This is a simple question that will help me diagnose a problem that I am having
When I run the following command on the controller, after logging into ziti, I am returned the ca bunder as expected.
curl https://controller_server:6262/.well-known/est/cacerts
However, when I run this on a remote server, it does not work, returning the following message.
curl: (60) SSL certificate problem: unable to get local issuer certificate
More details here: https://curl.haxx.se/docs/sslcerts.html
curl failed to verify the legitimacy of the server and therefore could not
establish a secure connection to it. To learn more about this situation and
how to fix it, please visit the web page mentioned above.
I am using this to diagnose why I cannot login to the controller from a remote server.
The strangest thing is that I did this last night… but something has changed between then and now… and I have no idea of what I did to cause this problem
