PSA - quickstart change for latest tunnelers and c/python/swift/node sdk
Hi all,
UPDATED Aug 22 2023
Just wanted to drop a quick note about a bug in the quickstart. If you have generated your network from the quickstart recently. You want to verify the setting in the web section of your controller to ensure newer tunnelers don't have connectivity issues.
These commands should work with most/many/all the previous versions of the quicsktart but I can't really test them all. If you run into issues, comment back on this post.
Update Your Controller Config
  • source the .env file (or figure out how to set the variables accordingly):
    source $HOME/.ziti/quickstart/$(hostname -s)/$(hostname -s).env
  • Run this command. It will tell you whether or not you need to update your controller's config file:
    echo ""
    if [[ 0 -lt $(grep -c "${ZITI_PKI}/${ZITI_PKI_CTRL_EDGE_INTERMEDIATE_NAME}/certs/${ZITI_PKI_CTRL_EDGE_INTERMEDIATE_NAME}.cert" $ZITI_HOME/$ZITI_NETWORK.yaml) ]]
    then
      echo "You need to update/edit this file"
    else
      echo "Your quickstart is up-to-date/accurate"
    fi
  • If you see: Your quickstart is up-to-date/accurate, you're done.
  • If you see: You need to update/edit this file, run the commands listed below to repair your quickstart:
    sed -i 's#'"${ZITI_PKI}/${ZITI_PKI_CTRL_EDGE_INTERMEDIATE_NAME}/certs/${ZITI_PKI_CTRL_EDGE_INTERMEDIATE_NAME}.cert"'#'"${ZITI_PKI}/${ZITI_PKI_CTRL_EDGE_ROOTCA_NAME}/certs/${ZITI_PKI_CTRL_EDGE_ROOTCA_NAME}.cert"'#g' $ZITI_HOME/$ZITI_NETWORK.yaml
    echo "adding controller root CA to ca bundle: $ZITI_PKI/$ZITI_PKI_CTRL_ROOTCA_NAME/certs/$ZITI_PKI_CTRL_ROOTCA_NAME.cert"
    cat "$ZITI_PKI/$ZITI_PKI_CTRL_ROOTCA_NAME/certs/$ZITI_PKI_CTRL_ROOTCA_NAME.cert" > "${ZITI_PKI_CTRL_CA}"
    echo "adding signing root CA to ca bundle: $ZITI_PKI/$ZITI_PKI_SIGNER_ROOTCA_NAME/certs/$ZITI_PKI_SIGNER_ROOTCA_NAME.cert"
    cat "$ZITI_PKI/$ZITI_PKI_SIGNER_ROOTCA_NAME/certs/$ZITI_PKI_SIGNER_ROOTCA_NAME.cert" >>"${ZITI_PKI_CTRL_CA}" >> "${ZITI_PKI_CTRL_CA}"
    echo "adding secondary signing intermediate into ca bundle: $ZITI_PKI/$ZITI_PKI_SIGNER_ROOTCA_NAME/certs/${ZITI_PKI_SIGNER_INTERMEDIATE_NAME}_spurious_intermediate.cert"
    cat "$ZITI_PKI/$ZITI_PKI_SIGNER_ROOTCA_NAME/certs/${ZITI_PKI_SIGNER_INTERMEDIATE_NAME}_spurious_intermediate.cert" >> "${ZITI_PKI_CTRL_CA}"
Restart the Controller
If you're using systemd, restart the controller: sudo systemctl restart ziti-controller
Verify the Controller Config
You can now use openssl to verify your controller is correctly updated. Run the following two commands. The first one will pull the cabundle openssl command:
curl -sk https://${ZITI_CTRL_EDGE_ADVERTISED_ADDRESS}:${ZITI_CTRL_EDGE_ADVERTISED_PORT}/.well-known/est/cacerts \
  | openssl base64 -d \
  | openssl pkcs7 -inform DER -outform PEM -print_certs -out /tmp/well.known.cacerts.pem
openssl s_client \
  -connect ${ZITI_CTRL_EDGE_ADVERTISED_ADDRESS}:${ZITI_CTRL_EDGE_ADVERTISED_PORT} \
  -CAfile /tmp/well.known.cacerts.pem < /dev/null 2>&1 \
  | grep "Verify return code"
If you see anything other than: Verify return code: 0 (ok) you still have a problem. Revisit these steps.
