I come back to this post because I would like to change the token life time. I saw your explanation and you mentioned that duration can be set on the controller in the yaml setting file. But I don’t see any yaml file on my controller!!! Is it possible? When I used Quickstart, I remember there were yaml files but with our new installation not using Quickstart, I see them nowhere.
Do I have to create such file? And where should it be knowing the tree is /opt/openziti/etc/controller.
Thanks.
[made a toplevel post by clint]
Refer to this other discourse post where JWT lifetime is mentioned:
Hi @Eric, no that's not possible. It's likely you just don't know where it is. If you have a systemd service you can find that location pretty easily with systemctl cat ziti-controller (or whatever the unit is). That should tell you where that config file is.
After you bootstratpped the controller it emits:
INFO: bootstrap completed successfully and will not run again. Adjust /var/lib/private/ziti-controller/config.yml to suit.
That's the file you'd want to change/look at, I believe.
I have looked at the config.yml file and see that life time is set to 180m but when I create an identity, life time is 60m. Is the value in config.yml overwritten by something else?
Hmm. It shouldn't be. You did restart the controller after updating the configuration, correct? If you restarted it, we might need to try to reproduce the behavior. You also indented the yaml properly right? I know that's a 'dumb question' but I mean, I've screwed that up before so I know it's easy to to
Actually, for now, I’ve done nothing, just read the YAML config file and see this 180m value knowing that tokens life time is 60m in reality. So I believe that this time, it’s not my bad!
/# edgeIdentity - optional
/# A section for identity enrollment specific settings
edgeIdentity:
/# duration - optional, default 180m
/# The length of time that a Ziti Edge Identity enrollment should remain valid. After
/# this duration, the enrollment will expire and no longer be usable.
duration: 180m
/# edgeRouter - Optional
/# A section for edge router enrollment specific settings.
edgeRouter:
/# The length of time that a Ziti Edge Router enrollment should remain valid. After
duration: 180m
To be entirely honest, I don't know what's going on. You're using the latest ziti?
After I edit my config:
sudo vi /var/lib/private/ziti-controller/config.yml
Set it to 20m (notice there are two to set one for identities and one for routers):
edgeIdentity:
duration: 20m
edgeRouter:
duration: 180m
then restart the controller and run this block of bash to delete/make an identity and then parse the jwt locally:
You'll see in my case, 1200 which is 60*20m in seconds... Could you POSSIBLY have another instance of ziti you're connecting to? Or possibly have somehow muffed the edit?
edgeIdentity:
duration: 180m
edgeRouter:
duration: 360m
Then I restarted the service and created a new identity but the token life time remains 60 m.
Result is very strange:
delete of identity with id 9OPfDQlepR: OK
New identity 20m created with id: O1Y-NQlWLR
Enrollment expires at 2025-08-29T04:51:19.046Z
1756441879
1756443079
1200
BUT I created it at 06:31 my time and I see this in the json:
my server current time:
Local time: ven. 2025-08-29 06:34:48 CEST
Universal time: ven. 2025-08-29 04:34:48 UTC
RTC time: ven. 2025-08-29 04:34:48
Time zone: Europe/Paris (CEST, +0200)
System clock synchronized: yes
NTP service: active
RTC in local TZ: no
So this means that identity creation is not using local time but UTC time. This explains why I got 60m life time token when duration was set to 3 hours as we are at UTC+2 here.
Due to previous test, and because my goal is to obtain a one day life time for the tokens, I have put 26 hours in config.yml (1560m) but when I create new identity, I effectively see a one day life time.
ziti edge create identity 20m -o /tmp/20m.jwt
now=$(date +%s)
expiration=$(cat /tmp/20m.jwt | cut -f2 -d "." | base64 -d 2>/dev/null | jq -r .exp)
echo $now
echo $expiration
echo $((expiration - now))
Found 0 identities with id or name matching 20m
New identity 20m created with id: 8mTvWNQUt4
Enrollment expires at 2025-08-30T06:44:26.871Z
1756442666
1756536266
93600
I think you don't get me, maybe it is due to my poor English usage!
See this:
root@zpix:/# ziti edge delete identity 20m
now=$(date +%s)
echo $now
echo $expiration
New identity 20m created with id: h98MqvMlzn
Enrollment expires at 2025-09-02T04:47:34.613Z
1756702054
1756788454
86400
root@zpix:/#
I agree I obtain 84400 seconds BUT look at the expiration time: it's exactly 22 hours after I created it. The problem is that the 24h are starting from UTC time, not my time. Expiration should have been 06:47:34. Does it make sense now?
I take it you are in UTC+2 timezone, right? The first number you show is 1756702054. That corresponds to 2025-09-01 04:47:34Z which is in UTC. i assume you created the identity at 6:47am local time? I should have simply printed that out too. It probably would have made this interaction easy for both of us
Then, the expiration for the token is 24th later at 4:47 UTC the next day.
The ‘Z’ at the end of the date signifies the UTC timezone. Assuming you are in a UTC+2 timezone, it's working correctly. My expectation is that you just aren't familiar with the ‘Z’ timezone?
Actually, when duration was set to 180m, I noticed that life time expired after 1 hour, that's why I linked this behavior to the time zone. Now, after your last explanation, I'm confused on what happened. I'll do additional testing and come back to you.
