Passwordless openziti - error ENTITY_CAN_NOT_BE_DELETED
I am currently trying to migrate my openziti app to be passwordless and use certs only, but i encountered an issue.
I am using openziti/quickstart(2.0.8) docker image with both ctrl, router, and ctrl-init router. During setup, default admin identitiy is created. i want to get rid of that default admin identity, because it uses passwords to authenticate.
I docker exec inside ziti controller and i tried this:
ziti@5b2c185ed158:/persistent$ ziti login -f admin1@gmail.com.json
Saving identity 'default' to /home/ziti/.config/ziti/ziti-cli.json
ziti@5b2c185ed158:/persistent$ ziti edge delete identity "Default Admin"
delete of identity with id MM5mCNgKX: FAIL
error deleting identities/MM5mCNgKX instance. Status code: 400 Bad Request, ENTITY_CAN_NOT_BE_DELETED - The entity requested for delete can not be deleted
deleting other identities work fine. then i tried to delete default admin from zac:
How can i get rid of this default admin identity, so i can have fully passwordless openziti setup.
I believe the built-in Default Admin is protected from deletion, which would explain the ENTITY_CAN_NOT_BE_DELETED error. A workaround is to create a new admin identity (ziti edge create identity -A) and enroll it with a one-time token so it authenticates with a certificate. Then run ziti edge list authenticators and ziti edge delete authenticator <id> on the updb entry belonging to Default Admin, so the password login no longer exists. I haven't tested this on the 2.0.8 quickstart image, so it's worth confirming on a throwaway setup first.
Thanks that does the job. I also disabled that identity, just in case.