Thank you very much.
System updated.
Is this acceptable output?
grep: /.yaml: No such file or directory
I forgot, I am running this in docker compose
The script assumes you've sourced the .env file so that the variables are available. Make sure you source $HOME/.ziti/$(hostname -s)/$(hostname -s).env. I'll update the instructions. thx Turns out it was step one of the instructions :slight_smile: Make sure you source that file.
Oh docker-compose... You'll want to exec into the container to source the file. Then you can source it. I'll try it now to make sure it works.
So I tried this two ways.
  1. I sourced the .env file in my docker project folder, ran the command, output as shown.
  2. I jumped into a shell on my controller, sourced the ziti.env file, got a tone of NOT OVERRIDING... messages which tells me it's already set and in the environment. Ran the command, same output.
Sorry. Thaks for pointing out docker is different. Here's the working docker compose instructions. I confirmed the compose steps are, unfortunately different. I'll update them with the updated steps.
  • docker exec -it docker-compose-ziti-controller-1 bash (or the correct name)
  • run:
    if [[ 0 -lt $(grep -c "${ZITI_PKI}/${ZITI_PKI_CTRL_EDGE_INTERMEDIATE_NAME}/certs/${ZITI_PKI_CTRL_EDGE_INTERMEDIATE_NAME}.cert" $ZITI_HOME/ziti-controller.yaml) ]]
    then
    else
    fi
Looks like the sed command to fix it will change too. Let me get these instructions up to date for docker...
Interestingly, that still didn't work. Here are the particulars about my setup... I notice that my .yaml file is named after the host.
$ grep -c "${ZITI_PKI}/${ZITI_PKI_CTRL_EDGE_INTERMEDIATE_NAME}/certs/${ZITI_PKI_CTRL_EDGE_INTERMEDIATE_NAME}.cert" ziti.mydomain.com.yaml
0
But the .env isn't correct, so far as I can tell.
$ echo $ZITI_HOME/$ZITI_NETWORK.yaml
/persistent/ziti.yaml
The actual file is ziti.mydomain.com.yaml
$ ll
total 68
drwxrwxrwx 4 root root  4096 Aug 15 14:51 ./
drwxr-xr-x 1 root root  4096 Aug 15 14:50 ../
-rw-r--r-- 1 ziti ziti     0 Aug 15 14:51 access-control.init
drwxr-xr-x 2 ziti ziti  4096 Aug 15 14:51 db/
drwxr-xr-x 9 ziti ziti  4096 Aug 15 14:51 pki/
-rw-r--r-- 1 ziti ziti 10046 Aug 15 14:51 ziti.env
-rw-r--r-- 1 ziti ziti    19 Aug 15 14:51 ziti.mydomain.com-87ab719dd0f7.init
-rw------- 1 ziti ziti 10544 Aug 15 14:51 ziti.mydomain.com.cas
-rw------- 1 ziti ziti  4163 Aug 15 14:51 ziti.mydomain.com.cert
-rw------- 1 ziti ziti  1006 Aug 15 14:51 ziti.mydomain.com.jwt
-rw------- 1 ziti ziti  3243 Aug 15 14:51 ziti.mydomain.com.key
-rw-r--r-- 1 ziti ziti     0 Aug 15 14:51 ziti.mydomain.com.log
-rw------- 1 ziti ziti  2065 Aug 15 14:51 ziti.mydomain.com.server.chain.cert
-rw-r--r-- 1 ziti ziti  1726 Aug 15 14:51 ziti.mydomain.com.yaml
edit: I did an sed on the actual domain.
edit again: I think the issue is that doing this from a docker instance will end up in some inconsistencies in the .env file. The .env file in the container is, I assume, derived from the .env file you use on docker compos up... maybe not. It definitely isn't the same file, because the ziti.env file in the container is full of if statements.
