I will use the term zrok dynamic endpoint meaning : the https endpoint zrok create every time a share is created, ie: https://6fyfuwuzl6xm.share.zrok.io. I don't know if a go template variable is available today
Hello, i set up a reverse proxy to my sandboxproduction.com upstream PHP server, it outputs pages with absolute links in html (is: http://sandboxproduction.com/logo.png) so I would like to translate links in response body with the zrok dynamic endpoint ( i mean the https endpoint zrok create every time a share is created )
Also I would like to replace 302 header location, because they contain absolute link http://sandboxproduction.com/ with aforementioned zrok dynamic endpoint
This is my current file
TNX in advance
http:// {
bind {{ .ZrokBindAddress }}
reverse_proxy https://127.0.0.1 {
header_up Host sandboxproduction.com
transport http {
tls
tls_insecure_skip_verify
handle_response {
header replace Location http://sandboxproduction.com https://{{dynamic endpoint host+port variable???}}
Hi @MatteoOreficeGS, welcome to zrok
and the community! (and to OpenZiti).
Firstly, are you sure you want to use a dynamic endpiont every time? With zrok
front door, or more basically, with just using zrok reserve
, you can establish a permanent endpoint url so that you don't have to do all this.
If we start there, would that "solve" your issue or do you like that the endpoint is dynamic?
For example in my recent blog Play Minecraft with friends safely and securely I used a reserved share so that my zrok endpoint is always mymcserverjan06.share.zrok.io
For example:
zrok reserve public https://whatever.you.want --unique-name myshare
[ 0.474] INFO main.(*reserveCommand).run: your reserved share token is 'myshare'
[ 0.475] INFO main.(*reserveCommand).run: reserved frontend endpoint: https://myshare.share.zrok.io
then:
zrok share reserved myshare
You'll see:
And now that url is yours forever
Hello @TheLumberjack ! thank you so much for quick reponse, it is a proof there is behind a living community
I tested also reserverd share and it worked perfectly, I omitted this so to not over complicate, sure my final goal is run zrok with this feature
in the meantime (2h) I tested and solved some issues
- I tested ngrok and I understood the feature for rewriting or altering proxied response was not implemented in both tools, so maybe I was assuming it as a zrok feature
- so I changed my upstream web server config to alter response body and headers, unfortunately I accomplish it with ngrok dynamically but not in zrok
http {
# rewriting absolute url in location header with relative to omit
# original upstream wrong base url
map $upstream_http_location $us_location_new {
"~https?://[^/]+/(.*)" "/$1";
location ~ \.php$ {
# replace domain in response body with x_forwarded_host
# ngrok leave the header so we can dynamically alter response body
sub_filter 'sandboxproduction.com' $http_x_forwarded_host;
sub_filter_once off;
# hide and replace location header with
fastcgi_hide_header location;
add_header location $us_location_new;
fastcgi_pass fastcgi_frontend;
fastcgi_param SCRIPT_FILENAME $realpath_root$fastcgi_script_name;
include fastcgi_params;
ngrok
zrok
It seems zgrok hide x_forwarded_host, and no other header is available to the upstream server application
follows zrok detected server vars
As I see there is not a trace about original host both reserved or dynamic as ngrok
I added the line header_up X-Forwarded-Host {http.request.hostport}
sandbox.caddyfile
http:// {
transport http {
tls
companion files
upstream nginx.conf
http {
upstream nginx vhost.conf
location ~ \.php$ {
