It would seem to me that if you are using full-tunnel mode for OpenVPN/Wireguard, and if that traffic is intercepted first it's possibly breaking OpenZiti's mTLS?
Exactly this. This is what is happening.
The packet tunnel logs are the following:
[2026-07-23T14:27:52:177Z] INFO PacketTunnelProvider:PacketTunnelProvider.swift:425 logNetworkPath() Network Path Update:Status:satisfied, Expensive:false, Cellular:false, DNS:trueInterfaces:14: name:en0, type:wifi14: name:en0, type:wifi26: name:utun8, type:other
[2026-07-23T14:27:52:204Z] WARN PacketTunnelProvider:PacketTunnelProvider.swift:371 getUpstreamDns() No fallback DNS configured. Setting to first resolver: 192.168.1.1
[2026-07-23T14:27:52:205Z] INFO PacketTunnelProvider:PacketTunnelProvider.swift:410 startNetworkMonitor() Setting fallback DNS to 192.168.1.1(85441)[2026-07-23T14:27:52.204Z] INFO tunnel-cbs:ziti_dns.c:273 ziti_dns_set_upstream() DNS upstream[1] is set to 192.168.1.1:53(85441)[2026-07-23T14:27:55.837Z] INFO tunnel-cbs:ziti_dns.c:567 format_resp() found record[100.64.0.26] for query[1:bull-board.dev.foo.com]
[2026-07-23T14:27:55:844Z] INFO PacketTunnelProvider:PacketTunnelProvider.swift:425 logNetworkPath() Network Path Update:Status:satisfied, Expensive:false, Cellular:false, DNS:trueInterfaces:14: name:en0, type:wifi14: name:en0, type:wifi26: name:utun8, type:other
[2026-07-23T14:27:55:862Z] WARN PacketTunnelProvider:PacketTunnelProvider.swift:371 getUpstreamDns() No fallback DNS configured. Setting to first resolver: 192.168.1.1[2026-07-23T14:27:55:862Z] INFO PacketTunnelProvider:PacketTunnelProvider.swift:410 startNetworkMonitor() Setting fallback DNS to 192.168.1.1(85441)
[2026-07-23T14:27:55.862Z] INFO tunnel-cbs:ziti_dns.c:273
2026-07-23T14:27:56.135Z] INFO tunnel-cbs:ziti_dns.c:567 format_resp() found record[100.64.0.7] for query[1:bull-board.us.foo.com][2026-07-23T14:27:56:304Z] INFO PacketTunnelProvider:PacketTunnelProvider.swift:425 logNetworkPath() Network Path Update:Status:satisfied, Expensive:false, Cellular:false, DNS:trueInterfaces:14: name:en0, type:wifi14: name:en0, type:wifi26: name:utun8, type:other
[2026-07-23T14:27:56:339Z] WARN PacketTunnelProvider:PacketTunnelProvider.swift:371 getUpstreamDns() No fallback DNS configured. Setting to first resolver: 192.168.1.1[2026-07-23T14:27:56:340Z] INFO PacketTunnelProvider:PacketTunnelProvider.swift:410 startNetworkMonitor() Setting fallback DNS to 192.168.1.1(85441)
[2026-07-23T14:27:56.339Z] INFO tunnel-cbs:ziti_dns.c:273 ziti_dns_set_upstream() DNS upstream[1] is set to 192.168.1.1:53(85441)[2026-07-23T14:27:59.849Z] INFO tunnel-cbs:ziti_dns.c:567 format_resp() found record[100.64.0.12] for query[1:grafana.dev.foo.com](85441)[2026-07-23T14:28:06.839Z] ERROR ziti-sdk:channel.c:1125 on_tls_connect() ch[0] failed to connect to ER[dev-router0] [-3008/unknown node or service](85441)
[2026-07-23T14:28:06.839Z] INFO ziti-sdk:channel.c:981 reconnect_channel() ch[0] reconnecting in 68058ms (attempt = 218)(85441)[2026-07-23T14:28:09.006Z]
ERROR tunnel-sdk:tunnel_tcp.c:191 on_tcp_client_err() client=tcp:100.64.0.1:64365 err=-14, terminating connection(85441)
[2026-07-23T14:28:13.897Z] INFO tunnel-cbs:ziti_dns.c:567 format_resp() found record[100.64.0.11] for query[1:gitlab.foo.com]
[2026-07-23T14:28:17:677Z] INFO PacketTunnelProvider:PacketTunnelProvider.swift:425 logNetworkPath() Network Path Update:Status:unsatisfied, Expensive:false, Cellular:false, DNS:trueInterfaces:14: name:en0, type:wifi14: name:en0, type:wifi26: name:utun8, type:other[2026-07-23T14:28:18:042Z] INFO PacketTunnelProvider:PacketTunnelProvider.swift:425 logNetworkPath() Network Path Update:Status:unsatisfied, Expensive:false, Cellular:false, DNS:trueInterfaces:14: name:en0, type:wifi14: name:en0, type:wifi
I assume you/the firmware devs are running ziti-edge-tunnel and not embedding OpenZiti's SDK directly into their code?
Correct. We don't use the sdk since our devices are a mix of OpenVPN and Wireguard connections.
If you're using ziti-edge-tunnel though I would think you'd be able to configure the tunneler with a different IP range and exclude that IP range from the full tunnel (if it supports that sort of thing)?
That will be a tough action to do. I don't really know how to get that to work.
Having OpenVPN, Wireguard AND OpenZiti seems -- I dunno, maybe a bit redundant? Is that just because of legacy? I'm just wondering if OpenVPN/Wireguard are preferable for some other reason?
It is but we have setup fault-tolerance and high availability setup where we can scale with OpenVPN/Wireguard where it doesn't cost us an arm-and-leg for other services out there. We have thought on using OpenZiti as a full replacement but it's complicated for us at the moment in setting up faul-tolerance and high availability atm.
