I’m trying to add an ARM64 OCI (Oracle Cloud Infrastructure) VM to my Network but I get a seg fault on connect.
Steps to reproduce:
- Created
VM.Standard.A1.Flexinstance with 2 CPU and 12 GiB RAM - Downloaded and unzipped
v0.19.2/ziti-edge-tunnel-Linux_arm64.zip - Copied
oracle1.jwtfrom NetFoundry - Executed
./ziti-edge-tunnel enroll -j oracle1.jwt -i oracle1.jsonwhich worked fine - Executed
./ziti-edge-tunnel run-host --identity oracle1.jsonas root and got:
Segmentation fault (core dumped)
Has somebody seen that before?
Is someone successfully running an edge tunnel on an Oracle ARM64 VM?
How can I investigate that error further?
Regards,
Sven
