Setting up primary/secondary auths for controller
Hi looking at docs , I see it is possible to setup cert/jwt authentication as primary and then maybe have an MFA on top of it .
Where can I find the guide to achieve this
Please do point thanks
Yes. NetFoundry has this configuration in place for our chat app. You want to implement a posture check for TOTP
Were to execute those api's ? Since I'm not using sdk
Posture Checks | OpenZiti shows you ziti cli commands which should get you what you need
