Intercept active directory with ZDEW
Hi, I've tried to tunnel Window's active directory but haven't been successful yet.
I've kind of followed this approach here but it looks like the SRV records can't be resolved as soon as I activate the service.
PS C:\Users\p.gross> Resolve-DnsName -Type SRV _ldap._tcp.dc._msdcs.ad.xyz.de
Resolve-DnsName : _ldap._tcp.dc._msdcs.ad.xyz.de : DNS-Server Error
In Zeile:1 Zeichen:1
+ Resolve-DnsName -Type SRV _ldap._tcp.dc._msdcs.ad.xyz.de
    + CategoryInfo          : ResourceUnavailable: (_ldap._tcp.dc._msdcs.ad.xyz.de:String) [Resolve-DnsName], Win32Exception
    + FullyQualifiedErrorId : RCODE_SERVER_FAILURE,Microsoft.DnsClient.Commands.ResolveDnsName
Normal A-Record can be resolved
PS C:\Users\p.gross> Resolve-DnsName ad.xyz.de
Name                                           Type   TTL   Section    IPAddress
ad.xyz.de                                A      60    Answer     100.64.0.5
I'm using the current release ZDEW 2.4.0 which if I understand this correctly should work.
The service seems to be setup correctly. It is supposed to be offloading on a private edge router (ad-ztna02).
root@ad-ztna01:~# ziti edge policy-advisor services ad-client.svc -q
OKAY : ad-ztna02 (1) -> ad-client.svc (2) Common Routers: (1/1) Dial: N Bind: Y
OKAY : p.gross (3) -> ad-client.svc (2) Common Routers: (2/2) Dial: Y Bind: N
I'm getting the following logs
[2024-08-06T06:15:16.370Z] ERROR tunnel-cbs:ziti_tunnel_cbs.c:103 on_ziti_connect() ziti dial failed: connection is closed [2024-08-06T06:15:20.849Z] ERROR ziti-sdk:connect.c:963 connect_reply_cb() conn[0.20/I0tLp1x-/Connecting] failed to connect, reason=can't route from pHbNlOUrfj -> PvWaLOwrfj [2024-08-06T06:15:20.849Z] ERROR tunnel-cbs:ziti_dns.c:631 on_proxy_connect() failed to establish proxy resolve connection for domain[*.ad.ardorisai.de] [2024-08-06T06:15:20.849Z] WARN tunnel-cbs:ziti_dns.c:679 on_proxy_write() proxy resolve write failed: connection is closed/-24
Edit: pHbNlOUrfj is ad-ztna01 --> PvWaLOwrfj is ad-ztna02
Your help is highly appreciated!
I have no idea why, but it is working now.
Thanks anyway
If you see this again, please let us know. We've had one other similar report, but haven't been able to duplicate it, so any help we can get in tracking it down is appreciated.
Should you see it again, the first thing to look at would be the routers and links, to make sure the mesh is established properly. The second thing to check for would be messages related to links in the controller and router to see if links are maybe flapping. It's possible that it might work sporadically if you've got an unstable link.
Cheers,
thanks, I'll monitor it.