At any rate, being able to grep the file was sufficient for me. Knowing that in the /persistent folder there is a your.controller.name.yaml file and that needs to be grepped for the literal string is sufficient for me. Probably would be if someone chooses to go all cowboy and run it in docker anyway. :slight_smile:
Yeah, there are definitely differences in each quickstart that need to be accounted for. @qrkourier was working through that and should be putting up an updated set of steps soon. He let me know he was working on it.
Yep, working on a checker/repairer script. :+1:
It's unnecessary to source the env file with Docker Compose because user "ziti" ~/.bashrc already sources it when you exec bash to log in. I didn't check if that's also the case for the Docker quickstart (without Compose), but I'm guessing it is the case.
For Docker and Docker Compose quickstart users, any checking/repairing for this cert chain problem must be done as user "ziti" in the controller's or router's container.
Regardless of the script, if the grep command finds the string, then that confirms that no action is required, is that correct? The script certainly is helpful, but knowing what it's checking for as either a footnote or a description of the problem would be just as valuable, IMO. In such a case, if there is a option to manually verify then this would cover the edge cases where the script doesn't work and the end user doesn't need to understand what the script is doing.
That will detect one of the problems, but a grep of the controller config doesn't tell the whole story.
The thing to test is whether or not each TLS server presents a partial server cert chain that can be verified (completed) with cert(s) from CA bundle.
Let's start with how to check for a verification problem. The script will help document and automate how to repair the cert chains if necessary. You can perform these tests from the host or inside the controller container if you're using one of the Docker quickstarts.
First, you need a copy of the CA bundle as a PEM file.
# adjust IP and port to match the controller's client API web listener
  curl -sSk "https://127.0.0.1:1280/.well-known/est/cacerts" \
    | openssl base64 -d \
    | openssl pkcs7 -inform DER -outform PEM -print_certs -out "/tmp/well-known-anchors.pem"
Next, download a copy of the partial chain that's presented by each TLS server to TLS clients. Do this for the client API (e.g., :1280), ctrl plane (e.g., :6262), and public router edge (e.g., :3022)
openssl s_client -connect 127.0.0.1:6262 -showcerts </dev/null > /tmp/server-chain.pem 2>/dev/null
Finally, verify the server cert chain is completed by the CA bundle.
openssl verify -CAfile /tmp/well-known.pem /tmp/server-chain.pem
If you encounter a certificate verification problem with this method:
  1. Fix the verification chain (the script I'm working will help to document and, optionally, automate this)
  2. Re-start the controller or router that failed verification then re-test
  3. As needed, re-enroll the identities and routers that have the old CA bundle
A script for automatically checking TLS server certs are verifiable
This script requires the quickstart's env vars to be set in advance and automates checking those three TLS servers are currently verifiable.
