I have 2 services: socks5, element. The both are deployed on a machine where ovhXX routers run. However dc67 is a remote host, miles away from the services and from the clients also.
- ping client -> ovhXX time=16ms;
- ping client -> dc67 time=28ms.
│ ID │ NAME │ ENCRYPTION │ TERMINATOR STRATEGY │ ATTRIBUTES │
│ │ │ REQUIRED │ │ │
│ 297xbk7xZecDRoHI3vQ4GC │ socks5 │ true │ smartrouting │ │
│ 422e3i40ThOGC0YVX5HaMY │ element │ true │ smartrouting │ │
There are two questions:
- Sometimes ziti network allocates a service terminator on a a very remote router dc67 which is miles away from the host where these services are hosted.
- Similar situation with client's connections. A client can pick up very remote router: r/dc67 -> l/7YrrmAJOqw2wKkENZWhEAX -> r/ovh76. It lasts hours. There is no rerouting.
ziti fabric list circuits:
│ ID │ CLIENT │ SERVICE │ TERMINATOR │ CREATEDAT │ PATH │
│ LNs.Yds5F │ cma3li8za0maf4tj4ou1f2rh1 │ socks5 │ 6TJfsrSiFqEp6HNdfovgEw │ 2025-04-30 07:59:23 │ r/ovh76 │
│ Qfji1o.5e │ cma3li8za0maf4tj4ou1f2rh1 │ socks5 │ 6TJfsrSiFqEp6HNdfovgEw │ 2025-04-30 07:51:55 │ r/ovh221 -> l/1ZVOfxNRcZjWKlJGiWUvuV -> r/ovh76 │
│ Qgg4Yd.Ee │ cma3li8za0maf4tj4ou1f2rh1 │ socks5 │ 6TJfsrSiFqEp6HNdfovgEw │ 2025-04-30 07:57:25 │ r/ovh223 -> l/35Mlsz88K9xtbVFdZrjprO -> r/ovh76 │
│ T88nJds5e │ cma3li8za0maf4tj4ou1f2rh1 │ socks5 │ 6TJfsrSiFqEp6HNdfovgEw │ 2025-04-30 07:09:23 │ r/dc67 -> l/7YrrmAJOqw2wKkENZWhEAX -> r/ovh76 │
│ Vcb4YosEF │ cma3li8za0maf4tj4ou1f2rh1 │ socks5 │ 6TJfsrSiFqEp6HNdfovgEw │ 2025-04-30 07:57:25 │ r/ovh223 -> l/35Mlsz88K9xtbVFdZrjprO -> r/ovh76 │
│ XRGs1ds5F │ cma3luby80mq64tj45qxjpxh2 │ element │ 2fnPDU1qqTPhryBlrczwg1 │ 2025-04-30 07:59:06 │ r/ovh89 -> l/7Dqz00IgdTMbs2xwqLFE3j -> r/ovh223 │
│ anI9Yd.5e │ cma3li8za0maf4tj4ou1f2rh1 │ socks5 │ 6TJfsrSiFqEp6HNdfovgEw │ 2025-04-30 07:58:27 │ r/ovh89 -> l/1lWmp5wAPyslLgQgq3Msda -> r/ovh76 │
│ iNcA9os5e │ cma3li8za0maf4tj4ou1f2rh1 │ socks5 │ 6TJfsrSiFqEp6HNdfovgEw │ 2025-04-30 07:09:25 │ r/ovh223 -> l/35Mlsz88K9xtbVFdZrjprO -> r/ovh76 │
│ ls8sYosEe │ cma3luby80mq64tj45qxjpxh2 │ element │ 2fnPDU1qqTPhryBlrczwg1 │ 2025-04-30 07:59:06 │ r/ovh89 -> l/7Dqz00IgdTMbs2xwqLFE3j -> r/ovh223 │
│ n.rY1d.5e │ cma3li8za0maf4tj4ou1f2rh1 │ socks5 │ 6TJfsrSiFqEp6HNdfovgEw │ 2025-04-30 07:59:40 │ r/ovh76 │
ziti fabric list terminators:
│ ID │ SERVICE │ ROUTER │ BINDING │ ADDRESS │ INSTANCE │ COST │ PRECEDENCE │ DYNAMIC COST │ HOST ID │
│ 2fnPDU1qqTPhryBlrczwg1 │ element │ ovh223 │ edge │ 2fnPDU1qqTPhryBlrczwg1 │ │ 0 │ default │ 2 │ oOesPw1m9F │
│ 6TJfsrSiFqEp6HNdfovgEw │ socks5 │ ovh76 │ edge │ 6TJfsrSiFqEp6HNdfovgEw │ │ 0 │ default │ 32 │ oOesPw1m9F │
ziti edge list sessions:
│ ID │ API SESSION ID │ SERVICE NAME │ TYPE │
│ cma34zua000r84tj4qe9szovf │ cma34zu7c00r64tj422v2v0g7 │ socks5 │ Bind │
│ cma34zyla00rw4tj4gjnvugp7 │ cma34zyib00rt4tj4u7eqzlf2 │ element │ Bind │
│ cma3li8za0maf4tj4ou1f2rh1 │ cma3li8lv0mad4tj4i2iq4rtu │ socks5 │ Dial │
│ cma3luby80mq64tj45qxjpxh2 │ cma3lubte0mq44tj42pjci591 │ element │ Dial │
It is unclear why cma3li8za0maf4tj4ou1f2rh1 sends the flow to the remote router dc67 then the flow goes back to ovh76:
r/dc67 -> l/7YrrmAJOqw2wKkENZWhEAX -> r/ovh76 (circuit T88nJds5e). There is no service terminators on dc67.
