How to remove dead fronted tokens
In the case zrok agent suddenly dies for some reasons (example: a power line cut-off) the fronted token remains alive in the zrok database.
So I end up with a lot of icons in API Console linked to the same ziti identity id (z_id), and having the same bind local address:port.
There is the delete button. So I can release these dead tokens manually but I need to know which is active. With 9 access tokens such a operation is tricky. So I let them alone. But they fill up the console with the junk. I have several users with the same issue.
select id, environment_id, token, z_id, created_at, updated_at, deleted, bind_address from frontends where z_id = 'F4QGPJFyfp' and deleted='f';
 id  | environment_id |    token     |    z_id    |          created_at           |          updated_at           | deleted |  bind_address
 495 |             57 | DsJt6TcjckMh | F4QGPJFyfp | 2025-05-30 05:12:23.619696+00 | 2025-05-30 05:12:24.551853+00 | f       | 127.0.0.1:9443
 496 |             57 | wJYIKMGpSTny | F4QGPJFyfp | 2025-05-30 05:12:27.631044+00 | 2025-05-30 05:12:28.61566+00  | f       | 127.0.0.1:9191
 497 |             57 | aVjaQoBZqbjT | F4QGPJFyfp | 2025-05-30 14:37:19.632267+00 | 2025-05-30 14:37:21.12727+00  | f       | 127.0.0.1:8181
 498 |             57 | VOtgK58o7NOO | F4QGPJFyfp | 2025-05-30 14:37:24.225439+00 | 2025-05-30 14:37:25.195018+00 | f       | 127.0.0.1:9443
 499 |             57 | XCLrtJdnKTfj | F4QGPJFyfp | 2025-05-30 14:37:28.427756+00 | 2025-05-30 14:37:29.372851+00 | f       | 127.0.0.1:9191
 500 |             57 | 3NefSbuxP9nX | F4QGPJFyfp | 2025-05-30 15:46:39.720226+00 | 2025-05-30 15:46:40.875142+00 | f       | 127.0.0.1:8181
 501 |             57 | BhEXhJ6aqrGW | F4QGPJFyfp | 2025-05-30 15:46:42.252246+00 | 2025-05-30 15:46:43.173679+00 | f       | 127.0.0.1:9443
 502 |             57 | bzK7LwkEnCPo | F4QGPJFyfp | 2025-05-30 15:46:44.548646+00 | 2025-05-30 15:46:45.463368+00 | f       | 127.0.0.1:9191
 494 |             57 | 8MbLErIG6cZz | F4QGPJFyfp | 2025-05-30 05:12:19.4165+00   | 2025-05-30 05:12:20.448916+00 | f       | 127.0.0.1:8181
There is not currently a solution or workaround for this.
The upcoming remote agent support will potentially be helpful in identifying what's currently in use and what is not.
In this case I will do it manually, one by one.
The active token is the last in the sorted list for each bind_address.
select token, created_at, updated_at,  bind_address from frontends where z_id = 'Qup3x3wguV' and deleted='f' order by bind_address, updated_at;
    token     |          created_at           |          updated_at           |  bind_address
 vqsKLoagwTXY | 2025-05-11 16:11:37.036265+00 | 2025-05-11 16:11:39.037117+00 | 127.0.0.1:8181
 k2yskPu58QJc | 2025-05-24 16:30:26.299639+00 | 2025-05-24 16:30:27.334236+00 | 127.0.0.1:8181
 I5AADwDT21h4 | 2025-05-11 17:46:57.305645+00 | 2025-05-11 17:46:58.749567+00 | 127.0.0.1:9191
 k0jYuB9t7NVl | 2025-05-24 16:30:29.222431+00 | 2025-05-24 16:30:30.321485+00 | 127.0.0.1:9191
 yXbTPAMcExkw | 2025-05-11 16:11:31.564323+00 | 2025-05-11 16:11:33.314581+00 | 127.0.0.1:9443
 UtEGH0lwYtjf | 2025-05-24 16:30:23.121607+00 | 2025-05-24 16:30:24.42459+00  | 127.0.0.1:9443
(6 rows)
So the result is as below
(3 rows)
I hope it is correct. So far I don't see any error in logs.
This is probably true with the usage patterns in your environment, but could not be generalized to an implementation in zrok.
Generally, in practice, most users self-clean these things, and limits ensure that they do not produce too many of them before hitting a limit.
I have noticed a proliferation of unused frontend tokens.
Firstly I did not have a clue how it has happened.
Today I have discovered that these dead tokens have the same cause - a power line cutoff.
Zrok had not time to release the shares. When the power comes back and user starts its home computer zrok creates a new token.
