Latency issues using zrok when sharing Foundry VTT server
Hi I've been using zrok to self host my Foundry VTT server for a while now but I've been having trouble with a lot of latency and the following errors showed up:
[ 470.997] ERROR channel/v2/latency.ProbeLatencyConfigurable [ch{ziti-sdk[router=tls:8e55f926-faa1-4bdd-97fa- │
│3a4338b408dc.production.netfoundry.io:443]}->u{classic}->i{zj6dj}]: {error=[timeout waiting for message reply: context│
│deadline exceeded]} unexpected error sending latency probe │
│[ 470.998] ERROR sdk-golang/ziti.(*ContextImpl).connectEdgeRouter.func1.3: latency timeout after [10s] │
│[ 781.595] ERROR channel/v2/latency.ProbeLatencyConfigurable [ch{ziti-sdk[router=tls:8e55f926-faa1-4bdd-97fa- │
│[ 781.595] ERROR sdk-golang/ziti.(*ContextImpl).connectEdgeRouter.func1.3: latency timeout after [10s]
Thank you very much and merry christmas!
Hi @Parse12 - Welcome to the community, and Merry Christmas to you as well!
It looks like you're unable to connect to one of the Ziti Edge Routers. I'll reach out internally to our ops team and see if that Edge Router is having an issue. Everything should still work for you regardless, as there are other Edge Routers deployed that will be used (although it's possible other Edge Routers are farther away from you location, which could impact latency...)
Hi! Thank you for the quick response! I'll keep testing it after christmas to see if the error persists.
