Speaking to a company that develops an IoT fleet management platform, they are looking at getting OpenZiti deployed on their edge solution.
It currently supports up to docker 2.1, but the tunnel says it’s 3.9 (ziti-tunnel-sdk-c/docker-compose.yml at main · openziti/ziti-tunnel-sdk-c · GitHub)… do you see this as an issue?? Should it work?
I’m not a docker expert, I don’t think anyone on the team is. So I would say, wIthout “just trying it”, my guess is that there is enough differences where there’s a really good chance that it’ll cause a problem.
Also, docker is not the same as docker-compose. I’m not sure if docker-compose 3.9 is backward compatible to docker 2.1 or not.
So sadly, I don’t know.