#!/usr/bin/env bash
set -euo pipefail
check_chains(){
  declare -A CHAINS
  : "${CERTSDIR:=$(mktemp --directory --tmpdir="${TMPDIR:-/tmp}" "certs.${DATESTAMP}.XXXX")}"
  CHAINS[ctrl_plane]="${CERTSDIR}/controller-ctrl-chain.pem"
  CHAINS[edge_web]="${CERTSDIR}/controller-edge-web-chain.pem"
  CHAINS[router]="${CERTSDIR}/router-chain.pem"
  # download the controller's trust anchor bundle as currently presented to enrollees
  curl -sSk "https://${ZITI_CTRL_EDGE_ADVERTISED_ADDRESS}:${ZITI_CTRL_EDGE_ADVERTISED_PORT}/.well-known/est/cacerts" \
    | openssl base64 -d \
    | openssl pkcs7 -inform DER -outform PEM -print_certs -out "${CERTSDIR}/well-known-anchors.pem"
  # download the controller's edge web listener cert chain
  openssl s_client \
    -connect "${ZITI_CTRL_EDGE_ADVERTISED_ADDRESS}:${ZITI_CTRL_EDGE_ADVERTISED_PORT}" \
    -showcerts </dev/null > "${CHAINS[edge_web]}" 2>/dev/null
  # download the controller's ctrl plane listener cert chain
  openssl s_client \
    -connect "${ZITI_CTRL_ADVERTISED_ADDRESS}:${ZITI_CTRL_ADVERTISED_PORT}" \
    -showcerts </dev/null > "${CHAINS[ctrl_plane]}" 2>/dev/null || true  # requires client cert to avoid errexit
  # download the router's edge listener cert chain
  openssl s_client \
    -connect "${ZITI_ROUTER_NAME}:${ZITI_ROUTER_PORT}" \
    -showcerts </dev/null > "${CHAINS[router]}" 2>/dev/null || true  # requires client cert to avoid errexit
  for CHAIN in "${!CHAINS[@]}"; do
    if openssl verify -CAfile ${CERTSDIR}/well-known-anchors.pem "${CHAINS[${CHAIN}]}" &>/dev/null; then
      echo "INFO: $CHAIN certificate chain verified."
    else
      echo "ERROR: cert verification failed for $CHAIN with command 'openssl verify -CAfile ${CERTSDIR}/well-known-anchors.pem"\
      "\"${CHAINS[${CHAIN}]}\"'." >&2
      exit 1
    fi
  done
DATESTAMP=$(date +%Y%m%d%H%M%S)
check_chains
One-liner to run the above script:
curl -sSf https://raw.githubusercontent.com/openziti/ziti/add-signer-grandparent-ziti-env/quickstart/check-repair-cert-chains.bash \
    | bash
I pulled this check_chains() function from the script I'm working on for automating repairs. That's got more edges. If you can start over with a fresh quickstart v0.30.1 or newer, it won't have this problem.
The next challenge with the repair script I'm working on is what to do with quickstart routers that were enrolled with incomplete chains. Recreating them seems necessary, but a step-by-step procedure for that hasn't emerged yet. I tried ziti router run --extend but that didn't seem to work. After solving routers I plan to look at whether existing identities need to be re-created.
Edit: @qrkourier is the docker quickstart:latest (which shows 0.30.1) the current version which resolves this issue? Just confirming.
I had to tweak the output, but it looks like my install is affected. I think I will blow it away and start fresh. I plan on making this one a pet... so I would like to start with a clean install.
    else
      echo "ERROR: cert verification failed for $CHAIN with command openssl verify -CAfile ${CERTSDIR}/well-known-anchors.pem" ${CHAINS[${CHAIN}]}\"
      exit 1
    fi
  done
My output is
# ./checkcert.sh
ERROR: cert verification failed for router with command openssl verify -CAfile /tmp/certs.20230826001342.jTJ1/well-known-anchors.pem /tmp/certs.20230826001342.jTJ1/router-chain.pem"
btw, I was getting this error...
# ./checkcert.sh
./checkcert.sh: line 36: unexpected EOF while looking for matching `"'
This issue was first corrected in 0.30.0, and 0.30.1 is currently latest.
curl -sSf https://registry.hub.docker.com/v2/repositories/openziti/quickstart/tags/ \
    | jq '.results[]|select(.name|match("^(latest|0.30.1)$"))|[.name, .digest]'
  "latest",
  "sha256:2f14bb593d33f924422fcf25e592e7fffad579681a34e8ef761ba87c2cd2a46f"
  "0.30.1",
Thanks for testing the checker script! I'll add that missing double quote to the original post.
Here's a one-liner for running the checker script that assumes the quickstart env vars are defined by either logging in to the quickstart container (exec bash) or sourcing the ziti.env file.
    | bash
