So, starting to look into MFA and posture checks.
Question 1:
From the documentation:
MFA Posture Checks also support forcing a client to re-submit a valid TOTP on timeout, after locking/unlocking a device, or waking a device from sleep.
Timeouts are set through the timeoutSeconds property. Where values 0 and -1 represent no timeout.
Forcing submission on lock/unlock is set through promptOnUnlock as true or false. After an unlock event the client is given a five-minute grace period before the posture check begins to fail.
Forcing submission on wake is set through promptOnWake as true or false. After a wake event the client is given a five-minute grace period before the posture check begins to fail.
and with a configuration of:
I then apply it to a dial service policy:
What I would be expecting, based on what I read in the documentation, is that should the machine go to sleep, or I lock/unlock the device, within 5 minutes I should be prompted for MFA/ require to input MFA. This is on ZDEW. However, it does not timeout and I can continue to use it. Thought I would ask here to confirm if my thinking is correct.
The expected outcome, is that you need to unlock the Ziti client when logging in / unlocking lock screen / Waking from sleep (which really is lock screen). However, you can work on the session until one of those conditions exist.
Question 2
What is the reasoning being a 5 minute grace period - the documentation does not state the reason. Is this configurable?
