBs0+t6Hn1E=\n-----END CERTIFICATE-----\n-----BEGIN CERTIFICATE-----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\nB8zTRKJnIXKm\n-----END CERTIFICATE-----\n"
"configTypes":null
I might try moving the files elsewhere - out of the windows folder perhaps. If you feel up for it, you could try using procmon to verify what if the files are actually being attempted to be read.
I would have expected this to work fwiw - so procmon might shed some light as to why the files were not read.
Were there any useful logs to read? Might be some clues in there.
I pasted the tunneler log here because I couldn’t attach the log file. I do have two identities loaded at this time. One is the recovered identity “auto-created-01” which I’d dropped into the Netfoundry folder and that one is enabled in Ziti Desktop Edge. The other identity is old and disabled and I’m not sure why the tunneler is even trying to authenticate that one.
Here’s the content of “auto-created-01-config.json” at the this log was generated:
"id":{
"key":"file:///Z:/auto-created-01.key",
"cert":"file:///Z:/auto-created-01.cert",
"configTypes":null
I forgot to mention the identity is recovered and visible in ZDE but there are zero services showing authorized there.
Did you toggle the identity ‘on’ with the slider? I expect yes - but figured I’d ask. Did the “recovered identity” connect to the controller and update the name of the identity (it does that on first connect)
I’m going back to the controller to sanity check my assumptions about policies, etc…
If the identity name changed - it means you have successfully authenticated to the controller. At that point - yes - I’d look at policies etc. since you should be good to go. can you submit a ‘feedback’ zip? that’d be easier for me to review
I wasn't able to attach the ZIP file either so here's the base64 encoding.
...nevermind
Body is limited to 32000 characters; you entered 338573.
When I click “Feedback” in ZDE it launches some kind of mail app that I don’t use which gets stuck on a setup screen I don’t intend to pursue completing, but I found the ZIP file near the logs so I just need a way to send it to you.
We found that the file path to the cert and key with the file:// scheme must omit the drive letter e.g. c: and now the auth’d services are available. Thanks!
