Couple of days I have try to figure out why my OpenZiti has stopped working. It has been working last 3 months without problems.
So, any hints what to do or test?
I have single controller on VPS and 2 public routers and 2 private ones, all on version 1.4.3.
For test I have rebuild one public router (ozrb1) and re-enrolled my ZDEW.
Now I see following errors on controller when ZDEW try to connect
[11752.160] ERROR transport/v2/tls.(*sharedListener).processConn [tls:0.0.0.0:443]: {remote=[95.217.xxx.yy:49132] error=[EOF]} handshake failed
[11762.303] ERROR transport/v2/tls.(*sharedListener).processConn [tls:0.0.0.0:443]: {remote=[95.217.xxx.yy:49188] error=[EOF]} handshake failed
[11772.347] ERROR transport/v2/tls.(*sharedListener).processConn [tls:0.0.0.0:443]: {remote=[95.217.xxx.yy:49098] error=[EOF]} handshake failed
and on ZDEW logs I see "reason=no controller available, cannot create circuit"
[2025-04-08T12:06:19.175Z] DEBUG tunnel-cbs:ziti_tunnel_cbs.c:354 ziti_sdk_c_dial() service[odoo2-service] app_data_json[178]='{"connType":null,"dst_protocol":"tcp","dst_hostname":"shop.domain.com","dst_ip":"100.64.0.15","dst_port":"443","src_protocol":"tcp","src_ip":"100.64.0.1","src_port":"54798"}'
[2025-04-08T12:06:19.175Z] DEBUG ziti-sdk:connect.c:432 connect_get_service_cb() conn[0.370/NsaaeNeJ/Connecting](odoo2-service) got service[odoo2-service] id[5DMAEDTItSDhyJm7cfKeCX]
[2025-04-08T12:06:19.175Z] DEBUG ziti-sdk:posture.c:216 ziti_send_posture_data() ztx[0] posture checks must_send set to TRUE, new_session_id[FALSE], must_send_every_time[TRUE], new_controller_instance[FALSE]
[2025-04-08T12:06:19.175Z] DEBUG ziti-sdk:connect.c:553 process_connect() conn[0.370/NsaaeNeJ/Connecting](odoo2-service) starting Dial connection for service[odoo2-service] with session[cm98gfixv0a21p6bp9kt36rv3]
[2025-04-08T12:06:19.175Z] DEBUG ziti-sdk:connect.c:409 ziti_connect() conn[0.370/NsaaeNeJ/Connecting](odoo2-service) selected ch[ozri1@tls://192.168.110.2:443] for best latency(3 ms)
[2025-04-08T12:06:19.175Z] DEBUG ziti-sdk:channel.c:245 ziti_channel_add_receiver() ch[2] added receiver[370]
[2025-04-08T12:06:19.179Z] ERROR ziti-sdk:connect.c:1073 connect_reply_cb() conn[0.369/CnkvdnU3/Connecting](odoo2-service) failed to connect, reason=no controller available, cannot create circuit
[2025-04-08T12:06:19.179Z] ERROR tunnel-cbs:ziti_tunnel_cbs.c:103 on_ziti_connect() ziti dial failed: connection is closed
[2025-04-08T12:06:19.179Z] DEBUG ziti-sdk:connect.c:896 flush_to_client() conn[0.369/CnkvdnU3/Closed](odoo2-service) no data_cb: can't flush, 0 bytes
But when connect from my WLS to controller I cannot found the problem...
timo@TIMO-P14s:~$ ziti ops verify traffic
WARNING no prefix and mode [] is not 'both'. default prefix of 2025-04-08-1520 will be used
Using controller url: https://ozc1.domain.com:8443/edge/management/v1 from identity 'default' in config file: /home/timo/.config/ziti/ziti-cli.json
Using username: admin from identity 'default' in config file: /home/timo/.config/ziti/ziti-cli.json
Enter password:
RESTY 2025/04/08 15:20:34 ERROR Post "https://ozc1.domain.com:8443/edge/management/v1/authenticate?method=password": context deadline exceeded (Client.Timeout exceeded while awaiting headers), Attempt 1
Token: 5400e89b-2deb-43ea-a8e0-b178b482f027
Saving identity 'default' to /home/timo/.config/ziti/ziti-cli.json
INFO generating P-384 EC key
INFO waiting 10s for terminator for service: 2025-04-08-1520.traffic
INFO successfully bound service: 2025-04-08-1520.traffic.
