How to override/set openziti endpoint in zrok?
Hello.
I'm getting the following error while connected to a Cisco Secure Client VPN:
[ERROR]: error creating topTunnel backend (error listening: failed to listen: no apisession, authentication attempt failed: Post "https://ziti.share.0101.party:1280/edge/client/v1/authenticate?method=cert": context deadline exceeded (Client.Timeout exceeded while awaiting headers))
This issue only occurs with my self hosted instance. I was able to open tunnels and use them with free tier api.zrok.io endpoint.
I have noticed that VPN is blocking connections to https://ziti.share.0101.party:1280 but not to https://ziti.share.0101.party. I'm assuming both are one and the same.
or, can this URL be customized before building docker containers? is there a way to avoid https://domain:PORT/xyz syntax in my setup configuration.
Thanks.
It sounds like the VPN may block destination ports other than 443. While connect to the VPN, are you able to open a connection with OpenZiti controller's 1280/tcp?
Even if you get an error, you can still confirm the port is "open" while connected to the VPN by visiting the controller's URL in a web browser: https://ziti.share.0101.party:1280
You should see a certificate error if it's working correctly (zrok brokers cert trust through OpenZiti, not through the OS or browser's CA trust store).
curl gets timed out while connected to VPN. got SSL error as expected without VPN.
I'm quite curious to konw why official api.zrok.io works fine though :thinking:
I suspect it's because the VPN is blocking outgoing ports other than 443. You can verify your zrok environment is using port 443/tcp for the official zrok.io instance by parsing the OpenZiti controller URL from the environment's configuration file.
jq .ztAPI ~/.zrok/identities/environment.json
You're self-hosting zrok in Docker and using Caddy to manage zrok's certs, right?
The VPN probably allows 80/tcp too. Will you confirm with cURL while your VPN is turned on?
curl -sSf http://api.zrok.io:80
...gets this output if 80/tcp works on the VPN.
<head><title>301 Moved Permanently</title></head>
<body>
<center><h1>301 Moved Permanently</h1></center>
</body>
</html>
yes.
yes, it's working.
Great! That's two: 80,443. If we have three TCP ports, then only a small change to the zrok Docker recipe is needed.
See if 22, 53, 1723, 3306, 3389, 8000, 8080, 8088, 8443, 8888, etc. are open while the VPN is ON.
EDIT: more candidates 25, 110, 139, 143, 194, 445, 5900
UPDATE: I'm drafting a solution in this pull request: stop Caddy binding 80/tcp so it can be used as an edge listener by qrkourier · Pull Request #792 · openziti/zrok · GitHub that you may reference to switch your required Ziti ports over to common ports allowed by your VPN
Here's an overview of zrok's network flows in the Docker /w Caddy example.
video tour: https://youtu.be/U6d5qa3qOGo
EDIT: an attempt at highlighting the internet firewall exceptions and wildcard DNS requirement:
