Greetings!
I have recently run into an issue with new routers that I deploy to AWS with Terraform, and a custom AMI that I build on top of my company's foundational AMIs. First, let me say that I was able to work around it, by locking my version to 1.1.15, so I am not in a critical situation, but I would love to know what changes I need to make in my environment to continue running newer and newer versions as I deploy more routers. It looks to me like it is trying to make a directory on startup, and it fails with a FATAL error. It is unclear to me whether it is trying to run mkdir, and failing to find the mkdir command, or if it is trying to create a directory that may be null, because I see dir=. Is this a directory that I can create ahead of time in my AMI? Here is a snip from the logs from one FATAL error to the next:
Feb 26 01:20:02 ip-10-2-2-20 ziti[10986]: [4802.556] FATAL ziti/ziti/router.run: {error=[mkdir : no such file or directory]} error starting
Feb 26 01:20:04 ip-10-2-2-20 ziti[10993]: [4804.976] INFO ziti/ziti/router.run: {os=[linux] arch=[arm64] routerId=[Hi3lsWHMGw] version=[v1.3.3] revision=[2a62cc577e45] configFile=[/opt/openziti/er-use1-studios1-fsx1.yaml] go-version=[go1.23.4] build-date=[2025-01-27T19:27:43Z]} starting ziti router
Feb 26 01:20:04 ip-10-2-2-20 ziti[10993]: [4804.977] INFO ziti/common/metrics.ConfigureGoroutinesPoolMetrics.GoroutinesPoolMetricsConfigF.func1.1: {maxWorkers=[32] idleTime=[30s] maxQueueSize=[1000] poolType=[pool.link.dialer] minWorkers=[0]} starting goroutine pool
Feb 26 01:20:04 ip-10-2-2-20 ziti[10993]: [4804.977] INFO ziti/common/metrics.ConfigureGoroutinesPoolMetrics.GoroutinesPoolMetricsConfigF.func1.1: {maxWorkers=[1] poolType=[pool.rdm.handler] minWorkers=[1] idleTime=[30s] maxQueueSize=[1000]} starting goroutine pool
Feb 26 01:20:04 ip-10-2-2-20 ziti[10993]: [4804.977] INFO ziti/common/metrics.ConfigureGoroutinesPoolMetrics.GoroutinesPoolMetricsConfigF.func1.1: {poolType=[pool.route.handler] maxQueueSize=[1000] minWorkers=[0] maxWorkers=[128] idleTime=[30s]} starting goroutine pool
Feb 26 01:20:04 ip-10-2-2-20 ziti[10993]: [4804.977] INFO ziti/common/metrics.ConfigureGoroutinesPoolMetrics.GoroutinesPoolMetricsConfigF.func1.1: {minWorkers=[0] maxWorkers=[50] idleTime=[30s] poolType=[pool.terminator_validation] maxQueueSize=[1]} starting goroutine pool
Feb 26 01:20:04 ip-10-2-2-20 ziti[10993]: [4804.977] INFO ziti/router/internal/edgerouter.(*Config).LoadConfigFromMap: cached data model file set to: /opt/openziti/er-use1-studios1-fsx1.yaml.proto.gzip
Feb 26 01:20:04 ip-10-2-2-20 ziti[10993]: [4804.977] WARNING ziti/router/internal/edgerouter.(*Config).LoadConfigFromMap: Invalid heartbeat interval [0] (min: 60, max: 10), setting to default [60]
Feb 26 01:20:04 ip-10-2-2-20 ziti[10993]: [4804.977] INFO ziti/router/internal/edgerouter.(*Config).loadCsr: loaded csr info from configuration file at path [edge.csr]
Feb 26 01:20:04 ip-10-2-2-20 ziti[10993]: [4804.977] INFO ziti/router/state.(*ManagerImpl).LoadRouterModel: router data model file does not exist [/opt/openziti/er-use1-studios1-fsx1.yaml.proto.gzip]
Feb 26 01:20:04 ip-10-2-2-20 ziti[10993]: [4804.977] INFO ziti/router/forwarder.(*Scanner).run: started
Feb 26 01:20:04 ip-10-2-2-20 ziti[10993]: [4804.978] INFO ziti/router/state.(*ManagerImpl).SetRouterDataModel: {index=[0]} replacing router data model
Feb 26 01:20:04 ip-10-2-2-20 ziti[10993]: [4804.978] INFO ziti/router/state.(*ManagerImpl).SetRouterDataModel: {index=[0]} router data model replacement complete, old: 0x0, new: 0x4000237380
Feb 26 01:20:04 ip-10-2-2-20 ziti[10993]: [4804.978] ERROR ziti/router.(*Router).Start: {dir=[] error=[mkdir : no such file or directory]} failed to initialize data directory
Feb 26 01:20:04 ip-10-2-2-20 ziti[10993]: [4804.978] FATAL ziti/ziti/router.run: {error=[mkdir : no such file or directory]} error starting
