How to run ziti ops verify traffic?
ziti ops verify traffic has created bind/dial identities but apparently it can not find routers.
All my routers have custom roles. There are no router with #all.
Saving identity 'default' to .config/ziti/ziti-cli.json
INFO    generating P-384 EC key
INFO    waiting 10s for terminator for service: 2025-07-31-1428.traffic
INFO    successfully bound service: 2025-07-31-1428.traffic.
INFO    Server is listening for a connection and will exit when one is received.
WARNING failure creating Bind session to service 2025-07-31-1428.traffic  error="error for request T86.RHFAB: NO_EDGE_ROUTERS_AVAILABLE: No edge routers are assigned and online to handle the requested connection" errorType="*rest_util.APIFormattedError"
WARNING failure creating Bind session to service 2025-07-31-1428.traffic  error="error for request veVJdHFAB: NO_EDGE_ROUTERS_AVAILABLE: No edge routers are assigned and online to handle the requested connection" errorType="*rest_util.APIFormattedError"
WARNING failure creating Bind session to service 2025-07-31-1428.traffic  error="error for request C0q.duv6B: NO_EDGE_ROUTERS_AVAILABLE: No edge routers are assigned and online to handle the requested connection" errorType="*rest_util.APIFormattedError"
ERROR   failed to create bind session for service 0xc001454fc0  error="error for request C0q.duv6B: NO_EDGE_ROUTERS_AVAILABLE: No edge routers are assigned and online to handle the requested connection"
WARNING failure creating Bind session to service 2025-07-31-1428.traffic  error="error for request r0j.RuFA3: NO_EDGE_ROUTERS_AVAILABLE: No edge routers are assigned and online to handle the requested connection" errorType="*rest_util.APIFormattedError"
WARNING failure creating Bind session to service 2025-07-31-1428.traffic  error="error for request -sL.RHFA3: NO_EDGE_ROUTERS_AVAILABLE: No edge routers are assigned and online to handle the requested connection" errorType="*rest_util.APIFormattedError"
WARNING failure creating Bind session to service 2025-07-31-1428.traffic  error="error for request TKQJRHv63: NO_EDGE_ROUTERS_AVAILABLE: No edge routers are assigned and online to handle the requested connection" errorType="*rest_util.APIFormattedError"
ERROR   failed to create bind session for service 0xc001454fc0  error="error for request TKQJRHv63: NO_EDGE_ROUTERS_AVAILABLE: No edge routers are assigned and online to handle the requested connection"
WARNING failure creating Bind session to service 2025-07-31-1428.traffic  errorType="*rest_util.APIFormattedError" error="error for request VZ9.duFAB: NO_EDGE_ROUTERS_AVAILABLE: No edge routers are assigned and online to handle the requested connection"
WARNING failure creating Bind session to service 2025-07-31-1428.traffic  errorType="*rest_util.APIFormattedError" error="error for request ucCJdHv6B: NO_EDGE_ROUTERS_AVAILABLE: No edge routers are assigned and online to handle the requested connection"
WARNING failure creating Bind session to service 2025-07-31-1428.traffic  error="error for request FnCJdHv63: NO_EDGE_ROUTERS_AVAILABLE: No edge routers are assigned and online to handle the requested connection" errorType="*rest_util.APIFormattedError"
FATAL   terminator not found for service: 2025-07-31-1428.traffic
Thanks, it should probably check/add a policy specifically to avoid that. I filed an issue ziti ops verify traffic should add dial and bind policies · Issue #3195 · openziti/ziti · GitHub
In the meantime, you would have to make your own policy and you’ll have to use the --prefix to force the name of the generated identity.
Example:
ziti ops verify traffic --mode server --password $ZITI_PWD --prefix exampleprefix
Then you can see the generated identity will be named:
ziti edge list identities 'name contains "exampleprefix"'
│ ID         │ NAME                 │ TYPE    │ ATTRIBUTES                    │ AUTH-POLICY │
│ SIFd8AMvs3 │ exampleprefix.server │ Default │ exampleprefix.traffic.binders │ Default     │
results: 1-1 of 1
You would make policies for the attributes that will be generated: exampleprefix.traffic.binders and exampleprefix.traffic.dialers and I believe it’ll work
