Self-hosted Anytype over openziti
Hello community!
I’ve successfully installed openziti network and it’s working great with web-services. Recently I’ve tried to install self-hosted Anytype server and it also works fine in my local network. But it doesn’t work over openziti network.
Here is what was used:
  1. original docker-compose of any-sync any-sync-dockercompose/docker-compose.yml at main · anyproto/any-sync-dockercompose · GitHub
  2. openziti service for anytype - intercept and host tcp/udp 1001-1006 and 1011-1016
when I start anytype it says connection is working fine. but it fails few minutes later to sync notices. debug network returns perfect log:
system info: GoOS:linux,Kernel:Linux,Core:6.8.0-88-generic,Platform:x86_64,OS:GNU/Linux,Hostname:tt-IdeaPad-Slim-3,CPUs:8
open TCP conn, addr: at.mydomain.net:1004
TCP conn established, ip:100.64.0.3:1004, dur: 108.411891ms
start handshake
handshake success, dur: 395.769125ms, total: 504.203089ms
open yamux session
yamux session success, dur: 33.877µs, total: 504.255547ms
open sub connection
open sub conn success, dur: 83.681µs, total: 504.35683ms
start proto handshake
proto handshake success, dur: 137.746777ms, total: 642.11164ms
start configuration request
configuration request success, dur: 109.395655ms, total: 751.521894ms, nid: N5N8qc24kecLAbiYgmBbhvvaCXNc2ZFbzhf6njxhpdiWKF7g
success, dur: 751.549974ms
open QUIC conn, addr: at.mydomain.net:1014
QUIC conn established, ip:quic://100.64.0.3:1014, dur: 629.486798ms
open sub connection
open sub conn success, dur: 28.569µs, total: 629.539395ms
proto handshake success, dur: 189.908981ms, total: 819.461508ms
configuration request success, dur: 68.160138ms, total: 887.646793ms, nid: N5N8qc24kecLAbiYgmBbhvvaCXNc2ZFbzhf6njxhpdiWKF7g
success, dur: 887.661182ms
But, I see in device log error
Dec 10 23:16:56 tt-IdeaPad-Slim-3 ziti-edge-tunnel[906145]: (906145)[ 1991.934] ERROR tunnel-sdk:tunnel_tcp.c:191 on_tcp_client_err() client=tcp:100.64.0.1:60112 err=-14, terminating connection
Dec 10 23:16:56 tt-IdeaPad-Slim-3 ziti-edge-tunnel[906145]: (906145)[ 1991.964] WARN ziti-sdk:channel.c:574 dispatch_message() ch[0] received message without conn_id or for unknown connection ct[DataType] conn_id[16]
and in openziti controller logsr:
Dec 10 23:16:59 openziti-controller ziti[7525]: {"file":"github.com/openziti/ziti/controller/network/fault.go:32","func":"github.com/openziti/ziti/controller/network.(*Network).fault","level":"info","msg":"network fault processing for [1] circuits","time":"2025-12-10T23:16:59.929Z"}
Dec 10 23:16:59 openziti-controller ziti[7525]: {"circuitId":"6mO4wBeqethellXN3hZgrT","file":"github.com/openziti/ziti/controller/network/fault.go:49","func":"github.com/openziti/ziti/controller/network.(*Network).fault","level":"info","msg":"sent unroute for circuit to router in response to forwarding fault","routerId":"bkkm5uS80S","time":"2025-12-10T23:16:59.929Z"}
Dec 10 23:17:29 openziti-controller ziti[7525]: {"file":"github.com/openziti/ziti/controller/network/fault.go:32","func":"github.com/openziti/ziti/controller/network.(*Network).fault","level":"info","msg":"network fault processing for [1] circuits","time":"2025-12-10T23:17:29.930Z"}
Dec 10 23:17:29 openziti-controller ziti[7525]: {"circuitId":"5k2ugOZ4mFsvabcLCxvtzc","file":"github.com/openziti/ziti/controller/network/fault.go:49","func":"github.com/openziti/ziti/controller/network.(*Network).fault","level":"info","msg":"sent unroute for circuit to router in response to forwarding fault","routerId":"bkkm5uS80S","time":"2025-12-10T23:17:29.930Z"}
Dec 10 23:18:39 openziti-controller ziti[7525]: {"file":"github.com/openziti/ziti/controller/handler_edge_ctrl/subscribe_to_data_model.go:54","func":"github.com/openziti/ziti/controller/handler_edge_ctrl.(*subscribeToDataModelHandler).HandleReceive","index":103,"level":"info","msg":"data model subscription request received","routerId":"bkkm5uS80S","time":"2025-12-10T23:18:39.149Z","timelineId":"jVbDeEkDg"}
Dec 10 23:18:39 openziti-controller ziti[7525]: {"currentIndex":103,"file":"github.com/openziti/ziti/controller/sync_strats/rtx.go:189","func":"github.com/openziti/ziti/controller/sync_strats.(*RouterSender).handleSyncRequest","level":"info","msg":"data model subscription started","renew":true,"requestedIndex":103,"routerId":"bkkm5uS80S","routerName":"er1","subscriptionDuration":"2025-12-10 23:23:39.149384495 +0300 MSK m=+197354.313819323","time":"2025-12-10T23:18:39.149Z","timelineId":"jVbDeEkDg"}
Dec 10 23:24:09 openziti-controller ziti[7525]: {"file":"github.com/openziti/ziti/controller/handler_edge_ctrl/subscribe_to_data_model.go:54","func":"github.com/openziti/ziti/controller/handler_edge_ctrl.(*subscribeToDataModelHandler).HandleReceive","index":103,"level":"info","msg":"data model subscription request received","routerId":"bkkm5uS80S","time":"2025-12-10T23:24:09.148Z","timelineId":"jVbDeEkDg"}
Two questions
  1. is there anyone who successfully running self-hosted anytype?
  2. any ideas what went wrong?
openziti v1.6.12
anytype 0.51.2
Hi @rand, welcome to the community and to OpenZiti!
Could you possibly give me the exact steps you used along with your .env files (redacted as necessary) I could try it out at some point. I don't/haven't used AnyType yet but I'd be happy to take a look maybe this weekend if I can.
Greatings, @TheLumberjack !
anytype .env is default
.env.override
EXTERNAL_LISTEN_HOSTS="192.168.1.132"
openziti anytype-host-config
  "name": "anytype-host-config",
  "configTypeId": "NH5p4FpGR",
  "data": {
    "address": "192.168.1.132",
    "forwardProtocol": true,
    "forwardPort": true,
    "allowedPortRanges": [
        "low": 1001,
        "high": 1006
        "low": 1011,
        "high": 1016
    "allowedProtocols": [
      "tcp",
      "udp"
    "httpChecks": [],
    "portChecks": []
  "tags": {}
and it didn't work. But
I have great news @TheLumberjack and I'll save your weekend!
Your question helped me to find a solution. I just added extra ips in EXTERNAL_LISTEN_HOSTS, I don't know for sure which one is worked. First IP I got from logs of laptop with openziti tunnel (anytype ip) and another IP was my public IP of controller and edge router openziti.
Now both of my devices are syncing remotely. Thank you @TheLumberjack !
sweet - i was gonna check this out today but you indeed saved me from doing so! :slight_smile: cheers