INFO Server is listening for a connection and will exit when one is received.
INFO new service session session token=e2a15177-07f6-47a1-a236-df68073db92e
INFO found terminator for service: 2025-04-08-1520.traffic
INFO found service named: 2025-04-08-1520.traffic
INFO Server has accepted a connection and will exit soon.
INFO successfully dialed service: 2025-04-08-1520.traffic.
INFO traffic test successfully detected
INFO Server complete. exiting
INFO client complete
timo@TIMO-P14s:~$ ziti ops verify network
INFO All requested checks passed.
timo@TIMO-P14s:~$ ziti fabric list routers
│ ID │ NAME │ ONLINE │ COST │ NO TRAVERSAL │ DISABLED │ VERSION │ LISTENERS │
│ LCL6JKhPby │ ozrb1 │ true │ 0 │ false │ false │ v1.4.3 on linux/arm64 │ 1: tls:ozrb1.domain.com:80 │
│ OxLPlvdtE │ ozrb2 │ true │ 0 │ false │ false │ v1.4.3 on linux/amd64 │ 1: tls:ozrb2.domain.com:80 │
│ SwgS1vd1ap │ ozri2 │ true │ 0 │ false │ false │ v1.4.3 on linux/amd64 │ 1: tls:192.168.110.3:80 │
│ ePZkDbQx74 │ ozri1 │ true │ 0 │ false │ false │ v1.4.3 on linux/amd64 │ 1: tls:192.168.110.2:80 │
results: 1-4 of 4
timo@TIMO-P14s:~$ ziti fabric list links
│ ID │ DIALER │ ACCEPTOR │ STATIC COST │ SRC LATENCY │ DST LATENCY │ STATE │ STATUS │ FULL COST │
│ 2e5BUsoVS3UU3mKWkkesH6 │ ozrb2 │ ozrb1 │ 1 │ 10.2ms │ 9.9ms │ Connected │ up │ 20 │
│ 2fCNnQ1U72CQpB8QUWwKBk │ ozri2 │ ozrb1 │ 1 │ 44.3ms │ 38.0ms │ Connected │ up │ 83 │
│ 4kJjEabpc2Zli1Hzt0kzde │ ozri2 │ ozri1 │ 1 │ 2.9ms │ 2.9ms │ Connected │ up │ 5 │
│ 7AmubYgUWOY2ReorlyhvEO │ ozri1 │ ozrb1 │ 1 │ 9.0ms │ 8.9ms │ Connected │ up │ 17 │
│ E7gubU4chTiyu2rczYr6S │ ozri2 │ ozrb2 │ 1 │ 44.9ms │ 44.6ms │ Connected │ up │ 89 │
│ Yg075yxcpYLdKzg84jb7c │ ozri1 │ ozrb2 │ 1 │ 14.2ms │ 14.2ms │ Connected │ up │ 29 │
results: 1-6 of 6
timo@TIMO-P14s:~$ ziti fabric list circuits
│ ID │ CLIENT │ SERVICE │ TERMINATOR │ CREATEDAT │ PATH │
│ 4j0JNzGHT │ cm93tu1ki1nhtlvbpr7ye2tu1 │ zabbix-agents │ 1mOTqgmqtl0zeeIAvzVqiX │ 2025-04-08 08:29:58 │ r/ozrb2 │
│ 4n6bNAlrT │ cm93tu1ki1nhtlvbpr7ye2tu1 │ zabbix-agents │ 1mOTqgmqtl0zeeIAvzVqiX │ 2025-04-08 08:31:54 │ r/ozrb2 │
│ 4uc5TAGrN │ cm93tu1ki1nhtlvbpr7ye2tu1 │ zabbix-agents │ 1mOTqgmqtl0zeeIAvzVqiX │ 2025-04-08 08:31:34 │ r/ozrb2 │