It seems that the cost is calculated for each session. But different circuits have different cost, isn't it?
Is it possible to access the cost per circuit information somehow?
As I have mentioned above a similar strange situation happens with service terminators. Ziti network allocates a terminator on the remote router dc67.
│ 5jWewbMLAy3IyC1T2HPOUB │ element │ dc67 │ edge │ 5jWewbMLAy3IyC1T2HPOUB │ │ 0 │ default │ 2 │ qNTXfYbyhW │
│ 6Uz4d4tkjy6PAlbkPIOeTY │ socks5 │ ovh29 │ edge │ 6Uz4d4tkjy6PAlbkPIOeTY │ │ 0 │ default │ 26 │ qNTXfYbyhW │
Here is another example.
1 . Client (OH7ESFp5e) -> socks5 (Y-UUoWCyIW) via the remote router dc67 (WIZxdWbqhW)
ping OH7ESFp5e -> router WIZxdWbqhW time=28ms (cost 262191)
{"namespace":"circuit","event_src_id":"dc","timestamp":"2025-04-30T16:04:53.839962811Z","version":2,"event_type":"created","circuit_id":"PzL9UKbwT","client_id":"cma44lp6j002qtsj4zbgw7pfe","service_id":"297xbk7xZecDRoHI3vQ4GC","terminator_id":"HGvzP3xeqHAO2vccfgWvx","instance_id":"","creation_timespan":17532908,"path":{"nodes":["WIZxdWbqhW","Y-UUoWCyIW"],"links":["3kzPOHn1SeJnEZlbCVtKJN"],"ingress_id":"WykX","egress_id":"mYvX"},"link_count":1,"path_cost":262191,"tags":{"clientId":"OH7ESFp5e","hostId":"oOesPw1m9F","serviceId":"297xbk7xZecDRoHI3vQ4GC"}}
- Client (OH7ESFp5e) -> socks5 (Y-UUoWCyIW) via local router ovh89(T8.KBWbyhW)
ping OH7ESFp5e -> router T8.KBWbyhW time=16ms(cost 261171)
{"namespace":"circuit","event_src_id":"dc","timestamp":"2025-04-30T16:07:47.099181796Z","version":2,"event_type":"created","circuit_id":"wfYhOdW5T","client_id":"cma44noke005otsj4hyhcqdpz","service_id":"297xbk7xZecDRoHI3vQ4GC","terminator_id":"HGvzP3xeqHAO2vccfgWvx","instance_id":"","creation_timespan":18808714,"path":{"nodes":["T8.KBWbyhW","Y-UUoWCyIW"],"links":["1vxV70bTB3De9VoNa3U0WS"],"ingress_id":"WQqo","egress_id":"BkvJ"},"link_count":1,"path_cost":262171,"tags":{"clientId":"OH7ESFp5e","hostId":"oOesPw1m9F","serviceId":"297xbk7xZecDRoHI3vQ4GC"}}
It seems that a circuit is not per session. Is it true? For the client(OH7ESFp5e) these two circuits are very different: the former has ping time 28ms the later has ping time 16ms. But for ziti these circuits are very similar 261171/262191.
