Unauthenticated DoS via unbounded memory allocation in striped session cookie parsing
CVE-2026-40303
Summary
endpoints.GetSessionCookie parses an attacker-supplied cookie chunk count and calls make([]string, count) with no upper bound before any token validation occurs. The function is reached on every request to an OAuth-protected proxy share, allowing an unauthenticated remote attacker to trigger gigabyte-scale heap allocations per request, leading to process-level OOM termination or repeated goroutine panics. Both publicProxy and dynamicProxy are affected.
  • Attack Vector: Network — exploitable via a single HTTP request with a crafted Cookie header.
  • Attack Complexity: Low — no preconditions or chaining required; the attacker only needs to know the cookie name (publicly derivable from any OAuth redirect).
  • Privileges Required: None — reached before JWT validation or any authentication check.
  • User Interaction: None.
  • Scope: Unchanged — impact is confined to the affected proxy process.
  • Confidentiality Impact: None.
  • Integrity Impact: None.
Availability Impact: High — sustained or concurrent requests cause OOM process termination, taking down the proxy for all users of all shares it serves.
Affected Components
  • endpoints/oauthCookies.go — GetSessionCookie (line 81)
  • endpoints/publicProxy/authOAuth.go — handleOAuth (line 50) — call site, pre-auth
  • endpoints/dynamicProxy/cookies.go — getSessionCookie (line 29) — call site
Affected Versions: > 1.1.9 < 2.0.1
CVSS 3.1 Score 7.5 High
CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:N/I:N/A:H
Thank you very much bugbunny.ai for researching and reporting this issue.