│ 63vJTzGHT │ cm93tu1ki1nhtlvbpr7ye2tu1 │ zabbix-agents │ 1mOTqgmqtl0zeeIAvzVqiX │ 2025-04-08 08:29:59 │ r/ozrb2 │
│ 6PsaTAGrN │ cm93tu1ki1nhtlvbpr7ye2tu1 │ zabbix-agents │ 1mOTqgmqtl0zeeIAvzVqiX │ 2025-04-08 08:31:59 │ r/ozrb2 │
│ 8kQvTzGHN │ cm93tu2lo1nhwlvbpuzblxkeh │ wazuh-agents │ bH3ejxYqycDJGf2EUtTSz │ 2025-04-08 08:33:27 │ r/ozrb1 │
│ FiGJTzlrN │ cm93tu1ki1nhtlvbpr7ye2tu1 │ zabbix-agents │ 1mOTqgmqtl0zeeIAvzVqiX │ 2025-04-08 08:29:50 │ r/ozrb2 │
│ HBpGEAlHN │ cm93tu2lo1nhwlvbpuzblxkeh │ wazuh-agents │ 7iEdOXZIH5g1pIkk8yxdgW │ 2025-04-08 11:23:32 │ r/ozrb2 │
│ IZycTzGHN │ cm93tu1ki1nhtlvbpr7ye2tu1 │ zabbix-agents │ 1mOTqgmqtl0zeeIAvzVqiX │ 2025-04-08 08:31:19 │ r/ozrb2 │
│ IjncNAGHT │ cm93tu1ki1nhtlvbpr7ye2tu1 │ zabbix-agents │ 1mOTqgmqtl0zeeIAvzVqiX │ 2025-04-08 08:31:23 │ r/ozrb2 │
results: 1-10 of 31
timo@TIMO-P14s:~$ ziti fabric list terminators
│ ID │ SERVICE │ ROUTER │ BINDING │ ADDRESS │ INSTANCE │ COST │ PRECEDENCE │ DYNAMIC COST │ HOST ID │
│ 10q2wjKsW30Ao9ShqUEPM6 │ srv-backrest │ ozri2 │ edge │ 10q2wjKsW30Ao9ShqUEPM6 │ │ 0 │ default │ 0 │ ClhTL4eeM6 │
│ 1BW5fNEa0A4v5hjRRMzFTS │ ad-services │ ozrb2 │ edge │ 1BW5fNEa0A4v5hjRRMzFTS │ │ 0 │ default │ 0 │ q2OjYbQx7 │
│ 1MSVIPSX2dPkS4YBUFh2CI │ srv-jump2 │ ozrb2 │ edge │ 1MSVIPSX2dPkS4YBUFh2CI │ │ 0 │ default │ 0 │ YqRkhAFf8R │
│ 1Oal1BfsuSkGtcFbg0ijIJ │ ad-services │ ozri2 │ edge │ 1Oal1BfsuSkGtcFbg0ijIJ │ │ 0 │ default │ 0 │ q2OjYbQx7 │
│ 1RG5Hhmk7tcpf2XTr0rXrG │ odoo2-service │ ozrb2 │ edge │ 1RG5Hhmk7tcpf2XTr0rXrG │ │ 0 │ default │ 0 │ xhRbXQIha │
│ 1Sq6UhOY5WmPlcuLW12YDt │ homeassistant │ ozrb2 │ edge │ 1Sq6UhOY5WmPlcuLW12YDt │ │ 0 │ default │ 0 │ 9-X7OTd1ap │
│ 1ZCZ2XeGtpjlHsQQoyuRjm │ kalenteri-app │ ozri2 │ edge │ 1ZCZ2XeGtpjlHsQQoyuRjm │ │ 0 │ default │ 0 │ 6HUAGjHeM │
│ 1u4ma5em62aupSYohdFUSA │ rproxy-proxy-forward │ ozri2 │ edge │ 1u4ma5em62aupSYohdFUSA │ │ 0 │ default │ 0 │ yN5L7Sd1a │
│ 21REG7PQd90Magy4K2I4RA │ rproxy-luna2-forward │ ozrb1 │ edge │ 21REG7PQd90Magy4K2I4RA │ │ 0 │ default │ 0 │ HcoL4Kf7s │
│ 29eN2CdTILBMZRTHY5Uhvp │ rproxy-odoo2-forward │ ozrb2 │ edge │ 29eN2CdTILBMZRTHY5Uhvp │ │ 0 │ default │ 0 │ xhRbXQIha │
results: 1-10 of 43
timo@TIMO-P14s:~$
