Oc cluster, some hosts reporting as not connected
I'm running a 3-node cluster, consisting of nodes 01, 02, and 03.
All are up and appear healthy, and everything seems to be working.
When 01 is the leader, when I do 'ziti agent cluster list' from 01, everyone is connected.
If I run from 02, it says 03 is not connected.
If I run from 03, it says 02 is not connected.
But when 02 is the leader, the ...cluster list from 02, all connected
From 01, 03 is not connected
From 03, 01 is not connected
It's the same, and consistent, no matter who the leader is. The leader sees all, the followers can't see other follower.
Because the issue appears to be related to/follow the leader, it leads me to believe this is not an inter-host communication issue, but rather a bug in Ziti affecting follower-to-follower communication.
I'm using version 1.6.3; I haven't tested other versions yet.
Has anyone else hit this? Is it 'a thing', and should I file it on GH?
tia!
Ignore me, this seems to be covered in Controllers Cluster issues
Thanks
