Question ZAC whitelist
Hi All,
I was wondering if we can still protect the admin website as now it hangs behind the 8441 port. Previously we used the 8433 port and whitelisted it.
Tom
I assume you mean the 'ziti admin console' (ZAC). Sure, you can. There are numerous posts on the forum and videos that cover "splitting the api". You want to split your api onto two ports (and possibly two ips, but that's up to you). Leave the "client-api" and "oidc" on the public port and move the fabric, edge and zac to the private port. Example thread/post: Unable to configure Controller with split API - #5 by control_joe
Thanks for the reference, I saw this post but did not understand the purpose of it.
I managed to got it seperated by splitting up and copying the settings and changing the port for the managment side
  - name: client-management
    apis:
      - binding: edge-client
        options: { }
      - binding: edge-oidc
        options: { }
      - binding: edge-management
        options: { }
      - binding: fabric
        options: { }
      - binding: zac
          indexFile: index.html
into 2 difrent groups
(public port)
  - name: client
    bindPoints:
      - interface: 0.0.0.0:PUBLIC PORT
        address: DNS_TO_ZITI:PUBLIC PORT
    apis:
        options: { }
        options: { }
(private port)
  - name: management
    bindPoints:
      - interface: 0.0.0.0:PRIVATE PORT
        address: DNS_TO_ZITI:PRIVATE PORT
    apis:
        options: { }
      - binding: fabric
        options: { }
      - binding: zac
