Hi Team,
I understand that currently there isn’t any QoS based treatment in netfoundry/ziti frabric. Generally it is router functionality to treat a packet based upon the priority as mentioned or defined in the DSCP field of IP header.
Can you please confirm if this feature is enabled or available in NF hosted edge or customer hosted edge routers ?
Thanks
Sameer Sarkar
Underlay routing in the Ziti fabric is at the application layer and does not directly interact with low-level packet handling. If your operating system is configured to handle the underlay network in the manner that you want, then the Ziti fabric will utilize that configuration.
This is the case with either NetFoundry hosted or customer hosted routers.
Thanks Michael for clarifying the doubt.
