Hello,
Trying to install latest ziti-edge-tunnel binary on Debian 11, but getting the following error:
“ziti-edge-tunnel: /lib/x86_64-linux-gnu/libc.so.6: version GLIBC_2.33' not found (required by ziti-edge-tunnel) ziti-edge-tunnel: /lib/x86_64-linux-gnu/libc.so.6: version GLIBC_2.32’ not found (required by ziti-edge-tunnel)
ziti-edge-tunnel: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.34’ not found (required by ziti-edge-tunnel)”
Looks like the ziti binary used version 2.32 or above, but my local version is 2.31: /lib/x86_64-linux-gnu/libc.so.6 → libc-2.31.so. I cannot find the glibc package for debian 11 greater than 2.31… Anyone know of a fix for this?
Hey @cwalkernf, our CI focuses on Ubuntu releases at this time. You could try the binary packed for Ubuntu 18.04 (Bionic) with something like this:
curl -sSLf https://raw.githubusercontent.com/openziti/ziti-tunnel-sdk-c/main/package-repos.gpg \
| gpg --dearmor \
| sudo tee /usr/share/keyrings/openziti.gpg >/dev/null
echo 'deb [signed-by=/usr/share/keyrings/openziti.gpg] https://packages.openziti.org/zitipax-openziti-deb-stable bionic main' \
| sudo tee /etc/apt/sources.list.d/openziti.list >/dev/null
sudo apt update
sudo apt install ziti-edge-tunnel
Hello @sabedevops, thank you for getting back to me. Really appreciate the feedback - am getting past that error now, but now getting a dns error:
“ERROR ziti-edge-tunnel:utils.c:31 run_command_va() cmd{grep -q ‘^nameserver 100.64.0.2’ /etc/resolv.conf} failed: 256/2/No such file or directory”
The file definitely exists though:
$ ls -l /etc/resolv.conf
-rw-r----- 1 root root 85 Sep 14 11:59 /etc/resolv.conf
Cat on Resolv.conf shows the following nameservers:
Hey @cwalkernf,
I believe this is a false positive. We just need to migrate that command execution to a separate utility function that disables error logging since we expect this command to fail when we’ve modified /etc/resolv.conf already (which was the case here).
Let me know if it isn’t working for you so we can take additional debugging steps.
Hi @sabedevops, good work suggesting the error logging… For some odd reason, just adding the --verbose flag allows it to work - (or at least to run wout segfault):
→ sudo ./ziti-edge-tunnel run --verbose --identity ./my_id_file.json
That said, there is still an issue with the DNS. If I try to lookup a service it complains about the resolv.conf:
“nslookup myservice.ziti
nslookup: parse of /etc/resolv.conf failed”
Which currently looks like this:
domain netfoundry.io
search netfoundry.io
nameserver 10.30.0.2
I am seeing other discord posts with similar errors, reviewing those now. Thanks again
Hey @sabedevops, the perms had gotten messed up on resolv.conf - it’s working now. Just need to add that --verbose flag to the run command for some reason. Thank you again for the help on this.
The legacy resolver code that handles the fallback to /etc/resolv.conf when systemd-resolved is not available on the system does an “in-place” override (sed -i ..). I’m guessing this probably changes the permissions on that file. Can you please open an issue in GitHub for this?
Does the binary segfault every time you don’t add the --verbose flag? If so, can you run it under valgrind and post back? (e.g. valgrind ziti-edge-tunnel run ...)
