NodeJS SDK config directory
When I call the following command
await ziti_init(process.argv[1]);
I get the following error..
what is unusual is the highlighted directory
@ff5bc3e(main) starting at (2022-06-06T11:05:02.557)
[ 0.000] ERROR ziti-sdk:model_support.c:67 parse_tokens() jsmn_parse() failed: -2
[ 0.000] ERROR ziti-sdk:ziti.c:216 ziti_init_opts()
/Users/runner/work/ziti-sdk-nodejs/ziti-sdk-nodejs/deps/ziti-sdk-c/library /ziti.c:186 - load_config(options->config, &cfg) => -13 (Configuration is invalid)
This is not the folder the app is being run from.
Any tips
@curt
hmm think I need to run the build process... will give it a go
yep.. that seems to be the source... but created a lot of errors
Any tips on how to set the npm package properly to run the build process
ziti-sdk-nodejs@0.4.0 build /Users/houst/DevTech/ _zitiapps/ZAC dark/first-servers
npm run build:init; npm run build:c-sdk; npm install --build-from-source --clang=1
ziti-sdk-nodejs@0.4.0 build:init /Users/houst/DevTech/ _zitiapps/ZAC dark/first-servers
git submodule update --init --recursive
fatal: not a git repository (or any of the parent directories): .git
npm ERR! code ELIFECYCLE
npm ERR! errno 128
npm ERR! ziti-sdk-nodejs@0.4.0 build:init: git submodule update --init --recursive
npm ERR! Exit status 128
npm ERR!
npm ERR! Failed at the ziti-sdk-nodejs@0.4.0 build:init script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
ziti-sdk-nodejs@0.4.0 build:c-sdk /Users/houst/DevTech/ _zitiapps/ZAC dark/first-servers
cd deps/ziti-sdk-c; git submodule update --init --recursive; mkdir build; cd build; cmake -G Ninja -DCMAKE_POSITION_INDEPENDENT_CODE=ON --config Debug ..; cmake --build . --target all
sh: line 0: cd: deps/ziti-sdk-c: No such file or directory
mkdir: build: File exists
CMake Error: The source directory "/Users/houst/DevTech/ _zitiapps/ZAC dark/first-servers/build/Debug" does not exist.
Specify --help for usage, or press the help button on the CMake GUI.
Error: could not load cache
npm ERR! errno 1
npm ERR! ziti-sdk-nodejs@0.4.0 build:c-sdk: cd deps/ziti-sdk-c; git submodule update --init --recursive; mkdir build; cd build; cmake -G Ninja -DCMAKE_POSITION_INDEPENDENT_CODE=ON --config Debug ..; cmake --build . --target all
npm ERR!
npm ERR! Failed at the ziti-sdk-nodejs@0.4.0 build:c-sdk script.
ziti-sdk-nodejs@0.4.0 install /Users/houst/DevTech/ _zitiapps/ZAC dark/first-servers
node-pre-gyp install --fallback-to-build
gyp: binding.gyp not found (cwd: /Users/houst/DevTech/ _zitiapps/ZAC dark/first-servers) while trying to load binding.gyp
gyp ERR! configure error
gyp ERR! stack Error: gyp failed with exit code: 1
gyp ERR! stack at ChildProcess.onCpExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
gyp ERR! stack at ChildProcess.emit (events.js:400:28)
gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:285:12)
gyp ERR! System Darwin 21.4.0
gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/Users/houst/DevTech/ _zitiapps/ZAC dark/first-servers/build/Release/node-v83-darwin-x64/ziti_sdk_nodejs.node" "--module_name=ziti_sdk_nodejs" "--module_path=/Users/houst/DevTech/ _zitiapps/ZAC dark/first-servers/build/Release/node-v83-darwin-x64" "--napi_version=8" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v83"
gyp ERR! cwd /Users/houst/DevTech/ _zitiapps/ZAC dark/first-servers
gyp ERR! node -v v14.19.3
gyp ERR! node-gyp -v v5.1.0
gyp ERR! not ok
node-pre-gyp ERR! build error
node-pre-gyp ERR! stack Error: Failed to execute '/usr/local/bin/node /usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/Users/houst/DevTech/ _zitiapps/ZAC dark/first-servers/build/Release/node-v83-darwin-x64/ziti_sdk_nodejs.node --module_name=ziti_sdk_nodejs --module_path=/Users/houst/DevTech/ _zitiapps/ZAC dark/first-servers/build/Release/node-v83-darwin-x64 --napi_version=8 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v83' (1)
node-pre-gyp ERR! stack at ChildProcess. (/Users/houst/DevTech/ _zitiapps/ZAC dark/first-servers/node_modules/@mapbox/node-pre-gyp/lib/util/compile.js:89:23)
node-pre-gyp ERR! stack at ChildProcess.emit (events.js:400:28)
node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:1088:16)
node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:296:5)
node-pre-gyp ERR! System Darwin 21.4.0
node-pre-gyp ERR! command "/usr/local/bin/node" "/Users/houst/DevTech/ _zitiapps/ZAC dark/first-servers/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
node-pre-gyp ERR! cwd /Users/houst/DevTech/ _zitiapps/ZAC dark/first-servers
node-pre-gyp ERR! node -v v14.19.3
node-pre-gyp ERR! node-pre-gyp -v v1.0.9
node-pre-gyp ERR! not ok
npm ERR! errno 1
npm ERR! ziti-sdk-nodejs@0.4.0 install: node-pre-gyp install --fallback-to-build
npm ERR!
npm ERR! Failed at the ziti-sdk-nodejs@0.4.0 install script.
npm ERR! errno 1
npm ERR! ziti-sdk-nodejs@0.4.0 build: npm run build:init; npm run build:c-sdk; npm install --build-from-source --clang=1
npm ERR!
npm ERR! Failed at the ziti-sdk-nodejs@0.4.0 build script.
