Setup ziti-edge-tunnel with interception
Hello,
I would like to set up a ziti-edge-tunnel on a Linux system with podman, which binds services, interrupts connection calls and routes them via the Ziti-network.
My tunneler-compose file looks like this:
version: "3.9"
services:
  openziti-tunneler:
    image: docker.io/openziti/ziti-edge-tunnel:1.3.2
    hostname: openziti-tunneler
    read_only: true
    security_opt:
      - no-new-privileges
    user: 1000
    devices:
      - /dev/net/tun:/dev/net/tun
    cap_add:
      - NET_ADMIN
    volumes:
      - ./config:/ziti-edge-tunnel:z
    labels:
      - io.containers.autoupdate=registry
    environment:
      - ZITI_ENROLL_TOKEN=<ENROLL_TOKEN>
    networks:
      - proxy
    restart: always
networks:
  proxy:
    external:
Since the container runs in rootless-podman, I have manually updated /etc/resolv.conf as requested in the logfile:
# Generated by NetworkManager
nameserver 100.64.0.2
However, a curl <service> does not work, and the IP 100.64.0.2 is also not reachable.
The network configuration with ip a also only lists the loopback interface and an eth0. Should there be another one?
Best regards.
Update:
The tunneler now works with this config:
version: "3.9"
services:
  openziti-tunneler:
    read_only: true
    security_opt:
      - no-new-privileges
    user: 1000
    devices:
    cap_add:
      - NET_ADMIN
    volumes:
    labels:
    environment:
    network_mode: host
    restart: always
From the host i can ping and curl the services, but the container seems not to use the updated /etc/resolv.conf.
How need the container-configs updated, that they use the new nameserver too?
Perhaps your goal is a transparent proxy for a container, non-container processes running on the Docker host, or both. There's a different strategy for each.
You can use that container image openziti/ziti-edge-tunnel like this example to provide a transparent proxy and nameserver for all processes on the host, including containers. This is equivalent to installing the ziti-edge-tunnel Linux package on the host, and both require systemd-resolved on the host to auto-configure DNS, or you must configure the resolver to query the Ziti nameserver first (default: 100.64.0.2). It is not possible to use this image in a container-specific way, only to configure the entire host.
Another goal is to provide a transparent proxy and nameserver for a specific container(s), not the Docker host, and not all other processes on the Docker host. This is done with the Ziti "sidecar" approach. I recommend the openziti/ziti-router approach like this example. Here's a quick overview of the sidecar approach: configure a Ziti router with tunneling enabled to share a Docker network interface with the client application. The tunneler configures the Docker network namespace with transparent proxy (TPROXY) iptables rules and a nameserver for Ziti services. Only the containers sharing the Docker network interface can access the Ziti services.
I used the ziti-edge-tunnel in the container and adapted /etc/resolv.conf. The Ziti-Interface ziti0, is also started successfully and requests to services from the host system are also successfully routed via the Ziti-network. However, the containers themselves cannot resolve the domains.
You are running the tunneler in a privileged container on a Linux host with the goal of configuring the entire host, including all containers, with the same Ziti service access, correct?
You wish to manually configure the Docker host to use the Ziti nameserver. This can work if the tunneler privileged container has network mode "host" and there are no other processes managing libc's /etc/resolv.conf, eg NetworkManager, Resolved, etc.
After configuring the host resolver and verifying name resolution, you must configure the other containers to use the Ziti nameserver provided by the tunneler. This will involve DNS configuration and ensuring the containers have an IP route and firewall exceptions for the nameserver, if applicable.
I believe the default revolver configuration for Docker containers is to inherit the host configuration as a fallback and treat the Docker nameserver, which has features like resolving container names to Docker bridge IP addresses, as primary resolver.
This functions differently on the default Docker bridge and custom Docker bridges. Generally, use a custom bridge for the most intuitive behavior.
Thank you for the clarification, now I have finally understood it and the connections work.
The problem was actually that the NetworkManager was constantly overwriting the DNS configuration.
Glad you found it! For others, you don't necessarily need to change the resolver used by your distribution, just to follow that resolver's docs to set the Ziti tunneler nameserver as first to answer queries. Only systemd-resolved is reliably auto-configured, and you can manually configure resolveconf, Network Manager, Netplan, /etc/resolve.conf (as a last resort).
Network Manager is quite common. The rationale is to modify the connection profile with a primary (Ziti) and at least one recursive nameserver.
nmcli connection modify wired1 ipv4.dns "100.64.0.2,8.8.8.8,1.1.1.1"
In case you require a single nameserver you can use Ziti DNS with the --dns-upstream 1.1.1.1 option.
Ref: Options and Modes | OpenZiti
can you please explain this more detailed? thx
OpenZiti provides software for dialing Ziti services, and different pieces of software use different system-level strategies to accomplish transparent interception, DNS resolution, etc.
For Linux, there are two sets of software applications implemting distinct strategies:
  • ziti-edge-tunnel run represents a system-wide (cannot be containerized) strategy involving /dev/net/tun and the systemd DBus API for resolved.
  • ziti router run and ziti tunnel tproxy use TPROXY iptables rules, which can exist inside a container's network namespace, and so are appropriate for a scenario where a container must dial a Ziti service by intercept domain name.
